None machined 451 rims?
Old 02-15-14, 10:17 AM
ziqpy
ziqpy's Avatar
Do they exist?
I know dahon had them on a few high end models maybe in 406? But can you order them seperately?
Only finding machined ones
ziqpy is offline
Old 02-15-14, 10:36 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
You mean rolled and pinned rims.. ? where have you searched?.
fietsbob is offline
Old 02-15-14, 11:06 AM
ziqpy
ziqpy's Avatar
Yes with no braking surface on them.
Googling, like a mad hatter, my frame will be here next week.
ziqpy is offline
Old 02-15-14, 11:19 AM
HGR3inOK
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
See: www.danscomp.com
Shipping might be pricey.
-HANK RYAN-
Norman, Oklahoma USA
HGR3inOK is offline
Old 02-15-14, 12:03 PM
ziqpy
ziqpy's Avatar
Thx for that, seems 406 way to go.
https://shop.alienationbmx.com/skylark.html
see if I can get them in black here, unless, someone makes a better suggestion
ziqpy is offline
Old 02-15-14, 01:12 PM
HGR3inOK
Quoted: 56 Post(s)
To clarify - DansComp does have 451 rims. See:
https://www.danscomp.com/products.php...ize=20 x 1-1/8
and
https://www.danscomp.com/products.php...ize=20 x 1-3/8
-HANK RYAN-
HGR3inOK is offline
Old 02-16-14, 10:47 PM
thugpipe
Bikes: 2011 Origin 8 Bully, 2010 Dahon Silvertip, 2016 Respect Mini Velo
Quoted: 20 Post(s)
Velocity makes 406 rims without machined sidewalls, I used the non-MSW Aeroheat rims on my disc brake mini velo build but I had to order them direct from Velocity.
https://store.velocityusa.com/p/aeroh...x_20-406?pp=12
Or they offer the wider cliffhanger rim in non machined sidewall
https://store.velocityusa.com/p/cliff...f-hanger?pp=12
Its funny but the A23 is the only 451 rim they offer now but they don't have that one in non-MSW in any size sadly. I hope this helps
thugpipe is offline
Old 02-17-14, 03:56 AM
ziqpy
ziqpy's Avatar
Thanks for that.
I was looking at the cx75 hubs which are 28 hole.
Are all shimano hubs able to take 105 cassettes?
ziqpy is offline
Old 02-17-14, 07:52 AM
thugpipe
Quoted: 20 Post(s)
Going for center lock discs, I went for the 6 bolt disc setup because there seemed to be a wider variety of offerings and I got a good deal on my BB7 which came with rotors. I bought Sram X.7 hubs which I have been very happy with.
Any shimano 8,9, and 10 speed cassettes are pretty much universal and should fit any shimano or sram freehub except for some of the newer 11 speed hubs.
Are you looking to go for skinny or fat tires on your build? I assume you are leaning twards skinny given your leaning twards 451s.
thugpipe is offline
Old 02-17-14, 08:16 AM
ziqpy
ziqpy's Avatar
Well i found you can get 406 BMX rims from alien nation. No brake rims.
I was thinking of using the cx75 hubs with R517 brakes and they are 28 holes. 10 speed 105 cassette with spacer.
File Type: jpg
ziqpy is offline
Old 02-17-14, 10:19 AM
thugpipe
Quoted: 20 Post(s)
My only problem with BMX rims is the very wide profile of the rim, I went with the aeroheat rims because the rim is only 24mm wide and the 32h drilling works for me.
Not to presume too much but look into the installation and adjustability of those brakes before you buy them.
thugpipe is offline
Old 02-17-14, 10:33 AM
ziqpy
ziqpy's Avatar
have the pdf somewhere, they silver over the dark grey cx77 and both are adjustable at each side of pad, if i recall.
ziqpy is offline
Old 02-17-14, 11:03 AM
fietsbob
Bikes: 8
why?
fietsbob is offline
Old 02-17-14, 12:49 PM
thugpipe
Quoted: 20 Post(s)
Originally Posted by fietsbob
why?
He is building a bike with disc brakes so I presume ziqpy prefers the look of a rim without the machining, its really just a style thing. Well that was my reasoning when I got mine at least
thugpipe is offline
Old 02-17-14, 12:52 PM
ziqpy
ziqpy's Avatar
I would have thought it would be stronger too.
ziqpy is offline
Old 02-17-14, 12:59 PM
fietsbob
Bikes: 8
Small diameter is already a strength factor..
so extrusion die making a brake track or not, shape,
is not really a significant factor , but if the theory feels comfortable . go with it..
I got disc brakes and Sun CR18 406 rims, could put disc or rim brakes on them .
they're OK..
fietsbob is offline
Old 02-18-14, 11:27 AM
LittlePixel
Raleigh20 PugFixie, Merc
LittlePixel's Avatar
Bikes: 1982 Raleigh Twenty Hotrod Fixie; 1984 Peugeot Premier Fixie, 2007 Merc Lightweight folder
Liked 4 Times in 4 Posts
Spray paint / powder coating is your friend
LittlePixel is offline
adavis84
Mountain Biking
0
09-24-15 09:05 PM
lixxus
Singlespeed & Fixed Gear
16
05-09-15 07:51 AM
markk900
Classic & Vintage
4
11-23-14 11:39 AM
mike alanko
Classic & Vintage
9
08-18-10 09:10 PM
