New Twist on Qwik Chain Luber
Quoted: 58 Post(s)
https://www.kickstarter.com/projects...paign=94b61144
It's just a little cloth sponge like disc between two plastic discs. You pull the plastic ones apart, and you lube up the cloth sponge disc. Put them back together, and hold the axis in the center between thumb and finger while the sponge rolls over the chain...while back pedaling.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
Pretty slick, but you wouldn't think there would be a real need for a Kickstarter program for something that simple.
-Matt
-Matt
Quoted: 18424 Post(s)
Liked 15,582 Times
Waste of money and time if you use the best chain lube on the planet--NFS. You only need a few drops for the entire chain. Ergo, a lube-soaked sponge is not needed. But y'all keep doin' what y'all doin'.
Liked 15,582 Times
Maybe the sponge is made of a space-age polymer developed by NASA and thus is extremely expensive. Or maybe they are not confident of success and thus don't want to risk a dime of their own money.
Interocitor Command
By golly, this is IT! They can turn off the Hadron Super Collider now. THIS is the best invention of mankind!
.... their ad states: "More Riding Pleasure" and "No Loss of Performance" --Is this chain lube or a condom?
Likes For PickleRick:
Quoted: 58 Post(s)
You're looking at the readson for Kickstarter the wrong way.
If you have a cheap, little element like that, someone will jump in on the concept with a slightly different twist right away. That means that they capture the potential customers, and if they have the capital for funding the bulk manufacturing, marketing, and distribution while you don't, then you've lost the market, the ship never lands.
So you go on these crowd funding sites, sup up the campaign to get all of the investments and donations to rain down on it...from the crowds...with email blitzes, twitter, fb, etc for a month, pull capital over the side, and go to the next crowd funding site.
First thing is to send those globs of dough to the marketing campaigners, manufacturer, and all of the other rigs and regs that eat money like wildfires, and land the product on as broad of a surface area as financially possible. Turn it over, hold up the revenue as collateral, find further investors and lenders who see collateral, blow up the "make-and-market" project further. Then repeat this until the return on investment starts to contract. By that time the competitor enters with a new twist on the gadget, and you toss the reigns over to who wants to ride it out while, your taking your winnings to the next big thing that you have to go do.
And that's what's going to happen. It could be the people behind this kickstarter gig, or it could be someone else who would have done it if they didn't do it first. But that's what happens to you or with you depending on whether you know how to.
Passista
Quoted: 868 Post(s)
Liked 721 Times
I could make that for free, but I prefer to put my bike on the stand and put 1 drop of oil on each roller. Takes maybe 2 mins more, but it's better IMO.
Likes For Reynolds:
Quoted: 608 Post(s)
Liked 352 Times
They raised almost a $100,000 by almost 2,500 backers so this has to tell you there is a market for it. I wouldn't use it but lots of people would. I hope it is successful for them.
$20 for this innovation? Isn't April 1st over already?
Next time I run out of electrical tape i safe the plastic drum and glue some foam on it.
Likes For HerrKaLeun:
Quoted: 58 Post(s)
You all are right: DIY.
But...the big market of bike commuters in all of the metros and cities world wide...they got no time for making anything like this.
It's see it, buy it, lube it, time saved several fold. That's all it's about; crunching time. And that's the kind of people that get paid, so things like this soak up that pay on a mass scale.
Quoted: 427 Post(s)
Liked 700 Times
A solution for a non-existent problem? And it seems the sponge would soak up some of the lubricant, and perhaps hold onto some of the grime coming off of the chain. No thanks.
Likes For freeranger:
Quoted: 942 Post(s)
Liked 527 Times
I’ve been doing this for a while now. The sponge is just from one of those small sponge paint brushes that you get at your local hardware or dollar store. The point on the tip focuses the lube where it needs to be. Stored in a Altoids tin. Application is simply putting several drops on the tip and running it along the inside of the chain. Sponge is simply stored in the tin. The tin is NOT filled with lube and the sponge is not soaked in lube, or you will end up putting WAY too much lube on. This method actually saves a lot of lube vs. putting a drop link by link and wiping off excess. Coverage is also more uniform and if you do it right there is no excess to wipe off. It’s also way quicker.
Doesn't all that spongy stuff require a lot of lube just to be able to release some? And all the dirt of the chain will be in the foam, so you need to replace it every once a while? I see that creates quite a problem with contaminated waste and more use in lube.
Maybe I shouldn't laugh. I once was gullible enough and bought and used one of those Park tool chain washing machines and cassette floss to clean.... now i just wipe the chain after the ride and put some lube on every once a while...
Quoted: 942 Post(s)
Liked 527 Times
Likes For fietsbob:
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
The second bike I ever owned--the second hand-me-down from my older brother--was a Columbia cruiser, and it had a little chain oiler built into the chain-guard. A little metal reservoir with a flip-top; it fed oil to a felt pad that brushed the top of the chain. No excess, no lack (as long as you topped off the reservoir now and then).
Some very early bikes had fully-enclosed chaincases that had an actual oil bath in the bottom of them, but I think they leaked pretty badly if the bike wasn't upright. Likely problematic for wheel removal, too.
WALSTIB
I think it's pretty neat. And yes I am a sucker for gadgets. Is a little high priced but like said earlier I'm sure cheaper knockoffs soon to follow.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Won't work. You don't lube the outside of the chain but the inside between the pins an rollers by putting drops of lube on the links that get sucked in by capillary action. I don't think that will happen with this device, leading to wear of the pins
Liked 15,582 Times
I am a big city bike commuter (and road rider and loaded tourer) and I see no need to spend time making anything like that and thus no need to spend money on anything like that. Old shirts make perfect chain rags.
Quoted: 58 Post(s)
