Need help for my wife and her sore tailbone.
Quoted: 681 Post(s)
Liked 949 Times
my wife has not ridden a bike for 30+ years and she is blink on back of our new tandem. her tailbone was hurting a lot after the 20 minute test ride. the saddle that came with the bike is a normal size but pretty soft. I put this saddle on with a kinect suspension seat post https://www.selleroyal.com/en/optica-moderate-man
I am not sure how she is sitting maybe she is sitting too far forward? I am not sure where to go on this. I just bought her some padded shorts to try today but I don't think that will help on the tailbone issue. I am thinking of moving the saddle a bit forward but I don't know for sure.
just another gosling
Quoted: 3907 Post(s)
Liked 1,956 Times
Try a Selle Italia Diva saddle and set her up to lean much more forward. Maybe move her saddle back and shorten the stoker stem. With pedals horizontal, drop a plumb bob from the bony protuberance below her knee. It should intersect the center of her pedal axle. She should definitely be leaning forward. ~45° torso angle is normal for road cyclists, but stoker compartments are usually too short to manage that. IOW, get her off her tailbone.
Results matter
Results matter
Quoted: 681 Post(s)
Liked 949 Times
yes not a lot of room. here is a a pic of what we have. I can rotate the bars forward and put a stubby stem on it. I want to try that before a new saddle.
Quoted: 6256 Post(s)
Liked 4,858 Times
If it actually is/was her coccyx that was hurting, then I'd think she is either sitting too upright and possibly on the wrong part of the saddle. Especially if saddle like in picture.
So saddle height, fore/aft and even tilt need to be considered. as well as bar reach if you have control of that.
Otherwise, even I have a few issues with saddle pain when I get back to riding after taking the winter off. Usually after two or three weeks and a dozen rides it becomes an issue of the past.
You can always play the swap saddle game, but every time I did it or others I knew, they eventually wound up with a saddle not too different than what came on the bike. If you are only doing one hour or less rides, an old style saddle with big seat and springs might help. But those will typically be murder on long rides.
Liked 1,956 Times
So start by getting her saddle more or less level. With the bike on a level surface, adjust the tilt so that the forward, say 3/4 of the saddle is level, a gap under the level of 1/8"-1/4".
Then adjust her saddle fore-and-aft as I suggested above.
After doing that, set saddle height by having her put her heels on the pedals and rotate them backwards which you hold the bike upright. Adjust saddle height so that her leg comes completely straight at the bottom of the pedal circle, but without reaching for it by tilting her pelvis. When she pedals normally with the ball of her foot on the pedal, saddle height should be about right.
After doing all that, take a ride and see if she thinks her saddle tilt should be adjusted differently.
Good to see couples getting out on a tandem. Our team age is 145.
Results matter
Results matter
Quoted: 4844 Post(s)
Liked 3,970 Times
BTDT. I broke mine 30 years ago and did not get the surgery so it is still unattached. I have to ride saddles that do not press on it. (Not a major issue on the hoods or drops but sitting up to ride no-hands - a real part of both my spiritual journey and reason for riding - meant real pain the rest of that ride and often for another day or more.)
I look for saddles with either a grove or a."V" shaped cutout. (Like your saddle. The Specialized saddles of 10-20 years ago with their full length grooves work well. (They are still going so I haven't looked at the newer ones.) Terry Flys also work very well for me.
fooferdoggie, nice photo of the bike and your wife, but not helpful at all. We cannot see any of the important stuff. (No, I don't want to see your wife, but her seat would tell us a lot.)
There are a lot of choices out there now that have tailbone friendly shapes. Enough that finding the one that also works for the rest of her should be quite possible.
Ben
Ben
Quoted: 681 Post(s)
Liked 949 Times
I will take better pics tonight I was at work when I thought to ask. I bought a new stem its a cheap fix for sure. I will see if I can have it facing forward too. I want to try this over new saddles as thats hard to do when you cant even check them out in person right now.
Quoted: 681 Post(s)
Liked 949 Times
thanks for all of the advice.I forgot to take a before pic but here is the after pic. wife tailbone was fine though its still sore its going to take a few days to get better. but she really enjoyed the ride and we did 8.5 miles today. a record for her me its not even half of my commute (G)
Quoted: 3450 Post(s)
Liked 420 Times
My experience of cycling very seasonally is that at the start of each season I always suffer from some tailbone pain for a while and would like a really soft saddle to start with. After the miles build up I'm fine with a hard saddle again.
Soft saddles help initially yet you can suffer from numbness after too many miles as you sink into the soft saddle and cut off blood supply. Harder saddles prevent you from sinking into them and cutting off blood supply yet they do also bruise you until you get used to them.
Liked 1,956 Times
Results matter
Results matter
Quoted: 681 Post(s)
Liked 949 Times
