Shopping list for 2006 Cannondale power train and braking rebuild
Tell me what to buy
Bikes: Cannondale Bad Boy 2006
I have a 2006 Cannondale Bad Boy which needs some updating. I'd like to put the following on it.
3 speed gear set
Disc brakes (the burlier the better)
I'm looking for mid-range recommendations, price wise. The bike's main use will be pulling a trailer with children in it.
Many thanks!
3 speed gear set
Many thanks!
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
If the frame wasn't designed for disc brakes, I don't think you can add them.
Fork blades and seat stays are beefier to handle the stresses.
Tell me what to buy
Quoted: 4209 Post(s)
Liked 3,875 Times
"3 speed gear set" ?? As in a triple crank set or a 3 speed IGH or a 3 cog cassette???
When hauling a trailer most want pretty low gearing. Do you? BTW are there hills in "here"? Andy
Added- The early disk braked Cannondales can have non standard disk brake specs. As example their rotors used a 4 bolt attachment. Do your fitting homework well and I suggest only buying what you can easily return for credit or refund. Andy
AndrewRStewart
AndrewRStewart
canhazhelp
Bicycle Mechanics
0
06-24-19 03:42 PM
bbxwxpyu
Hybrid Bicycles
5
08-20-15 06:08 PM
