Wahoo speed sensor won't fit
Old 06-08-19, 11:17 PM
u235
u235's Avatar
Quoted: 437 Post(s)
Liked 133 Times in 86 Posts
I have new wheels, the hub center section is too narrow and too fat to fit the Wahoo speed sensor. They are straight pull with a larger ends. Any alternatives BT or ant+ or a way to mount it sideways (90 degrees)? In theory I could find a larger strap and kind of strap in on at an angle maybe.
u235 is offline
Old 06-09-19, 05:30 AM
ChinookTx
Bikes: Lynskey GR270
Quoted: 115 Post(s)
Liked 69 Times in 49 Posts
Clearly you need new wheels. ;-)
I can't help with a solution only to say I noticed my garmin sensor very barely fit on my set of wheels as well. I don't know if changing the orientation of the sensor will mess the readings, but it's worth a try.
If you could find that mounting bit, maybe it would fit?
https://www.amazon.co.uk/Velocompute.../dp/B00WFMK1TG
ChinookTx is offline
Old 06-11-19, 12:28 PM
John_V
John_V's Avatar
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times in 85 Posts
Originally Posted by u235
..... Any alternatives BT or ant+ or a way to mount it sideways (90 degrees)? .....
Only alternative I can think of is to use a combination speed/cadence sensor on the chain stay. You may want to compare your Wahoo to a Garmin sensor and see if it's any narrower but in either case, it's going to cost you extra bucks. Not sure how you would mount the sensor vertically or even if it works in that position.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Old 06-18-19, 01:35 PM
ymee
Quoted: 25 Post(s)
I had the same problem but installed them at an angle, works just fine.
ymee is offline
Old 06-18-19, 02:48 PM
u235
u235's Avatar
Quoted: 437 Post(s)
I ended up doing the same, used a longer rubber strap from something else and it sits a little funny but so far so good.
u235 is offline
Old 06-18-19, 05:46 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Liked 244 Times in 181 Posts
Did you try both hubs?
JohnJ80 is offline
Old 06-19-19, 09:17 PM
u235
u235's Avatar
Quoted: 437 Post(s)
I did. The back was worse.
u235 is offline
Bezalel
Tandem Cycling
59
09-17-16 10:46 AM
scarleton
24
09-15-16 12:28 PM
palmgreens
14
05-13-16 10:33 AM
metalheart44
1
04-28-15 02:49 PM
rho
Road Cycling
12
01-08-13 07:25 AM
