What is the film on these fork socks and can I get it off?
Quoted: 837 Post(s)
Liked 1,080 Times
As you can see in the photo, the chrome here has cloudy film covering much of it. Or, is it possible this is actually under the chrome and much of the chrome coating has come off? Is this even a coating?
I haven't tried to get it off yet as I'm not sure the safest way to approach it. Thoughts?
Thanks!
Thanks!
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Not So Clear Anymore?
Thanks!
Thanks!
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Speculation
UV exposure and temperature and oxygen and caustic exhaust fumes and what have you would all contribute to degradation of the clear in the clear coat.
Time itself, takes its toll too.
Quoted: 567 Post(s)
Liked 563 Times
My only Peugeot was a UO-8 from back in the 70s but I don't recall clear on the fork socks, I would have lost a bet that it was there.
If it is under the chrome, it might be nickel. Electroplatings like to stick to nickel and nickel likes to stick to things.
Almost every electroplated item I know of has a flash of nickel in it, typically as the first layer.
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
It's clearcoat. It will come off with fine bronze wool. Every chrome-forked Peugeot I've ever had has it, dating back to the late 60s. Make sure you treat the chrome after with something to protect it.
verktyg
Quoted: 1036 Post(s)
Liked 1,237 Times
Clear Coat
Clear coat was/is applied to protect the finish of the paint and protect the chrome. In the case of the paint, to provide scratch resistance and rust resistance on the chrome plated surfaces. It has a tendency to yellow as it ages depending on a lot of variables.
The clear lacquer used BITD wasn't intended to last more than the bike street life expectancy of 5-10 years.
The clear coat on the chrome on my 1967 Peugeot is starting to crack after 50+ years.
My 1972 Motobecane looked great from a distance when I got it in 2007. On closer exam you can see the "crackalure" forming in the clear coat.
It had been storage for almost 10 years, When I took it out, the clear coat on the chrome had completely deteriorated and the paint completely dull. The right fork blade shows how it looked, the left shows what a few minutes of scraping and fine steel wool did.
I've been using 2000 grit wet or dry paper with water then polish to get the old clear coat off of the painted areas. It's a lot of work. This is half way through the clear coat. You can still see the cracked clear coat. The white stuff is polish.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
PM me your cotters
Liked 588 Times
Ideally? Tape off from the trim line above, prep with a paint prep/residue remover and re-spray with a 2-stage clear like this (but if you're unfamiliar with this type of paint, read the precautions carefully and watch some YouTube videos!!!).
However, if you don't want to re-clear it, you can periodically re-apply a chrome treatment like this. It's pretty easy to work with and I've had respectable (but not as fool-proof as clearcoat) results.
Re-clearing just sucks because every little spec of dust still on the forks if you don't properly prep or take consideration of your environment will show up.\ and drive you bonkers if you're OCD.
PS: Also recommend you to use painters tape when taking the clear off. I normally tape at the gold pinstripe and take it very gently as I approach up towards the tape. Better to use too little pressure than too much pressure with the fine/ultrafine bronze wool. I prefer bronze wool over steel, tends to be less aggressive.
Quoted: 556 Post(s)
Liked 132 Times
I did as Francophile did, on one of my Motos. Tape off at gold paint line, then gently wipe clear coat off with citrus stripper. Came right off.
No need to re coat it with clear. I just wiped down with alcohol or wash with soap and water, dry, then waxed the chrome well.
Thanks!
Thanks!
The reason I ask is because the replacements have the double eyelets on each end and look just like yours do (instead of singles like the original would have had). I was always wondering what they may have come from or been intended for installation on.
Thanks
PM me your cotters
Liked 588 Times
It's a Peugeot pictured. They were chromed up the whole fork and painted all but the socks. Chrome underneath was usually only perfectly smooth in the non-painted areas but "smooth enough" under the painted area. You could technically remove all the paint and have all-chrome forks but where the paint was may look a little orange-peel-ish. If someone did choose a Peugeot fork to replace the one on your Mirage, they may've done just that to remove the identifying decals/unmatching paint.
Several companies like Pyramid made all-chrome replacement forks with lawyer lips and all kinds of other things. They share the same style of triple-point crown used on the lesser-quality bikes of the era.
Thanks for the information! Very interesting. From the looks of these replacements, they were never painted, the finish is consistent down the length of the fork. The crowns do seem to have a higher degree of finish, but I imagine this is to be expected as these were much less likely to be painted.
PM me your cotters
Liked 588 Times
No Lawyer Lips here
Quoted: 837 Post(s)
Liked 1,080 Times
Thanks!
PM me your cotters
Liked 588 Times
If Blue Magic is your preference, I would recommend sticking with what you know and trust. We're just trying to solve for two things here: 1) Polish away imperfections, 2) seal the metal to prevent reactions. How you achieve both is really up to you. Some may prefer a 2-stage ultra-gloss clearcoat, which is a 1-shot long-lasting solution. Others may prefer a product like Blue Magic or the Turtle product linked and re-apply at appropriate intervals.
Quoted: 837 Post(s)
Liked 1,080 Times
I've yet to use Blue Magic, so not sure. The product I linked is what I've been using, it seems to be an ultra-gentle abrasive to polish without cutting. One of my detailer friends recommended it, swears by it, said it contains an agent to neutralize rust, polish to shine, and protect like a wax and that was enough for me to start. I haven't been let down.
