Bottom bracket
Bottom bracket
I have some noise ,clicks, in the area of my bottom bracket.there is a tiny amount of play when i jiggle the crank at certain spots.None at different points .Is the bb finished ?
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
From my experience, yes. The clicking is likely bearings and the wobble (in my case) got progressively worse on my Trek 800 Sport till I put it in the shop.
Quoted: 6193 Post(s)
Liked 4,808 Times
Might could just adjust the bearings. I'd disassemble it, clean, lube and reassemble and see what it does with properly adjusted bearings. It is the old style bb with spindle, bearings and cups.... right?
Depending on what you are seeing and how much, a little play is not too terrible a thing.
I'm assuming the bb is for an old trek 330 since that's you tag. But it'd really help if you gave some more info on what it is.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
That you have play at some spots but not others suggests that the bottom bracket shell may need facing. This may or may not solve your clicking problem.
Quoted: 4201 Post(s)
Liked 3,857 Times
I love this, we don't know hardly anything yet. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2026 Post(s)
Liked 1,096 Times
BB is listed as Truvativ ISIS splined axle.I tightened all crank screws and I'll see if that helps tomorrow.
Liked 4,808 Times
If it's a cartridge bb and you are certain that's where the noise is, then replace it. If you aren't doing any rides that demands that the bike function perfectly, or if the clicks don't drive you nuts just wait till it's a real problem.
However bb's are fairly inexpensive. So don't fret too long before deciding one way or the other.
