New frameset, what is this hose for?
Old 12-01-19, 09:35 AM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 489 Post(s)
Liked 225 Times in 147 Posts
I purchased a 2016, S Works, Tarmac Sl 5 frameset. Brand new, in the box. It came with a box of parts. Some rubber plugs, a optional derailleur hanger, heaset, etc. Also in the box is a piece of rubber hose about 18" long, (edit: .5" diameter with . 25" diameter hole. ) made of like a foam type of rubber. I have everything accounted for except this hose . What is it for? Anyone know?
ls01 is offline
Old 12-01-19, 10:05 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 960 Post(s)
Liked 188 Times in 135 Posts
Originally Posted by ls01 View Post
I purchased a 2016, S Works, Tarmac Sl 5 frameset. Brand new, in the box. It came with a box of parts. Some rubber plugs, a optional derailleur hanger, heaset, etc. Also in the box is a piece of rubber hose about 18" long, made of like a foam type of rubber. I have everything accounted for except this hose . What is it for? Anyone know?
Maybe this is obvious to someone. If not, what is the diameter?
WizardOfBoz is offline
Old 12-01-19, 10:08 AM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 489 Post(s)
Good point, it's about .5" outer , .25" inner. I'll add this to the original post. Thank you
ls01 is offline
Old 12-01-19, 10:36 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2297 Post(s)
Liked 379 Times in 304 Posts
Sounds like some sort of cable casing covering, about the correct ID for a casing to slide into and might be cut for fit. Perhaps tp protect the paint from casing rub? Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 12-01-19, 10:59 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1082 Post(s)
Liked 443 Times in 316 Posts
https://www.specialized.com/us/en/contact-us
dedhed is offline
Likes For dedhed:
Old 12-01-19, 02:46 PM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 489 Post(s)
Just thinking out loud here but, what are the chances it goes inside the frame around the rear brake hose to dampen rattle?
Quite a bit of clatter from the hose just laying inside that space. I believe that's where I'm using it.
ls01 is offline
Old 12-04-19, 05:51 PM
justinschulz9
Bikes: diamondback century 1, cannondale synapse, giant talon, fuji absolute
Quoted: 24 Post(s)
Liked 7 Times in 4 Posts
seems like a ton of hose for a tarmac brake cable.... the weight alone would be something a picky peter would complain about.
justinschulz9 is offline
Old 12-04-19, 06:53 PM
wesmamyke
Quoted: 165 Post(s)
Liked 18 Times in 17 Posts
I would guess it's for replacing cables. Often frames with internal routing come with a length of hose to use as a tool of sorts.
wesmamyke is offline
