Reliable patch brand? I have vulcanizing glue already.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
a good seal won't break outside the tire and I want to make sure the seal is good before I reuse that tube. I do em in batches and leave them inflated all overnight to make sure they don't slow leak. Occasionally I'll get one that leaks or I find another hole in the tube
It's difficult to cut through all the noise (especially here) -- it takes some effort. First drill down into sources like MSDSs for the cement to find whether substances like cyclohexyl-n-ethylamine are present or not. Then research can reveal uses of those substances like "cross-linking accelerator." Ultimately you may find dissertations detailing the use and mechanism of cold vulcanization. More importantly you'll know which cements have accelerators (Rema) and which don't (Slime). [Note: MSDSs are not authoritative as they don't list all ingredients. Look for older versions.]
Those who have good filters learn to ignore unqualified voices extolling things like Crazy Glue and Elmer's, and rely more on qualified research and empiricism.
Stuart Black
Stuart Black
Liked 4,217 Times
made a thread about a patch leaking...
I was suggested to instead use cold vulcanizing glue instead of the $0.75 cents mini glue tubes from china ebay sellers.
I bought a $16 can of Rema vulcanizing specially made for tubes.
I needed to patch a tube the other day. I did everything 'to a t' from how patching is suggested. I clamped the patch and left it overnight. I might have put a tad bit too much glue but probably not. I didn't glob it on or anything.
Anyway, what seems to happen is the cheap patches I have are peeling. I inflated it and can see the edges of the orange rubbery layer of the patch starting to pull apart from both the tube and from the black top layer of the patch. I think it might have something to do with also that this was a hard puncture to patch - it was two close together and both were on two different seams of the tube. I sanded the seams down but they were still bumped out a little. I figured the better vulcanizing glue would help. But I also just think these cheap orange and black patches are to blame. It seems as though once inflated they pull apart.
These are the patches similar: Both the circle and rectangle ones I have:
https://www.ebay.com/itm/48-Weldtite...from=R40&rt=nc
What's a good brand of just patches? I only need patches I have glue. I don't want to waste money on a kit. Can you please link from ebay a good deal on just quality patches? Thanks
Stuart Black
Stuart Black
Quoted: 1572 Post(s)
Liked 643 Times
I'm frequently surprised at the things other posters claim to do when patching inner tubes.
I'm just to the point of using up the last of the generic patch kits that I had left over when I closed my bike shop 18 years ago. All that I ever do is to follow the instructions on the package ("let the 'glue' dry for 5 minutes") except that I do use a wood clamp on the tube for a period of time.
I'm confident enough that I don't even QC my patching jobs. I just toss the patched tube back into my spares box. Never had a failure.
Likes For Retro Grouch:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Quoted: 1975 Post(s)
Liked 232 Times
How much pressure are you putting in them for these tests? If it's a very small/low amount, I guess I could see it, but it just seems like these patches were never intended to work on their own, out in the open, outside the tire. We all know what happens to tubes if you try to pump them up to a decent pressure outside of a tire...
Yea usually at least an hour or two passes, since I usually patch in batches of 8-12 and by the time I finish the last one and clean up and throw away all the foil etc they're dry.
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,377 Times
Whenever I was there, the tube failed at some point other than the patch. This video is intended for the wider car tubes, but the same principles apply.
The burst test is done at about 4 minutes into the video.
Liked 4,217 Times
peeling at the sides? Mine did this. Now I apply the glue, let it dry. Inflate the tube just till it’s round and Touch the center of the patch on to the puncture. Then inflate a little more and press the sides down. Putting a patch on the round tube like that works better for me than putting in on flat and then inflating.
Stuart Black
Stuart Black
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Liked 4,217 Times
Stuart Black
Stuart Black
Quoted: 7348 Post(s)
Liked 2,465 Times
More trouble than it's worth. They invented cold vulcanization as an improvement over hot patches. And that was many decades ago.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,403 Times
I was hoping not to indicate my old age by mentioning that when I was a kid, hot patches were all we used. Came with a little tin dealie that sat on top of the patch, and you lit it with a match.
Quoted: 1607 Post(s)
Liked 2,216 Times
I once fixed 14 flat tires in two weeks on our car when we lived in India. Got really good at fixing flats. Often used the hot patches in that time period too.
My experience with both Park and Performance patches is dismal. Rema is the only solution that works for me.
Liked 2,465 Times
It's not a bad idea, though I generally don't. I might have sprinkled some baking soda on a time or two. I have that in the household but not chalk.
Quoted: 2604 Post(s)
Liked 1,928 Times
No chalk dust, but I do dust the tubes with talc (or is it cornstarch?) before I roll them up for storage after patching. Of course, the glue is usually pretty dry by the time I get around to that step (I do my patching in batches).
Liked 2,465 Times
talc is a (soft) mineral, not a plant product.
Quoted: 31 Post(s)
Liked 10 Times
One important difference between Rema patches and its imitators is that the Rema's clear layer is cellophane not plastic.
If you look very carefully at a Rema patch, you will notice there's a score mark going in one direction. I'll locate the score mark, while waiting for the vulcanizing fluid to dry. I'll then fold the patch along the score line. This will cause the cellophane to partially split open.
When the vulcanizing fluid is completely dry, I'll remove the foil and apply the patch - holding the patch by the corner of the cellophane layer. I'll also orient the partially open slit to be perpendicular with the long circumference of the tube. I'll burnish the patch from inside out with the rounded edge of a Rema patch kit box.
Once the patch is firmly adhered, I'll grip the patch with both hands between my thumbs and index fingers on either side of the slit. When I pull my hands apart, the slit opens further splits apart. This leaves the patch on the tube with 2 pieces of cellophane on top of the patch. I can then "roll" each cellophane piece off from the center to the edge. The cellophane removal from center to edge never tries to lift off the new patch.
Quoted: 897 Post(s)
Liked 9 Times
I have never found any brand of cold patches that worked as well. I even suspect that the ingredients of the patching fluid has changed over the years, these days I can't get cold patches to stick for crap. My memory is that they stuck much better 15-20 years ago.
Liked 2,465 Times
@Colnago Mixte, you're doing something wrong. Today's patches work just fine.
Quoted: 897 Post(s)
Liked 9 Times
My research shows the hot patch smell is considered toxic...and it is banned by the UN.
I also struggled with cold patches in the past, when I used generic multipurpose patches.
But recent bicycle patch kit from Walmart is working pretty well.
People in poor parts of the world seems to prefer hot patch...no doubt it is cheaper, simpler and more effective...just not healthy.
Cold patches are a hit-or-miss. There's also different type of rubber...that might have something to do with why some of my cold patches didn't stick.
Mind you, I live in California, home of the mandatory cancer warning on every product sold. Where most paint sold at stores is now useless and won't stick to anything. Where the entire cleaning aisle at the supermarket is full of useless cleaning products after all of the effective chemicals used in them have been banned in the state.
It would not surprise me in the least to find that effective patch glue chemicals have been banned here too.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I honestly think the chemicals have changed in some patch glues.
Liked 4,217 Times
As for hot patches, I think people use them because that's what their daddy used. A hot patch isn't "better", it's just that they don't know of a different method.
Another mistake that people make is to be too stingy with the vulcanizing fluid. As far as I can determine, the accelerator isn't a catalyst, it is an active participant in the reaction and, as such, is consumed. If you have too little vulcanizing fluid on the tube, the reaction is starved and doesn't form enough bonds to be permanent.
Still another mistake that I see all the time, is that people aren't careful about handling the patch. Don't touch the orange bit on a Rema patch! Oils from your fingers interfere with the reaction and the bond isn't as strong. When you peel the foil, hold the patch by the plastic covering the patch.
Much of what you say about paints and cleansers is true, for varying reasons. But the dominant cross-linking accelerators are neither on the prop 65 list, nor banned by USOSHA because they are deemed non-toxic. Thus they also don't appear on recent MSDSs which makes it difficult to confirm which cements use them. Any cement that claims, on the container label, to have cross-linking accelerators almost certainly does.
I also tell people to not inflate the tire after patching to "check" their work. This pulls at the edges of the patch before it has had time to cure and weakens the bond.
Stuart Black
Stuart Black
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,427 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,427 Times
What Park kit is giving you trouble? I get good success from Park VP-1 (VP=Vulcanizing Patches) -- I won't touch those glueless patches (aka stickers)
I've used all kinds of patches over the last few years but I always seem to come back to Rema. They seem to last the longest. I used their brand of vulcanizing fluid also. I think it's a good idea to use the same brand fluid as patch. On the road though I carry both Park self-sticky patches and Rema. I have a small Rema patch kit that I throw two Park patches in as well as the Park self-sticky tire boot patch. The later came in handy a few years ago when I blew out a tire.
