Campy 10 sp Ergo rebuild
Quoted: 2604 Post(s)
Liked 1,933 Times
I replaced the g springs on a right side Ergo shifter, probably vintage 2008, and my problem is persisting. Upper gears shift fine, but when I try to downshift below 5th gear (larger cog), I feel a click in the shifter but it doesn't catch, so the derailer falls down to the 5th cog. My guess is that the index gear (part #6 ) is badly worn and needs to be replaced. Can anyone confirm this guess before I drop big bucks on replacing it?
Second question, are there any other parts likely to fail in the next few years?
Finally, is there a good source for the right index gear? I'm tempted to invest in blocks of steel and Dremel bits!
Quoted: 241 Post(s)
Liked 232 Times
Did you just change the G springs, or did you change the G springs and the spring carrier? Typically you change the G springs, carrier, and bushing at the same time. Very common for the spring carrier to crack, and it can sometimes crack in a way that will not allow it to hold on the larger cogs. I'd check for that before changing the index. I've only needed to change 1 index, and on that one there was obvious wear/damage on it.
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 4205 Post(s)
Liked 3,863 Times
Agreed that the spring carrier breaks frequently and can cause the shifter to not hold in the low gears. Index gears tend to last a very long time, one supplier laughingly referenced them as the cockroaches of parts. Having said that I have neded to replace one index gear on a personal bike. Surprisingly it was the LH lever's. I was trying one of the mid 1990s SunTour MtB ft ders with their very strong return springs and the lever wouldn't hold the large ring position when I jumped on the pedals. A replacement (and on other parts) solved that. The only other index gears I've replaced have been to change an 8 speed lever into a 9 speed one (and done this a few times). Andy
AndrewRStewart
AndrewRStewart
Liked 1,933 Times
I had a cracked spring carrier quite a whlie back -- 2006, maybe? Replaced that (one of the earlier alloy ones, IIRC) with a newer composite carrier that was supposed to fix the cracking problem. Are y'all sure the newer carriers are still susceptible to cracking?
Liked 3,863 Times
I've only done a dozen or so Ergo rebuilds for customers (besides the 10 or so of my own) and haven't seen the composite carriers break that I remember. A lot of the early alloy version with no reinforcing web at the post's base and a few later alloy ones with that added reinforcement.
I'd first double check the low gear limit screw on the rear der. If the G spring doesn't fully seat in the index notches then it can slip back. Of course cable tension also affects this. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Post your question on the paceline forum. Old potatoe knows all and does rebuilds.
Did you get that last spring (#19) in the proper orientation. Lord knows, I've put it backwards a number of times.
Edit: BTW I have broken a composite spring carrier.
Quoted: 550 Post(s)
Liked 325 Times
It's a bigger problem with larger cogs because spring tension increases moving up the cassette.
I never wore out an index cam although I lost count of the G-springs and carriers I wore out, broke two thumb button springs, one front paddle return spring, and a front ratchet pawl spring.
Liked 1,933 Times
Thanks for all the inputs. Just for closure or feedback, here's where I am now.
This "bike" (two frames, three bars, etc.) has 60,000 miles and change on it since I changed over to Campy 20 years ago. I've probably averaged changing g springs every 12-18 months in that time. Cracked one carrier, rusted out two thumb buttons, broke a paddle on each side, and changed from "old" 9 index gear to "new" 9. So I opened it up yesterday.
The spring carrier isn't broke, but that composite carrier sure is flexible -- so it needed to be replaced. The indexing ratchet has rounded off three of the gears, and a couple more are visibly worn. My stockpile had an extra carrier as well as a few more years' of g springs. I've got a line on the index gear, but I'll have to see if that pans out.
This is why it's a good thing to have a backup bike!
