2x11 Gravel Bikes... why?
Living in relatively flat Chicago I find even the stock 11-32 cassette limiting due to the ratio gaps. When I have to choose between two sub-optimal gears - one that will make me grind and the other that will let me spin where I want to - over a long ride the sustainable choice ends up being the one that lets me pedal at the desired cadence. But the penalty for this is that I end up going slower because it's one tooth greater than that ideal missing one.
On a 1x the gaps are even more exaggerated and as a result you end up even slower.
Quoted: 1218 Post(s)
Liked 298 Times
just thinking my double is a 48/36 on a 11-32. Pretty sure I don't wanna do that on my 36-32 low. haha I'd blow my knees
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
50/34 is a terrible chainring combo for gravel, it's also a poor choice for road riding with tires larger than 28mm.
46/36 is good
46/34 is better
44/34 is really nice
44/30 would probably be best but requires something other than the standard 110 bcd so it's generally not worth the tradeoff.
Gravel bikes come in 1x for the same reason mtbs started coming in 2x - crossover of riders from dirt to road and vice versa as well as mechanical limits for derailleurs improving which eliminated the need for smaller chainrings when larger cogs are more efficient and better. I don't think 1x is really holding anyone back on their gravel bikes, it's just another option. I've raced with a ton of guys on 1x and they never seemed to have any issues and always talked about it pretty positively. OTOH I've talked to more than one MTB guy who went from 1x back to 2x because they didn't like it. I dunno probably more local phenomenon than anything else.
46/36 is good
46/34 is better
In the end, you don't have to buy a 1x or a 2x if you don't want to. Everyone has their reasons and I am not one to tell people what they do or don't need. Sucks if the rest of the bike is otherwise perfect for you though. With me knees I don't see myself moving to a 1x anytime soon. It would be cool to not have to swap back and forth up front and I could easily give up some top end for some low end I guess. Both my gravel bike (2x10) and my XC bike (2x11) are about about 2 models years old and 2x was still a popular option back then. I ride a wide variety of terrain and conditions on both bikes and a 1x would work for me 90% of the time but that other 10% makes a difference. I've never had chain dropping issues on either bike. My gravel bike has a Deore MTB derailleur and my XC has a XT shadow with a selectable clutch. Against popular advice, I do in a pinch or a quick struggle use all rear gears in both rings at times (little/little and big/big). When its time for a new bike (no time soon), I'll consider my physical shape, what I plan on doing and all gearing options and decide then.
Bikes: stinner cx, paramount track
Quoted: 262 Post(s)
Liked 9 Times
my 1x cx bike with a 42 in the front and an 11/42 in the back is way more versatile than my “traditional” cx bike with a 46/36 front and a 11/32 in the back.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
I've found the opposite to be true for me, especially when racing through a cross course. The front ring change is many times all I need for many of the obstacles or changes in terrain with a 2x system. So, it's one single lever push on the fd instead of a few in the back.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I agonized over this for a while, but then it came clear:
I need the top end for fast road rides (paceline)
I need tight gearing for general commuting and pacelines (drives my crazy riding into the wind and not having the right gear to keep my speed and cadence up).
I'm the type of guy who would be swapping chain rings out for different rides, and I would rather press a lever than reconfigure the crank.
That, and stomping on a 11t cog isn't a great idea. Really no downside for 2x. Mountain bikers need 1x to be able to reshape (kink) the seat tube and/or for suspension issues. For Road/Gravel, its a fashion statement.
Quoted: 50 Post(s)
I used 50/34 + 11-28 on my cx bike and think it can be good option - if we drive on roads and have a lot of strength. 50T is very very fast, but I thinks it's bad option for "flat".
Now use 46/34 (with the same cassete) and it's much "user friendly", because changing is faster and smooth. I was interesed in 1x11 but think is terrible if we have only one bike - it will never good enough on all surfaces.
Quoted: 101 Post(s)
Liked 41 Times
Despite this, I don’t really see a reason why I need 1x, especially since it doesn’t seem to be appreciably less expensive than 2x, at least with shimano parts.
This. However, if you have enough bikes that you can dedicate one to gravel riding, and the terrain isn’t too hilly, I think it would work. I have a triple on my awol, but due to a front derailer malfunction last year at dk100, I rode 75 miles of that on 39x11-36 (1x9). A few times I wanted lower gears, so 1x11 with a different chainring/cassette to give me a little lower would’ve been great...the spacing wasn’t a problem. On sub-50 mile rides, I could maybe keep an extra chainring handy.
it’s easy enough to get a good range of gears if you know what you need/are capable of.
it's only been recently that someone, SRAM, decided to make a 'from the factory' 1x drivetrain.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Seriously- this hypothetical has to be such a small chance, its more scare tactic than worthwhile consideration.
But hey- trends need to be justified.
Sunshine
Liked 7,474 Times
Regardless, your sarcastic example of a practical action missed the mark.
Sunshine
Liked 7,474 Times
I've seen dozens of riders have front shifting issues during gravel events. "You can just set it to one of your rings and ride" isn't helpful when a failure to shift causes you to get dropped from the pack or have to dismount and run a climb. It's not that it stops working, it's that it stops working reliably.
My made up statistic of .001% of riders needing 1x holds here because in the grand scheme of riders, barely any ride in such extreme and unforgiving conditions.
1x is beneficial for some, absolutely.
It just seems to be spec'd on a lot of bikes because its trendy(or 'faddy'?). Very few need 1x because very few encounter the extreme conditions you mention.
Whenever drivetrains are gunking up, its safe to say that is an outlier in terms of rider participation.
Ive said over and again that if someone likes 1x, then cool. It just seems to be as necessary and useful as 52/11 for most who buy a road bike...which means it isnt.
Quoted: 101 Post(s)
Liked 41 Times
On the plus side of front derailers, I was riding with a friend once who had a rear shift cable break during our ride...result was getting stuck in the tiny cassette cog. Having a 2x meant still having two gears instead of one (very high) gear.
Quoted: 262 Post(s)
Liked 9 Times
why didnt yr friend use his multitool and turn the limit screws on the rear der into a more manageable gear
Liked 298 Times
You'd have to first prove that 1x is a fad or a trend.
Some could argue SS is a trend. Personally I find single speeding practical. yet sometimes I find 1x more practical, and even 2x is practical.
guys that ride 2x, but spend 90% of their time cross chaining.... Uh they are trending the 2x? they obviously don't need a 2x unless its a 44/x mtb 2x , but at that point they might as well move to a 1x setup as it better suits their fitness.
Quoted: 18883 Post(s)
Liked 10,646 Times
Damn... I hope not.
I get that the manufacturers want to sell us a bike for every day of the week, but the right gravel bike could be so versatile with just a wheel swap. For me, the ideal gravel bike would be a 2x11 with room for 44mm tires. Let me swap wheels/tires based on the ride/conditions.
But I agree with you on the 2x thing. I've never once worried about having a FD. "Oh no, I'm going down a hill and I might be able to shift when I need to!! "
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 588 Times
I think the builders went to 1X because they want the room on the bars for seatpost "droppers" which seem to be showing up on gravel bikes???. And they charge more. I agree that triples are no longer required for most riders because of the larger range of rear cogs, but a double costs the same or less and gives you more. You decide.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
