Swapping a fork
Toyota Racing Dev.
Bikes: 2004 Kona Hoss Dee-Lux
Swapping a fork
So from my understanding swapping a fork isn't all too difficult. I take off that top cap, remove my stem so that the top of the fork is free to move. Take off the spacers, pull the fork out, and basically just stuff the new one in there and put everything back on, is that the basic concept? Is there anything i should be aware of it's a 1.125" threadless headset.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Toyota Racing Dev.
what is the race thinger? the steerer tube is cut and there is already that bolt in the tube.
Bikes: Lemond Alpe d´Huez, Scott Sub 10, homemade mtb, Radlbauer adler (old city bike), Dahon impulse (folder with 20 inch wheels), haibike eq xduro
the bottom crown race is the circular ring shaped bearing surface that sits on the crown of the fork. When you put the new fork on you have to slide it down the fork tube and seat it on the new fork. There are special tools for mounting and demounting the crown race. Maybe you can improvise if you havent´t got them.
see https://www.parktool.com/repair_help/...readless.shtml
only the dead have seen the end of mass motorized stupidity
Plato
(well if he was alive today he would have written it)
Plato
Giggity giggity!
Bikes: Yeti DJ Custom build. X.9, Marzocchi, RaceFace, Gamut, DT, Truvativ, Michelin, Hope.
Just go to your LBS and ask them to show you how. Maybe give them 10 bucks for their time. The tool isnt really worth buying if you only use it once or twice. You can always tap it up with a screwdriver and hammer, but that can damage the race.
Bikes: 8 bikes - one for each day of the week!
I use a pine block and nylon mallet for installing races. You're better off having a shop install it though, as it only has to be a little uneven to ruin your headset.
Plato
Plato
Giggity giggity!
The biggest issue is getting it off undamaged, which is probably easier to do with the tool.
I use the pine block/nylon mallet for removal as well. But it's very important to properly seat the race so that your bearings sit flush. Same for threaded forks.
Toyota Racing Dev.
I think just due to my lack of confidence I'll have my LBS show me how to or someone who has done it before.
I use a piece of pvc pipe with to instal the race. the pipe alone will work fine for 1" but I had to make a little wooden "donut" of sorts to use with the pvc pipe for it to work for 1.125". and maybe a bigger piece of pvc pipe, I'm not sure. and a vice that was very carefully set with the jaws just the right width apart to remove. you could put some tape on the jaws to add a little protection.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Originally Posted by operator
Uh.. does this apply to threaded forks?
