70 Super Course
70 Super Course
So I have a pretty good idea of what complete bikes are worth but I'm always a bit up in the air when it comes to frames. Add on top of that a pretty sloppy repair at the downtube/headtube. I'm at a loss, Ebay? Craigslist? Or should I build it up even if I don't have era correct parts?
Quoted: 604 Post(s)
Liked 1,063 Times
I recently paid 150.00 for a 1978 Supercourse frame, it was nos, never built up. Your’s would be considerably less, even with some of the components on it. I would repair the frame, paint it, and build it up, but that’s just me.
Tim
Tim
incazzare.
I guess it depends on your market, but I think in good condition in NYC I could get $100 for the frame. As it is? I'd hope for $75 or so... Might not get it. Part it out and you'll make more.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
To me that bad repair job kills it, it is a $10 frame. The rest of the parts, check eBay. Brake $5, bars $10, brake levers $15, crank give away.
Quoted: 887 Post(s)
Liked 335 Times
^^^^ What bwilli88 said. Ten dollars on a very good day; I wouldn't take it from the trash except for parts.
Quoted: 5888 Post(s)
Liked 3,471 Times
Quoted: 3811 Post(s)
Liked 3,336 Times
The repair appears someone tried to float some brass in there without doing adequate preparation.
Joint looks like it needs a sandblast so frame builder can see what they are doing wrt making a proper job of it...
Fittings - IIRC the 1970 model was still coming through with the Freres Huret Luxe gear ensemble.
If it were really a 1970 model would not the headplate be anniversary?
Quoted: 4511 Post(s)
Liked 6,378 Times
Now iffin you was @gugie and decided it was to be saved, you could fix it yourself and eat the repair for yourself, but you would likely have a couple of good ones hanging around already so.......
Quoted: 790 Post(s)
Liked 1,761 Times
I'm with the zero value crowd I just would not spend time & money to build this bike up you can do a lot better and this is from a guy who typically builds up free salvage bikes.
Shp4man
Classic & Vintage
26
09-11-16 06:25 PM
JonRinehart
17
08-01-10 01:32 PM
