Best chain cleaning tool?
Stevoo
Gatorade bottle(s) and chain quickie link. Great chain cleaning tool(s). No need to overthink it.
Had to replace jockey and idler wheels on people's bikes because they used fancy on bike cleaner machines. They seem to wash the lube out of the pulleys really well and if water based cleaner was used the rust forms in the bushing / bearing. Just be aware.
Good luck
Good luck
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Best?
https://www.safety-kleen.com/ Its a service pump circulated over the tank, then the solvent is recyclrd by the company ..
Auto Shops are theit primary customers ..
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I don't think you need "the best" chain cleaner, just "good enough". Anti-chain cleaner guys are always saying how it really doesn't help extend life of chain or whatever. Really all I want is... not filthy... and easy to use.
Quoted: 4559 Post(s)
Liked 2,802 Times
This. Switch to wax/paraffin. Or something like Smoove.
Couplafew bucks for five bars a box.
Little Dipper, free with my big crock pot.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Stuart Black
Stuart Black
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
or.. in theory yes, in practice yes?
https://store.kmcchain.us/p/missinglink-11r-reusable
Advocatus Diaboli
Liked 1,532 Times
Liked 4,217 Times
Stuart Black
Stuart Black
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
The explanation is that (outer) plate material is thicker with lower speed chain, so any damage when dis/connecting a quick link still leaves enough material to hold securely.
Have I re-used the "many speed" ones? Yes, it was fine. Would I recommend it? Only with a warning that it's at one's own risk.
Advocatus Diaboli
Liked 1,532 Times
https://store.kmcchain.us/p/missinglink-10r?pp=8
https://store.kmcchain.us/p/missinglink-9r?pp=8
I've noticed that most quick links for up to 8 speeds are "officially" (by manufacturer recommendation) OK to be reused, while 9-10-11-12 are more often recommended to be used only once.
Quoted: 3375 Post(s)
Liked 5,513 Times
A jar with a lid and 1/4 of kerosene. Dump in chain, wait 5 minutes, shake for 1 minute, Pick out and dry chain.
Liked 4,217 Times
..pun intended, here's a couple more links.. I'm not sure where you get your info? This is from a manufacturer's site.
Stuart Black
Stuart Black
Mostly harmless ™
Liked 216 Times
I think the simple answer is really, eg. for KMC anyway, that they sell both Reusable and Non-Reusable variants. Read the product descriptions for the answer.
Bikes: See Signature...
Quoted: 9 Post(s)
I remove chain, put in jar with mineral spirits, shake a bit, let soak, shake more, then pull out and wipe clean. Sometimes a second jar with clean mineral spirits is used.
I'm probably going to switch to simple green. A bit more environmentally friendly, and the smell isn't as toxic
Liked 4,217 Times
Finally, the “smell” isn’t what is toxic. It’s the components. Deodorized mineral spirits contains hydrocarbons which have a low toxicity. Use gloves, of course, but you should use gloves when handling Simple Green as well.
Stuart Black
Stuart Black
I'm new to cycling but have been around chains most of my life in the ag field. Just what does a top of the line chain for a bike cost? Just an outside perspective but keeping a chain clean and lubed will save the cassette and crank set. But taking a chain off and soaking in solvent seems like a pile of work.
Non omnino gravis
You can expedite the process, too-- right after you clean the chain, swizzle a magnet around in the bottle, and sit in surprise at how much of that crud is metal.
Collect it in a recycled glass jar with at lid and let it sit still, and you can reuse the solvent several times. In the end you should dispose of it at your city collection place. Ppl tend to forget they shouldn't dispose of simple green in the drain either, if its contaminated with oil.
