Tenacious stem
#76
Quoted: 977 Post(s)
Liked 1,638 Times
#77
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1233 Post(s)
Liked 3,574 Times
ConnoisseurEqua how'd it go?
There were 135 Confentes, but only one...Huffente!
#79
Quoted: 3464 Post(s)
Liked 2,831 Times
It's an extra long stem. It goes all the way in. The nut must be 40cm long. Most of it comes out.
I've removed the wedge nut. No change.
I've removed the headset locknut. Removed all bearings for access. No change.
It could be as you said the wedge catching on something but can't see what.
from time to time the expander distorts the steerer, that will result in the situation you describe. I would use Kroil.
in this case you might have to assemble a wood fixture to support the inverted frame/ fork by the crown on each side, whack the stem from the underside near the steerer.
when you are done, good chance the stem will show damage adjacent to the expander and be removed from service.
#80
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
With that long assed stem, why didn't anyone suggest taking the adjuster cone off of the top of that fork and drop the fork enough to inspect the steerer tube? I have a feeling that it's either mushroomed as suggested by Kurt or the steerer is split below the threads.
