US-Based Teflon PTFE Powder for Mixing with Paraffin - Runway Stands Alone as of Now
Quoted: 97 Post(s)
Liked 7 Times
I am not affiliated or involved in any business related to cycling or anything that can be construed as relevant to this post. I am just a nerdy tech kind of person with some information, some beliefs. If it is right, then it is valuable. If it is wrong, or requires any level of context or correction, that is what this thread is for. I am not trying to prove anything. I am trying to find the truth best for my chain and power train on the bike I love.
I am sure people have all sorts of preferences, but if you are looking for the least friction possible that last for more than a handful of miles, you cannot do better than paraffin plus teflon (ptfe) powder. I am basing this on the years of research reported by Oz Cycling's YouTube videos, combined with what I can discern from https://zerofrictioncycling.com.au/. I have seen discussion of these sources here on BikeForums, but what I have not seen is discussion of Oz's Claim: is it true or false? Another thing I have not seen is a clear statement on where in the United States the right kind of teflon powder is available.
Oz says ten parts paraffin plus one part ptfe powder is the ultimate lube, and makes the case it is the best bar none. TRUE?
He says the teflon powder will clump together if the particles are too big, and says 1.6 microns works perfectly. Unfortunately, he does not say whether 1.7 microns is too big or whether all the particles have to be 1.6 microns or whether a mix of particle sizes averaging to 1.6 is what he is talking about. I suspect the case is he obtained some ptfe powder sold as 1.6 micron particle size, because that is a size that happens to be available. Sooooooooooooooooooooooo,
I have looked into this and discovered exactly zero US-based suppliers of "1.6 micron teflon powder". HOWEVER, I found that US-based Runaway Bike provides teflon powder that works perfectly. Here is the explanation from their website:
We had a recent customer claim that our product was between 2 and 3 microns in size. We are comfortable with that nice round estimate, but you should know that it's not quite so straightforward. A large percentage of our particles are actually less than 1.5 microns in size. The mean particle size is probably somewhere in-between.
I have everything in hand to start running paraffin plus teflon per Oz's recommendations. I will let you know what I learn from it.
The main reasons I am going for this:
- Extends life of chain from 1k-2k miles to 9k miles.
- Extends life of cogs and crankset to 27,000 miles
- Transforms the grunge factory that is my chain with normal lube to sparking clean all the time.
Quoted: 1814 Post(s)
Liked 923 Times
PTFE does not break down, and so will continue to accumulate in the environment forever- it's in your blood.
Consider whether spreading it around in your chain wax is a good idea.
At 570˚ + it gives off very toxic fumes, so don't burn or overheat that wax.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Quoted: 641 Post(s)
Liked 1,517 Times
I'm no expert on chain wax or lube but I do work in an industry that uses a lot of high tech plastics including teflon; mostly PFA and PTFE. The one thing that bothers me about using teflon for any application involving moving parts is that the material is really soft and abrades very easily. In my industry we call it the plastic we love to hate because it's fantastic for it's purity, resistance to high temperatures, and being virtually non-reactive with all the nasty chemicals we use but it's also a pain to machine to tight tolerances, has a very high thermal expansion factor, and just generally has horrid mechanical properties. We would never use it in an application where it was required to constantly rub against something. Perhaps it's different when you're dealing with particles.
I think a better material would be UHMWPE (Ultra high molecular weight polyethylene). Like teflon, it's really slick but it's considerably harder and less likely to break down. If you look at a assembly line conveyer and see guides where the conveyer changes direction, those are likely made of UHMW. It's also way less expensive.
Likes For Ogsarg:
Quoted: 97 Post(s)
Liked 7 Times
My last chain was dead at 2,000 miles. LBS says he changes his chain about every month. Maybe that is to promote chains, I don't know. Shelby Brown did a nice job explaining the religion of chain maintenance, emphasizing a wide range of lifespans.
What would you say is a valid life expectancy for chains?
Likes For danallen:
Quoted: 97 Post(s)
Liked 7 Times
What is the amount of waste put into the environment by a bicycle compared to a home furnace, air conditioner, automobile for home computer? We have a lot of substances in our bodies from the environment. Teflon is inert unless it is heated to over 500 degrees.
What lubrication is better for the environment? How big is the impact?
I am going to evaluate this seriously. Thank you for bringing it up.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Likes For znomit:
Quoted: 97 Post(s)
Liked 7 Times
Quoted: 97 Post(s)
Liked 7 Times
How many miles do you get out of chains?
When I got 2,000 miles out of a chain, I was oiling that chain all the time. I guess it needed more frequent cleaning, but the cleaning seems like no match for the amount of black crud that gets into the chain immediately. I was using sythetic motor oil (10%) mixed with mineral spirits (90%). Before that, I used dry lube, but it still got nasty black on any use whatsoever. Was I doing something wrong?
Quoted: 406 Post(s)
Liked 389 Times
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
I was interested in this until I saw the post about the environmental factors. I'll pass.
More to the point -- you should easily get 5-10,000 miles out of your chain if you keep everything clean and lubed. If not, you are either not maintaining it properly, using low quality chains, have something else dramatically wrong with your drivetrain, or -- most likely -- are replacing perfectly good chains for no reason.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
And motor oil contains detergents, which are emulsifiers. It's not meant for an external application exposed to the weather. I'd you're gonna pick some random lube that isn't specifically formulated for bike chains, how about gear oil or chainsaw oil.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
The mineral spirits is to lower the viscosity of the mixture for application, allowing the motor oil to penetrate better and to reduce the amount of oil left behind. The mineral spirits evaporates leaving a thinner coating of oil than if straight oil were used. I've been using this method for years and have found it to be clean and long lasting. Independent tests have shown this method to be among the best performers for friction at a fraction of the cost of similar performing lubes.
bike whisperer
Liked 716 Times
Okay, fair enough. But motor oil is widely regarded as a poor choice.
Likes For Kimmo:
Quoted: 760 Post(s)
Liked 1,717 Times
I started using squirt recently and it is biodegradable. works great and keeps my drive train nice and clean. As I live in the southeast rain can be an issue, so I just clean out the gook that might get picked up and then re-apply. Otherwise I reapply as needed, generally 150 to 200 miles has been my experience.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
NACT - Not another chain thread was an expression that i used to use around here.
I still love how even now so many weird assertions and near religious beliefs people can throw around about chains.
OP - PTFE is nasty stuff. Does a great job but.... Let me put it this way: at some point I am sure I will have to pay some sort of exorbitant fee to have all of the compounds in my business that contain PTFE removed as hazardous waste. It can build up in the body over time as well. That said - chain lube - knock yourself out.
Chains:
- Mileage on a chain is so specific to a rider it's a near meaningless number outside of comparisons to a particular rider's other chains
- Too many other factors can impact chain life outside of lubricant
- Maintenance or cleaning and reapplication of lubricant to a chain can have a much larger impact on wear of the chain than any single lubricant will.
- Too many people use an elongation measurement or wear of rollers measurement as their only indication of when a chain has worn out. I am finding more and more modern drivetrains are having poor performance when the chain being used develops a lot of lateral flex even when the overall roller wear or elongation is still well within acceptable limits.
- Chains are cheap. Swap your chain. I have lost track of the number of times that a simple chain swap has been the permanent solution to a myriad of afflictions bothering a rider.
- Chains are cheap part 2 - Tom Ritchey said it at one point and forgive me if I don't quote it perfectly as I can't find the original quote but when asked about his chain maintenance routine he said he simply puts lube on it and then replaces it when it needs to be replaced. "Life is too short to spend it cleaning chains".
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Quoted: 641 Post(s)
Liked 1,517 Times
In regards to the environment and your health goes, I would not worry one bit about ingesting it or it building up in your body. There is nothing in your body that can break it down. You can put it in full strength sulfuric acid for years and it wont be effected. Inhaling a powder may be an issue in terms of it being an irritant but it's not going to poison you.
Heating it is another issue though as it will give off poisonous fumes. We weld PFA at my company and it has to be done in an enclosed fume hood and the operators wear masks that feed them fresh air. Keep in mind though that the melting point of PTFE is over 600F so not easy to do that at home and why they suggest not leaving a teflon coated pan on the stove with the burner on and nothing in it.
If not heated excessively, it's probably a lot less damaging to the environment than most plastics.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Teflon is extremely toxic to birds.
Quoted: 551 Post(s)
Liked 722 Times
Have you tried snake oil? From USA snakes, not those inferior Australian snakes, of course.
Likes For znomit:
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times
I don’t clean chains. I did it for years and consider it a dirty job, capital waste of time and effort, and an unjustified use of toxic materials. Maybe my chains don’t last as long now, but it’s not an obvious effect and I haven’t seen any objective evidence that any cleaning regimen prolongs chain life.
I have three bikes with 430, 415, and 405 mm chain stays, respectively. If I only had the bike with the 430 mm length, I’d think chains lasted a long time.
Likes For MoAlpha:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 249 Times
Mixing PTFE into Paraffin wax is NOT a new idea. When I first started racing in 1976 we use to take Slick 50, which back in those days used US-based original Dupont brand Teflon PTFE, and mix that into the melted paraffin wax. Dupont sold off the Slick 50 to some other company, when that happened Dupont pulled the licensing rights from them to prevent them from using Dupont Teflon so another Teflon was used that wasn't near as good as the Dupont brand. My understanding is the reason Dupont sold off Slick 50 was that they discovered that the Teflon particles were ruining turbos, but I could be wrong in the reason, but I think I recall that was the issue. Anyway, the original formulated Slick 50 did seem to work better when blended into melted wax then just plain wax by itself.
Quoted: 850 Post(s)
Liked 344 Times
second point... I think the paraffin flash point is around 400F. So you’d have bigger issues at 570F.
Quoted: 169 Post(s)
Liked 192 Times
