Concept of lefty forks on touring bikes?
Quick opinions survey of the day: is the lefty fork pretty much antithetical to the very concept of the touring bike frame (abundance of possible rack/pannier placements being the primary concern)?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
If you can somehow attach a low-rider to it, you could have one huge front left pannier, which woudl greatly facilitate counter-clockwise touring.
Likes For Cyclist0108:
guess it all depends on your style of touring.
wouldn't work for me to have no spare parts availability and be restricted to proprietary headsets and bearings and hubs and brakes.
there'd gotta be some impressive advantages to having a lefty to justify the price and limitations.
does it actually solve any problems encountered by the average tourist?
Meh. I don't see any huge pluses or minuses for my style of touring. Do you have a particular reason to go that route? If you want to run front panniers it is probably a no go. You can run bar bag, bar rolls, and so on just fine. I am sure the setup is plenty reliable enough. Parts availability? If you are that worried have spare parts at home ready to be mailed/shipped to you in a pinch. If it is what you have and what to use it to tour, why not? If you are choosing a new setup to tour on, why?
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I've never ridden a bike with a Lefty (yet anyways), so no real opinion on that. Other than a lack of mounting options, as already mentioned, but that might not matter. 🤔
Here's my new-to-me Killer V, which not only works out great for riding various terrain, but it's also far easier to mount. 👍
The only drawback, it has a 1 1/4" headset, which is a little unusual, but shouldn't be too big of an issue. Kinda like your Lefty. 🙂
Good luck.
Quoted: 2236 Post(s)
Liked 1,314 Times
A Lefty fork does have a place for certain mtb builds as they are lighter than traditional suspension forks but that would be a stretch of a reason for a touring build where weight isn't such a critical factor. I tour without front saddle bags but even still wouldn't see a need for an expensive design like that ordinarily. Where I might see a desire is for a fast, lightweight, off road bike packing capable bike with suspension - ie. gravel bike with suspension. Fairly niche.
Palmer
Quoted: 1668 Post(s)
Liked 1,820 Times
i read that yes, the fork itself is lighter, but with the heavier bearings and the beefier headset/tube and crown, along with the honking massive hub, that it's actually a wash weight-wise.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
For regular road touring with panniers, you've already addressed its limitation.
Stuart Black
Stuart Black
I have had a Cdale with Lefty and it is one heck of a sus fork. The best I have used for performance riding. Precise, small bump sensitive, and very smooth operating. Virtually no stiction at all. As for touring, it is overkill. Currently there is no good way to attach a front rack to it.
Addressing the hub and axle, I have yet to see one fail. Considering autos have their axles supported on one side, motorcycles have single sided swing arms supporting the rear axle on one side, and formula race cars the same, there is little chance of a failure of the Lefty axle.
Disclaimer, I have been working in a Cdale shop for the past 3 years. Before that it was 30 years in a Specialized shop. Have seen a lot of fork failures, almost all of them, at least 99%, due to lack of maintenance or really, really big hits.
Quoted: 671 Post(s)
Liked 49 Times
I’d like to see a drop-bar suspension touring bike, if I had money to blow I’d ask custom builders if they’d make one.
Heavier by .5 to 1 kg but narrower lighter tires would negate some of that & higher tire pressure would give lower rolling resistance.
No front rack mounts but perhaps a builder could weld rack mounts to the fork or make a custom rack
Overkill for road touring on smooth roads but much more comfort & some increased safety & speed on the rough roads, bumpy sidewalks or trails that one might commonly encounter.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Quoted: 671 Post(s)
Liked 49 Times
You mean like a hybrid or German trekking bike? I've tried drop bars on a MTB & the handling is not ideal esp for those who like a more aero position. Also there's no suspension forks with rack mounts AFAIK A bit ironic considering some carbon forks have rack mounts.
https://www.amazon.com/Minoura-MT-40.../dp/B00FHV0Q92
Liked 4,218 Times
you can add a front rack to a suspension fork, either to the brake studs or with clamps. this one gots lowrider mounts and a platform.
Stuart Black
Stuart Black
Palmer
Liked 1,820 Times
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Today Lefty forks are better engineered...they used to be max ASTM condition 2 AKA 6" drops or less (think less than a regulation road-curb in the USA). Problem being everyone treated them like XC equipment....result was lots and lots of people were surprised when they broke prematurely after being abused by people who didn't know they were abusing them.
These days Cannonwhale engineers them to Cond 3 I think.
Either way...they don't gain you much for a touring context at all--and introduce hard-to-source proprietary parts where you don't need them.
There was a guy a few years ago on Tour de Nebraska that brought a Bike Friday. I remember it because I was about to leave a convenience store on my bike, he rode in, and his front fork snapped. Was just one of those things. He was fine, but his tour was done. No spare parts within who knows how many hundreds of miles, and for a 5 day organized tour he was done, given time constraints.
Quoted: 671 Post(s)
Liked 49 Times
