Pain on outside of right foot over time
I would love some help to see what adjustment to make with my cleat on this one. Left food is without issue, no fatigue or paint. The right foot, about 30-45 min into the ride, I start to develop some pain and fatigue in the outside of the foot from the arch to around the 5th metatarsal. I am sure the answer is complex but where should I start as far as moving the cleat? Any other areas I should look at for cause?
www.mp-aviation.com
www.mp-aviation.com
Most likely causes are, not enough arch support and cleat placement. I'd start by adjusting your cleat...rotate it so that your heel is pointed more inward (towards the frame), and make sure it isn't too far back from the ball of your foot.
If that feels better, but still not great, then add more arch support.
I have high arches so that might be it. I didn't even think about doing insoles but that is probably gonna be the ticket. I will adjust the cleat so the heel goes more inward a bit and try again.
www.mp-aviation.com
www.mp-aviation.com
Arch support is real game changer, once you get it right. Specialized insoles have worked well for me, and are cheap enough that you can experiment with them, without breaking the bank. They come in three different heights
You might benefit from cleat wedges. I use one on my left cleat only, even with my custom cycling shoes with custom footbeds.
Google bikefit cleat wedges.
Likes For DaveSSS:
So I bought the green and blue Specialized footbeds to try. I rode today for about an hour with the green inserts and no pain, so that’s good, but I did an easier ride today. Gonna off day tomorrow then really ride on Tuesday with the blue inserts to check those out.
www.mp-aviation.com
www.mp-aviation.com
Same issue and fix for me as well (so far)- arch support is a life changer.
If you can't get a hold of the specialized brand supports, Superfeet carbon are a good alternative, though designed for flatter feet, it provided my monstrosity of an arch with adequate support to rid of any hot spots or discomfort I'd traditionally get cresting over the 3-4 hour mark.
Couple worthwhile considerations beyond arch support;
1. Pedal washers: uncompensated forefoot varus positioning, which is very common, will ultimately place more pressure down on the outer edge of the foot. A quick trick to compensate, though unlikely to 'rid' of the problem completely, is by widening your stance with a washer or two.
2. Saddle height: too high? Maybe you're extending the hot spot side to compensate for the additional reach.
www.mp-aviation.com
www.mp-aviation.com
I still suggest cleat shims. There should be written articles on why they work. In your case the, the thick side will be on the inside of the right cleat, just opposite of what you might think. My left foot tilts down on the inside, causing my speedplay cleat wire to rub on the pedal spindle. One shim with the thick side on the outside of the cleat cures that problem.
https://blog.bikefit.com/bicycle-cle...compatability/
www.mp-aviation.com
www.mp-aviation.com
I have cleat shims on the way but I think ultimately, I was sitting too high. I lowered the seat considerably over the course of 3 rides until today, ultimately doing a half century ride today so I spent several hours on the bike. No outside foot pain!
www.mp-aviation.com
www.mp-aviation.com
My rule of thumb for saddle height is your heel should be able to drop 1-3cm below horizontal, with the leg fully extended at the bottom of the stroke. That's a fairly large range, but if the heel won't even reach horizontal, it will force a fairly radical heels up pedaling position.
Awesome news, thrilled to hear it helped!
