A question on bike frame design
Bikes: MGX MTB, Fuji Supreme, Miyata 90 and a Trek 700 in the works
Quoted: 16 Post(s)
In the old days bike frames had a slim down tube.
Bikes still worked as expected and I am not aware of bikes prone to fail at down tubes due to tube diameter.
Then why most newer bikes are built with very large diameter or flattened profile down tubes?
Is the added rigidity etc. really that beneficial over the slim tube down tube?
I find the fat down tubes really ugly.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Today we use lighter materials which require thicker walls and bigger tubes to have the same strength/rigidity. Steel did not need that.
actually things happened with how and where things got made like steel to aluminum ,
and manufacturing went overseas..
the Taiwan Contract companies spent their Profits on making things better and faster, for less ,
and the brand importers took advantage of those techniques, sending designs there ..
Hydroforming as a way to shape frame tubes , is fairly recent , in the Bike Frame making. It works especially well in Aluminum .
There's a school of thought in bike design that a stiffer frame will enhance power transfer from human to road. The larger junction at the BB/DT join isn't so much for structural reasons of keeping the bike together, but mainly to stiffen the frame up.
Quoted: 4209 Post(s)
Liked 3,875 Times
Agree with the above replies but will add the marketing aspect. Bigger is better as started in large number by the ATB bike advent. Very soon ATB bike design led road bike expectations to the masses. As to if the larger diameter or shaped tubes are of real performance advantages- you'll get different arguments from different people. I feel that a bike can be too stiff for efficient long distance riding. Andy.
Quoted: 5791 Post(s)
Liked 2,581 Times
Fashion and marketing are as important as engineering in modern frame design, and the large flattened section of downtubes is a case in point.
Frames already have more than enough rigidity within the plane because of the diamond truss configuration. Tubes with a large cross section in this direction are already is use with single tube frames, such as many folding bikes, and "Y" frame mtn bikes.
If BB or lateral rigidity were the goal the tube section across the plane (fatter crosswise) would be used. In fact, we often see both seat and down tubes flattened in that direction where they meet the BB.
So, one can take a few minutes to eyeball oval or flattened frame tubes, and consider the effects and decide for themselves if it's science or marketing (or often some of both).
FB
Chain-L site
FB
Chain-L site
Quoted: 2026 Post(s)
Liked 1,096 Times
Has the increasing emphasis on stiffness for it's own sake gone too far? Probably so for most riders.
Go Cannondale.......smaller downtubes.
