Bottom Bracket Spindle Length
Overacting because I can
Bikes: Merlin Agilis, Trek 1500
Is see BB spindles being listed in various widths. If I want to swap a triple crank to a double, which is listed with, e.g., 10mm narrower spindle. Do I have to buy the narrower spindle or can I put something like washers in there. Or does it even matter?
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
Quoted: 1572 Post(s)
Liked 643 Times
Get the right size bottom bracket.
If you don't the crankset is going to stick out too far. That will upset your chainline and cause chain noise in some gear combinations. It'll also cause chain rub on your front derailleur, maybe make the front shifting screwy. It'll also look goofy.
