Fit Question high end gravel bike - hands asleep
I need some advice. I got back into biking a few years ago. I really prefer packed gravel trails. I started with a Surly Straggler (still own and like) and have since graduated to a Lauf True grit (race) and just recently purchased a full custom built Salsa Beargrease (also owned a Ice cream truck and Mukluk). I love fat bikes. My main question and concern is when I ride my Lauf my hands always go to sleep and I suffer from elbow pain. I’ve been fit now by 2 different high end fitters and they have changed a lot of components and fit of The bike and still things go numb and I’m uncomfortable and ride in some pain. I thought maybe this was just the way it was until I got the Beargrease and can go for miles and miles and have zero discomfort. I feel great on this bike.
So my question is is it me or is the Lauf geometry just not made for me? Is there a better fitting (all carbon) bike that others would recommend that would maybe for closer to the Beargrease. I realize I’m comparing a gravel bike to a fat bike but I thought id ask. I wasn’t sure if maybe the Lauf geometry was to aggressive or want but I’d like to find a gravel bike as comfortable as my Salsa Beargrease. Thanks
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The Beargrease's geometry is much more in line with a mountain bike's, so maybe look in that direction. Lots of folks use 29er hardtails for gravel riding, with or without drop bars.
Quoted: 101 Post(s)
Liked 41 Times
Surprising that the Straggler works for you but not the Lauf. You didn’t mention sizes, but comparing (for example) the 58cm Straggler and the Size L Lauf shows similar stack/reach/ett:
https://geometrygeeks.bike/compare/l...00c-2019-58cm/
I guess it’s possible that your sizes don’t match as close, but if they do, I’d take a hard look at other fit details like stem height/length, handlebars, etc. Its amazing how little it takes to make numb hands…slight adjustments can put more pressure in the wrong spot on your palms and make a huge difference. I had some numbness with my current bike that mostly went away with different handlebars…but I then put those old bars on a different bike where they don’t seem to be a problem.
Likes For wheelsmcgee:
I do suffer it a little with the Straggler (large) but not near as bad as I do with the Lauf.
3 miles in on the Lauf and both hands are pretty much asleep and like I said I done several fittings and stem, and cockpit changes.
I’m trying to figure out if it’s just to aggressive of a setup for me. I should add that I do have pretty severe chronic epicondylitis in my elbows because of my profession but again I don’t suffer any issues on my Beargrease.
Im hoping to find a similar cock pit set I’m as my Beargrease in a carbon gravel bike. Hoping that exists.
Likes For Gravel50:
Expired Member
Quoted: 3736 Post(s)
Liked 5,604 Times
You can look at geometry charts online, compare with your Beargrease. And yes, if the Lauf is uncomfortable, sell it and try something else.
Thanknuih for you hell and advice everyone. I do have a question when looking at the geometry charts online for bikes. With my issues I’m having what are the main ones (angles and measurements) I should be looking for to try and match the BG?
Thank you for the help and advice everyone. I do have a question when looking at the geometry charts online for bikes. With my issues I’m having what are the main ones (angles and measurements) I should be looking for to try and match the BG?
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
You may want to consider drop bars that have flatter top sections where your hands are most of the time and also try thicker bar tape.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Try this.
- Stand up
- crouch down as low as you are comfortable
- put your hands out in front of you with your forearms parallel to the ground and your elbows in front of your knees.
Personally, I have found that shortening the reach (i.e. changing the handlebar stem) can do wonders in this area. If my reach is too long, I put weight on my hands and sooner or later something goes numb.
Guest
Liked 3,270 Times
Maybe, but I was thinking something along the lines of an actual mountain bike. Geometry-wise, the Beargrease has more in common with, say, a Timberjack.
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
I'd go back to the bike fitters and get them to help you fix it. If you want to a fitter to address an issue and they didn't get it right, they need to try again.
I agree that you cannot equate reach and stack on a Beargrease with flat bars and any gravel bike with drop bars. My gravel and fat bikes both fit me fine - reach on the gravel bike is 375; on my Beargrease 426.
Quoted: 83 Post(s)
Liked 64 Times
See your fitter. Carefully measure seat setback between the bikes. I might guess your Beargrease saddle might be set more aft. When that's set on your other bike, then adjust your stem reach. If one bike feels great, you should be able to adjust the fit of others to match it.
Likes For veloz:
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
I have a True Grit race and it is pretty aggressive for a gravel bike. I have mine set up with a similar bar to saddle drop as my road bike with just a slightly shorter reach. It comes with a pretty short stem already, so my guess is to get a little more upright, you would need a stem with some rise on it, but probably don't have much room to shorten the reach.
I definitely think it is a fit/position issue. The Lauf with the fork and smoothie handlebar (and wider tires) is way more comfortable on my wrists and hands on long rides than my cross bike with a similar set up.
Quoted: 581 Post(s)
Liked 921 Times
Excess pressure and numbness of the hands is often caused by saddle adjustment, esp. having the saddle tilted nose-down, sometimes even just by a little bit. This allows your weight to slide forward and you experience excessive load on your hands and arms to stop yourself from sliding forward.
Likes For ClydeClydeson:
Quoted: 2333 Post(s)
Liked 2,097 Times
Just get a recumbent or trike and all pain will be eliminated.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Except the pain your ego suffers every time one of your former two wheeled friends sees you on it…
But, you’re not wrong. I have a good friend who switched to a recumbent trike about 10 years ago after he developed carpal tunnel severe enough that riding a double triangle road bike became impossible.
Likes For Badger6:
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
I suffered excess pressure on my hands for years, even making the handlebar stem shorter and shorter, until I realised the seatpost on my dropbar bike had zero offset - I didn't think this was important, but I slammed the saddle back as far as I could and the pressure on my hands was more manageable. Its crazy what 20mm seat offset does to your riding position!
Liked 415 Times
...It comes with a pretty short stem already, so my guess is to get a little more upright, you would need a stem with some rise on it, but probably don't have much room to shorten the reach.
The reason why raising the handlebar height often actually makes things worse is this isn't taken into account.
Thank you everyone for all of the help and advice. Very much appreciated
Things that I have tried are... 2 complete bike fittings (one being the RETUL), changed the stem out twice. I now have a very short and upright stem (my fitter says I can't go anymore upright or shorter), Double wrapped my bars with salsa gel tape, done multiple seat changes and adjustments and a few other things. I just cant seem to get used to the aggressive geometry of the Lauf. I love the bike jut can't seem to get used to the geometry.
I've been considering maybe looking at another bike style for gravel riding. Maybe the Salsa Cutthroat?
I'm just not sure what to do besides try a different bike at this point. My hands are completely asleep at mile 3 and about every 1-2 miles I'm having to shake them out.
Sounds like your fitter hasn't heard of a riser drop bar.
Here's the most extreme carbon example out there:- https://bikerumor.com/eb17-3-new-bik...venture-trail/
https://alexscycle.com/collections/v...rbon-handlebar
As mentioned, you'd want to first start by ensuring your saddle height and setback position is near/exact your Beargrease. Level saddle also.
Then you dial in the front end.
That Lauf frame is quite long and aggressive for its design. Hopefully you didn't purchase a frame that is just too long for modding the fit.
On a typical flatbar your hands will be out wider than a dropbar, so when trying to achieve a similar 'reach' on a dropbar [at the hoods] you want to keep a similar distance/arc when swinging in your arm reach to a narrower dropbar.
You may be able to achieve this position using a moderately short stem on the Lauf, in combo with that rather short reach [and tall stack] Veno bar.
There are a few other carbon bars out there with much lower stack, but none have as short reach as the Borderless from Japan.
The Veno bar is quite expensive but way cheaper than a whole new carbon bike/frameset, if you ARE able to achieve the fit you're chasing with such a bar or similar.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,297 Times
This will be the last time I post this picture, I promise
if you look closely at the bars on the muddy one and the mountain bike you’ll notice not only do they have a bit of rise they also have a touch of sweep. I love these bars (Redshift Kitchen Sink) which is why they’re on the two bikes I ride the most, maybe give them a try.
Liked 415 Times
I have a super stiff front end on my bike, but I don't really notice it because I don't have any weight on my hands. If you have a strong core, you could keep the short stem but have it very low. That will take your weight off your hands, but it does require you to be athletic (note how many pros look like their knees are going to hit their elbows).
From what you are describing, you need a different frame. Try "renting" a bike from your LBS and going for a long ride. That may give you a way to feel out what you need. That is what I tend to do before making a big purchase (they often apply the rental to the cost of the bike if you buy).
Quoted: 2432 Post(s)
Liked 641 Times
I get numb fingertips only when I'm grabbing the brake hoods and only with modern Shimano STI's with hidden shift cables, not with anything else. Must be the design that my hands don't like
