DIY Bottom Bracket Tool
MichelleMachete
Location: Oakland, CA, San Jose CA, (Future) Portland OR
Bikes: old ass Peugot and a Surley Long Haul Trucker
So I'm trying to make a BB tool. Anyone know the pitch and the diameter of a crank bolt?
Bikes: 1983 Dawes Galaxy, 2006 Raleigh Airlite, 1982 Sun Solo (fixed)
what you mean by BB tool?
Crank Puller?
Lockring tool?
Crank Puller?
Lockring tool?
A group for all Dawes Galaxy owners to give and recieve information about them
https://flickr.com/groups/dawes_galaxy/
i jam my thumbs up and back into the tubes. this way i can point my fingers straight out in front to split the wind and attain an even more aero profile, and the usual fixed gear - zen - connectedness feeling through the drivetrain is multiplied ten fold because my thumbs become one with the tubing.
Bikes: Schwinn Traveler Fixie, Fuji Berkley commuter, Specialized Sirrus road rig, ++ many more
Are you referring to cup and cone style bottom brackets? Sheldon made a fixed cup removal tool. Otherwise, it's easier (and cheaper) to just buy the correct wrench, etc.
https://sheldonbrown.com/tooltips/bbcups.html
MichelleMachete
Simple question what's the pitch and diameter of a crank bolt. I know what a crank puller is I know how to remove various bottom brackets. If you don't know, I don't need you 2 cents.
Quoted: 29 Post(s)
why don't you take a crank bolt run it up your nose; maybe then you tell the pitch and diameter.
I don't know what it is lately in this forum; but more and more posters don't have clue about common courtesy or decency. You try to help someone and all they can do is turn into a jerk.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Speaking of cranks...
Today, I believe my jurisdiction ends here...
iPwn.
Location: Sackville (School)/Saint John, New Brunswick, Canada
Bikes: 2004 Norco Wolverine (Blue) set up with Semi-Slicks. Mid-1970's Raleigh, converted to single seed, (soon to be) all white.
measure it yourself.
if you have the skills/resources to make a tool, then you should be able to measure pitch and dia.
Perineal Pressurized
Let's start:
Search #1 - Crank Bolt Bicycle
Search #2 - M8 Pitch Diameter
Which might lead you to this: https://www.engineersedge.com/hardwar...ead-sizes1.htm
You should really learn to use the gray matter between the ears.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Quoted: 273 Post(s)
Liked 10 Times
Let's start:
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Let's start:
Wait a minute ... Michelle is asking about the crank BOLT, not the inside circumference of the crank arm which is where the BB tool or crank remover would go.
Maybe the idea is a spindle tool to do something with the spindle, since the crank bolt goes into the crank spindle. ???
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Je crois que Michelle est une doosh.
It's more fun to shame then to scold.
Bikes: Grifter BSA 20
the crank bolts arent M8
I tried an M8 bolt in there on Monday...there too coarse a thread.
Might be the same as wheel axles. Which are British standard Cycle thread...shortened to BSCY.
You get bottom bracket tools that screw into the bb axle
One is on order at work. Its £60.
For removing BB cartridges.
The M8 is the standard for traditional square tapered bottom brackets. You don't say what the particular bottom bracket is that you've got.
Call me The Breeze
My, my don't we have our knickers in a knot? A pitch gauge and a common micrometer would be nice to own wouldn't it?
My two cents? You have no idea what you are doing and can't even take the time to make a simple measurement that any one that has ever held a mike could do in five seconds.
Neither rain, snow...
He or she never claimed to be an "incredible tool maker", they just decided to be a little less nice than what we all expect of others here.
It's not worth it to make it more of an issue, this thread is already at three pages, more than half of which is derisive crap we've tried to stop twice by redirecting it to useful information. We've probably already driven them away from contributing anything of value.
Suggestion: Maybe the thread should be locked, and the OP can try asking again, this time a little nicer.
About the original question, I'd agree that the OP would do better to borrow a gauge/mic. and measure a few samples of bolts themselves if our information is not satisfactory.
8mm
I think DannoXYZ has the answer.
8mm with thread pitch of 1mm fits.
It is the first time I've looked at BikeForums and I hope it becomes the sort of place where you can ask simple questions without getting lots of sarcastic replies.
7mm bolts
7mm bolts:
DannoXYZ, I guess you found https://www.northlandfasteners.com/ca...tricBolt_1.htm for a hex head.
In the uk we've got 7mm socket cap bolts in 25 & 45mm but we had to get them from Taiwan.
Last edited by nimroduk; 06-23-09 at 03:32 AM. Reason: clarification, added title line
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
