Eddy Merckx? Need help with identification!
Bikes: Schwinn ss/fg, Charge Plug 1
Quoted: 12 Post(s)
Hi all, this is a recent find and it's great, but I don't know what year or model? any help would be greatly appreciated.
It has some different EM decals that are peeling badly, some yellow colored decorative etches in the lugs and the only numbers are the '56' near the bottom bracket.
It has a ttt stem and bars, stronglite crankset, campy shifters and deraillers, ruggieri seatpost, gipiemme dropouts, no cable guide braze-ons and a set of water bottle bosses.
it came with a set of nisi wheels on ofmega hubs.
Any info,
comments or questions would be great, thanks!
Any info,
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Not a Merckx-made Eddy.
He licensed his name to several companies, including Kessels, before starting his own bike factory in 1980.
This is one of the 'lesser' Merckx bikes, which seem to be making a comeback in value. Clearly needs a lot of work.
Quoted: 12 Post(s)
come on people, there's gotta be some Merckx aficionados out there!? it looks like some Kessels but i still haven't found any similiar lug designs..
any other knowledge would be appreciated!
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Kessels with stem and seatpost too high!
Looks like a lower price range Kessels made in Belgium. An amateur racing model. Kessels focused on performance style bikes. They made a range from gas pipe specials to top of the line pro models. They were well known for their sporting ride and handling qualities.
Merckx rode Kessels built frames from 1971 to 1976 but not exclusively. He also rode frames made by Colnago and DeRosa plus maybe some other builders during those years too.
Kessels was one of 6+ bike manufacturers that Merckx licensed to use his name.
The Campy knock off Gipiemme dropouts place it to around the mid 70's or later. No telling what kind of tubing it's made of. Maybe Reynolds 531 main tubes with lesser quality forks and stays???
A Reynolds 531 frame would normally take a 27.2mm or 27mm seatpost.
56 is the frame size = 56cm.
Here's an interesting story about Kessels bikes in this Flickr link. Scroll down to see the whole thing.
https://www.flickr.com/groups/145944...7624706263918/
It has a "dog's breakfast" mixture of components.
The stem and seat post are DANGEROUSLY high.
They should be inserted at least 75mm to 80mm (3"+) into the steerer and seat tube!
If you need them that high, you should look for a larger sized frame or bike!!!!
Riding a bike set up like yours is a good way to meet interesting new people like orthodontists, plastic surgeons, neurologists, orthopedic surgeons and physical therapists. Do a Google search on stem failure.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
52psi
Quoted: 790 Post(s)
Liked 802 Times
Stem is pretty tall. Looking at the where the fluting ends on the seat post I'd say it's probably just fine.
Cool find.
Cool find.
Quoted: 1627 Post(s)
Liked 630 Times
And the doggy's breakfast of parts (except the wheels) might even be all original; they all seem to be low-medium grade 1970s parts that a Kessel or another Merckx licensee might use to build such a bike. The wheels are definitely a lot newer than the rest of the bike.
@bpford, if you end up surplussing that saddle, I'd be interested.
Quoted: 12 Post(s)
Thanks all, great info!
the seat post is fine, plenty of metal in metal,
i will adjust the stem as it's 1/4" above the 'max' line
i'm thinking it's reynolds 531 tubing comparing it to other similiar frames..
Lascaux, pm me about the saddle, thx
Quoted: 12 Post(s)
btw, the seatpost diameter is 26.2, is that of significance in identifying the tubing type?
verk says the norm for 531 is 27 or 27.2..
and i think the stem may be seized, any hints on a solution other than ride till i die??
heelloo i find in this days something similar whit the seatpost 26.2 but different decals
the seatpost is ruggeri
shifters and deraillers campagnolo and nisi wheels
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I would guess maybe metric tubing if it's 531 (main 3 or better), could be plain gauge metric 531. Yes the lug cutouts are unique,the BB shell is clearly welded across the bottom. Taken as a whole looks "mid-grade" DOH! this is a 2 year old thread! @Vera, you'll need to make 9 more posts and then you can show us some pix!
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Possibly irrelevant data point:
I've seen this lugset combined with Gipiemme drops once before, on a frame claimed to be a Torpado but never substantiated as such. Other than the lugs and dropouts, there isn't anything on this frame that is the same as the OP's Eddy - especially the incongruous BB - but perhaps still worthy of mention:
-Kurt
-Kurt
Quoted: 233 Post(s)
Liked 396 Times
Blue Merckx: this is a production for the company Velosport (Bologna), it has been granted a licence for Italy to stick anything on two wheels in the colour "Merckx"...
The blue frame: The "Torpado" usually had rhombus-shaped lugs cut-outs.
Both frames could have been produced in the same factory (Velosport also "produced" Colnago Sport).
Orange frame: Eurocicli - the name of several different shops in Italy, I don't know if it has anything to do with "Merckx", except for stickers - I don't think so...
Translated with www.DeepL.com/Translator (free version)
Likes For CyclesMakaron:
Also I think that is not a merckx or Kessel, maybe some fan of merckx only put the stickers, but have good components, nisi wheels, shifters and deraillers campagnolo, breaks wander, crankset nervar from France
maybe you can help with a year maybe 70 ???
Also no have cable guide, a seatpost is Ruggeri
Thanks so much for all the info
Gesteve
10
04-30-19 01:29 PM
JoeBro16
Classic & Vintage
59
10-11-14 11:09 AM
