Tubeless tires, getting ready for spring
Old 02-19-20, 03:41 PM
ScubaAl
Hello,
Late last summer I picked up a Giant Defy Adv 2. The bike came with tubeless tires, which is something I'm new to. I did have a flat and did the repair, kind of a pain over just replacing a tube, but got the job done.
The bike has been in storage since Nov. and hope to get back on the road sometime in Apr. Is there anything I should do to the tubeless tire before hitting the road, aside from just pumping them up.
Thanks, Al
ScubaAl is offline
Old 02-20-20, 05:36 AM
DOS
DOS's Avatar
Quoted: 230 Post(s)
Liked 48 Times in 37 Posts
What kind of repair did you have to do?
Since tires have been sitting all winter, I would suggest you replace sealant with new.
DOS is offline
Old 02-20-20, 07:59 AM
jadocs
jadocs's Avatar
Quoted: 643 Post(s)
Liked 292 Times in 192 Posts
I would add a bit of sealant to each tire, pump them up and give it a good spin.
jadocs is offline
Old 02-20-20, 09:00 AM
ScubaAl
Thanks for the replies, the repair I had to do, was a patch on the inside of the tire. Then add sealant. Tire had a couple of other small leaks but the sealant sealed them.
Al
ScubaAl is offline
Old 02-20-20, 09:22 AM
jadocs
jadocs's Avatar
Quoted: 643 Post(s)
Al
Good practice for punctures that require a plug or larger than normal.
jadocs is offline
Old 02-20-20, 10:12 AM
katyjcrow
I would remove tires and clean out any old dried up lumps of sealant. Make sure valves are cleaned out. Than reinstall, add new sealent and go.
katyjcrow is offline
Old 02-20-20, 10:23 AM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 831 Post(s)
Liked 67 Times in 49 Posts
Not needed. The old sealant is sealing the leaks. Just remove valve core and add sealant.
Leebo is offline
