All City SpaceHorse vs Gorilla Monsoon
rockermike
Bikes: Surly Troll and Soma DoubleCross
what's the difference?.... other than wheel size (though both will take either 700 or 650b) I don't see much difference. Can someone enlighten me. And while you're at it, if you're informed on such matters.... how do they compare to the Soma Wolverine? TIA
Quoted: 1210 Post(s)
Liked 167 Times
Spacehorse is a fat tired road bike with a touring slant.
Gorilla Monsoon is a rigid mountain bike with drop bars.
The Wolverine is more similar to the Spacehorse than the Gorilla Monsoon. It rides a little better too IMO but they're both fairly similar. The Wolverine has also had some issues with dropouts failing prematurely which has lead to the new 3.0 models. Some believe the changes are merely cosmetic and do not correct the overall design issue. Quality control for Soma is always much less consistent than All-City in my experience.
I have not ridden the Gorilla Monsoon but feedback from a friend that has one is that it is very much a mountain bike. Rides stiff and sorta dead on the road but comes alive on singletrack and rough gravel. Also much heavier than a road-focused bike.
This blend of geometry and our 612 Select tubing creates a bike that is capable of quick road centuries, gravel racing, commuting, and of course loaded touring.
Want to do mixed pavement and single track rides? Put in long days off-road? Do some fire road touring? Camping? Ride across the continent? No problem.
Quoted: 20 Post(s)
It will be interesting to see what insights an expert will suss out. From my own limited understanding, the all city’s are cut from the same cloth wrt a by the charts analysis. The most significant geo aspects I could identify are GM is slightly taller and has shorter chainstays. I believe the tires are even compatible between the two frames. So then, a dropper seat post, fork mounted waterbottles and through axles on the GM vs quick release on the SH further divide. All city didn’t publish details about about the tubing or weight between frames though I bet they would if asked.
The space-horse is marketed as commuter and long distance rider I believe the GM fits that mold equally well but adds a dropper post, TA’s and a hair less head angle in nod to off-road trends.
The wolverine is a bit different. It’s longer, lower and with less trail then the AC’s. It design goals seem to be a fatter wheeled, more flexible cross bike. The sliding drop allow you to tailor the handling a bit. And it has more tire clearance the SH.
They all look like they would take you anywhere you want to go in style. A good problem to have imo.
High Plains Luddite
I'm slow, but I catch on eventually. !
And I sure wish I could bring myself to even consider spending $$$$ for any of the bikes being discussed in this thread. They all look amazing for the kind of mostly dirt/gravel riding I do these days.
sgtrobo
44
05-11-15 02:44 PM
vinuneuro
1
03-04-14 03:26 PM
