LHT Rear Deraileur Hangar fixed or bolted on ?
Old 11-04-19, 10:30 AM
jambon
Quoted: 104 Post(s)
Hi ,
Quick Question. I can't make this out from online images; Is the rear deraileur hangar on a LHT part of the frame or is it bolted in position ?
Thanks ,
J
jambon is offline
Old 11-04-19, 10:37 AM
Tourist in MSN
Quoted: 3450 Post(s)
Liked 1,449 Times in 1,130 Posts
The hanger was part of the 2004 LHT frame I had.
They have changed their frames a few times, so I can't comment on newer ones.
Tourist in MSN is online now
Old 11-04-19, 11:51 AM
Quoted: 18391 Post(s)
Liked 15,465 Times in 7,306 Posts
My 2011 is integrated.
Old 11-04-19, 12:15 PM
3speed
Quoted: 363 Post(s)
Liked 28 Times in 22 Posts
The current disk trucker on their website sure looks like it's part of the frame as far as I can tell. Crazy. Even cheap box store bikes often have replaceable hangars these days...
3speed is offline
Old 11-04-19, 12:47 PM
Doug64
Doug64's Avatar
Quoted: 1182 Post(s)
Liked 833 Times in 435 Posts
There is not much need for replacable rear derailleur hangers on a steel frame. Unlike aluminum frames, the hanger on a steel frame can be bent back into alignment. It is my understanding with aluminum frames and breaking the deraileur hangers is that the hanger is designed to fail before causing damage to the main frame. I've only had it happen once when my chain broke causing the rear derailleur to go into the spokes. The hanger did what it was supposed to do and cleanly broke off.
We have three LHTs in our family, the newest is about 2010, and all have integrated rear derailleur hangers.
Doug64 is offline
Old 11-04-19, 01:05 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
Originally Posted by jambon
Hi ...
As Doug and others have stated, the derailleur hanger on steel frames is part of the frame, and not bolt-on/replaceable because they can be bent back into proper position in the unlikely event of damage. If you bend an aluminum derailleur hanger and try to straighten it, it may break/snap off, which is why Al frames nowadays always have a replaceable derailleur hanger.
Technically speaking, on steel frames the derailleur hanger is part of the driveside dropout, which is welded to the stays and thus part of the frame. Here are some good images of Surly LHT (your browser may permit additional image enlargement).
seeker333 is offline
Old 11-04-19, 01:48 PM
I nearly destroyed the hanger of my first LHT. It got bent when I fell onto the bike in my house. Wet floor. Super heavy messenger bag. Some adult beverages involved. Yadda. Yadda. Yadda. That was during the winter. Bike was still rideable. But with crappy weather, I didn't take it out much. Decided to wait until spring to get it fixed. Totally forgot. Took the bike out one nice spring morning and decided to ride up a steep hill in the lowest gear to see just how low it felt. (I had done mostly flat riding until then.)
The minute I shifted into the granny I heard the disturbing sound of my RD aspolding and knew exactly what I had done: Shifted the RD cage into the spokes. The cage disintegrated and the body, along with the hanger, had been twisted up. I had to skateboard and then walk home. Fortunately, I was maybe 3 miles from my house. Amazingly, the LBS where I had bought the bike was able to straighten the hanger, and the hole was no so ovalized that it would not accept the new RD screw.
Old 11-04-19, 01:53 PM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times in 329 Posts
Disagree with the "not much need" statement, based on personal experience.
There are modern production steel frames now that have replaceable hangers and personally I will never again buy one with a fixed hanger.
The only caveat is this was on a gravel bike and I thrash my gear pretty soundly. On a road bike or touring bike it might not be such a risk.
ksryder is offline
Old 11-04-19, 08:58 PM
DropBarFan
Quoted: 671 Post(s)
Liked 49 Times in 43 Posts
I had a Disc Trucker repainted & neglected to tap out the derailleur hanger threads & damaged some of them installing the derailleur (looked square & didn't apply excessive force). Luckily after visit to LBS it still worked good enough, otherwise would be a more difficult repair.
DropBarFan is offline
Old 11-04-19, 09:28 PM
rifraf
Bikes: Surly Ogre, Extrawheel Trailer
Quoted: 122 Post(s)
Liked 34 Times in 30 Posts
Surly have been making the LHT and its disk iteration for some time now.
I'm sure if they thought it was a bad idea they would have offered up a removable one by now.
With what I think is for the most part, worldwide distribution (they have sold excretement-loads of them), its suggests terminal frame issues aren't too common.
rifraf is offline
Likes For rifraf:
Old 11-05-19, 01:38 PM
3speed
Quoted: 363 Post(s)
My steel frame bike has a removable hanger. Steel frame or not, there's no reason not to have a removable hanger, as far as I know, other than cost. I don't think there are any drawbacks to a replaceable hanger. There are drawbacks to an integrated one. They're not always fixable when they get bent badly. Threads can still get stripped, pulled out when the derailer tries to free itself in a crash, etc.
That's that's really giving the benefit of the doubt and pretending they aren't a corporation. Surly, (grumpily, as you might guess by their name) does plenty of things that they defend as "correct" without actually being right. So does every company. It's called profit. I'm not even arguing right or wrong on the derailer thing. I'm just saying that the fact that they haven't changed it has Nothing to do with whether or not they think it would be better to have it integrated or removable. It's a lot cheaper to have it integrated.
3speed is offline
Old 11-05-19, 08:44 PM
DropBarFan
Quoted: 671 Post(s)
Truckers are fairly expensive for a production steel frame & since touring bikes are vulnerable to damage during transport, for instance, the replaceable hanger would be cheap insurance IMO. Bilenky says $150+ to braze on new der hanger.
Old 11-05-19, 09:08 PM
3speed
Quoted: 363 Post(s)
That's the thing, though. They're fairly expensive for what they are. So they make a nice profit off of each one sold. That helps you take up the slack on the ones that get damaged during shipping, and is cheaper on the production line and less labor cost.
3speed is offline
