10-speed Mavic FTS Freehub?
Hi all,
I got a screamin deal on a Mavic Cosmic Expert Serie 6000 wheelset and was planning to put them on my 11-speed Masi Gran Criterium. The yellow of my lugs matches the Mavic logos, it's so wonderful. I have a Wheels Mfg. Accelerator 11, but the freehub body on the rear wheel is 9-speed only. I would just swap the body out, but the FTS system is incompatible with new(er) FTS-L. Did Mavic make 10-speed compatible FTS freehubs? Is there any way to update to FTS-L or am I up **** creek here?
Thanks for the info!!
If the freehub is 9-speed compatible then it also works with 10-speed. I don't know is they changed something from FTS to FTS-L but if they are the same outside dimensions you can fit an normal 11-speed cassette to the mavic freehub-
