Official Trek DS owners thread
#1626
Bikes: 2014 Avanti Cadent ERII 2, 2013 Trek DS 8.4, 2008 Norco Wolverine
Quoted: 16 Post(s)
Liked 5 Times
@limbot, what is the actual inflated width on those Kenda Small Block 8s? They look nice on your DS!
Thought it looked pretty good with them on
#1627
Sorry, can't tell you . If you look above at one of my posts, my DS is sadly no more and is a real gravel bike ( under 5 foot of gravel). I'd actually put the OEM LT3s back in for use in Vietnam so still have the Small Block 8s in storage...somewhere.... That picture was with 50psi in them if I remember rightly.
That was a very sad shot of your 8.4, was it up that hill farther or did that **** just flow over the top of it... We can get wet and we can get muddy, but we're flat as flat can be.
#1628
Bikes: Trek DS4
Quoted: 9 Post(s)
Newbie...intro...???
Hi all, I am trying to get back into cycling after being forced to leave due to back injuries 10 years ago. After reading a lot about Hybrid's here I got pumped and thought that riding rail trails might be a way back into cycling for me. So, I zeroed in on a DS 2 at my LBS, but they didn't have the frame size that I need. Long story short I ended up ordering a DS4 & am expecting delivery sometime this week or next. If all goes well for me...meaning that my back can handle the stress. Is there anything that I should be aware of with the DS4 in particular? Also, I will be transporting my ride to various sections of the Airline Trail in CT 2-3 times/week weather permitting. I thought that rather than tossing my new ride in the back of my F150 that a hitch rack would be good. Boy, have things changed since I left!!! Racks are pretty pricey. Looked at the old standby's....Thule & Yakima...and didn't think that the quality of build matched the prices being asked. Then I bumped into the 1up USA single rack and it looks like the way to go. So, my question now is ....is it worth it to go with the heavier 2" hitch model or is the 1 1/2" to 2" model good enough?
#1629
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
Lots of great bike racks. but if you are only using one bike for the rack, save yourself some money and weight by getting no more than a 2 bike rack. Which means 1 1/4 inch should be fine. You could be flooded with what people like and dislike on racks. Check the racks out within your price range and just get what makes you happy.
My personal opinion, SARIS makes great racks that are not too heavy, well constructed, sturdy and made in U.S.A.
#1630
Bikes: Trek DS4
Quoted: 9 Post(s)
Make sure that you have a great fit with the DS4, your LBS should be able to help you on this. Otherwise it may take a little while for you to figure out how to set the bike up for a good fit.
#1631
Bikes: Trek DS4
Quoted: 9 Post(s)
Thanks for the reply. Originally, I was shopping for an FX3 Disc, but being that I will do very little road riding I though that the DS would be a better option for me. During my LBS visit I rode an FX large frame on a trainer and it quickly became apparent that I needed the XL frame. I am 6'1" 183lbs with a 34" inseam. I took a leap of faith here as I have not even seen a DS4 let alone ridden one. Saris....I checked them out but unless I am missing something they do not have a single bike rack. The 1UP single Quik Rack sells for $300 shipped in silver and seems to be very well built. I also looked at a Kuat Transfer 1 for $220, but have not gotten much feedback on that rack. So many options!!!!!
#1632
Funny now but not so much when it happened.
#1633
Bikes: Trek DS4
Quoted: 9 Post(s)
You'll have a great time on your DS... As for racks, I went the cheap ama**n route for four bikes. Don't do that.... The wife and I have a business that we have to work sometime up to 30 miles away. If I'm ready early enough I take off on my bike and peddle till she catches up with me and then I load the bike on the rack and off we go. I went about ten miles one morning, she caught me, put the Trek 4300 mtb in the rack and away we go. Get to where we're going get out and look back...... No fn bike. The back of the pickup is loaded with work related things so we couldn't see behind us. I traced our route and it was a goner ..... It probably would have been trash anyway.... But it was gone . It's how I ended up with a DS
#1634
This is where sizing is tough...and I like to post actual measurements when available. 2" = 58mm wide, if it's absolutely true to size, but we know that most tires are not true to nominal size. And, frustratingly, even though Schwalbe call it a 29x2, the ERTRO measurement is 50x622 (50mm diameter casing, on 622mm rim). That's very much not a 2" tire, but that's become the norm.
On your specific bike, what is the clearance between the chain stays near where the shoulder (side lugs) of the tread, would be? If it's about 50mm, and you think an actual 51mm tire would be too wide, you could look at any of a number of 47mm tires (they'll be marked 700x47 or 47-622). I know Schwalbe and Continental make a few in this size, plus others as well. Schwalbes are generally pretty true to the ERTRO size (a 50-622 is going to be close to 50mm wide, and a 47-622 is going to be close to 47mm wide), but Continental is often a fair bit smaller even than the ERTRO size. If your actual clearance is about 50mm, then a 45-47mm tire might be good (more selection in 45mm wide probably).
#1635
Quoted: 36 Post(s)
Liked 26 Times
Besides a hitch mount bike rack, maybe try one of these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 or one like it. We have a Honda CR-V that we haul two bikes inside the car. I screwed the mounts onto a board and then secured that board to the car with tie down straps to keep it from sliding around. The rear wheels are simply velcroed down to prevent them from sliding left to right. You'll need to take the front wheel off the bike but that's a pretty easy and fast thing to do. We've hauled them many times over the last 6 months without any issues and I like the fact they're inside the car.
#1636
Bikes: Trek DS4
Quoted: 9 Post(s)
Thanks for the heads up...this would be a great solution for a truck bed carry were it not for my hard tonneau cover. So, I bit the bullet & ordered a 1UP USA single rack.
#1637
Bikes: Trek DS4
Quoted: 9 Post(s)
Bike shop called this afternoon.....my DS4 was ready so I went and picked it up. This was a leap of faith purchase for me and I am happy to report that my first impressions are all good. The only bad thing that I can relate is that 10 years of not riding and this on going growing old problem sent me some not so nice messages! But, I am hoping that I can regain a lot of what I have lost and have some fun at the same time. My last road bike was a Lemond Arrivee and the DS4 is a lot heavier so I thought that the DS4 would feel cumbersome. It actually feels quite nimble unlike the rider, LOL! Hoping for a warm winter!!
#1638
Bikes: Trek DS4
Quoted: 9 Post(s)
Now that story is a cause for pause when thinking about skimping on a rack!!! The more I read and discuss the more convinced I am becoming that the 1UP USA single rack is the way for me to go. First, however, I need to actually get my DS4 and see if I am going to bond with it. With winter coming quickly, my riding time will be quite limited so, it will have to be love at first sight, LOL.
#1642
Bikes: Trek DS4
Quoted: 9 Post(s)
Bikes: Trek DS4
Quoted: 9 Post(s)
Be careful what you ask for, LOL! Just a couple more then showtime. Then I guess I will be posting over on the broken body forum.
#1645
Bikes: Trek DS4
Quoted: 9 Post(s)
Weather isn't cooperating for me...just to cold....less than 30 degrees most days. So, I am ogling my DS4 and have a question on the pedals. It came with some Wellgo platform composite pedals. I have yet to learn how to ride with platform pedals, but one thing caught my eye and that is that these pedals do not have the traction screws (?) like many other pedal systems. They are molded protrusions and it would seem that they are less aggressive that those with the metal screws. Proof will be in the riding of course, but I was just wondering if it really makes that much of a difference.
#1647
Nice bike. And very nice rack I might add.. 🤔
#1648
Bikes: Trek DS4
Quoted: 9 Post(s)
Badger1, that is the Pomfret, CT section of the Airline Trail.....the trail is 54 miles long and the majority of the trail is as nice as this. My way back to fitness!!!
