X-One Allround or G-One Speed?
Bikes: 2018 Focus Mares CX 105 // 1984(?) Guerciotti GLX 7600 Super Record // 2021 Giant Stance 27.5” // 2022 Poseidon Redwood
Quoted: 71 Post(s)
Liked 23 Times
I have a set of Schwalbe X-One Allrounds (33mm) and a set of G-One Speeds (38mm). Anyone know which type is faster on dry gravel and pavement? I checked BicycleRollingResistance.com, but they don’t seem to have numbers for either specific model. Is there another source that has rolling resistance numbers?
Thanks.
Thanks.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I've read some German magazines, and oddly the all-round is slightly faster, although the difference is small enough to be negligible. I have both, and can't say the speed is really faster. You could go either way - their performance is similar (other than the obvious off road wet terrain issues with the speed).
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Thanks.
Thanks.
Likes For Toadmeister:
Quoted: 71 Post(s)
Liked 23 Times
Thanks, Chas and Toadmeister. I kept the 38mm G-One Speeds on the main wheelset and the 33mm X-One Allrounds on the winter alloy wheels. But I do think the narrower knobbies feel faster, maybe because they’re lighter, and they do have a good amount of compliance, I guess from the knobs.
Liked 415 Times
Likes For chas58:
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
How do you guys feel the X-One Speed 33c fairs in this group? I'm on 80%+ asphalt and the rest FL hardpack trail stuff. I'm looking to go more unpaved though as I find new riding spots.
Thanks.
Thanks.
Liked 415 Times
X-One is a cyclocross tire. 33mm is kinda small for gravel - like the carcass is the same size as my 32mm road tires. For gravel I like 40mm - although the hardpack we have in the summer I do use 32mm much of the time.
for FL hardpack stuff, it would be great - as long as you don't need flotation of a wider tire. I've owned tires like that in the past and love them. Fast on the straights, allow me to carve into hardpack dirt turns, more forgiving breakaway characteristics than a slick, not as draggy as a knobby.
Disadvantages: Gotta be very smooth when climbing (not a problem for you I guess). Hard cornering is going to be soft on the road (compared to a slick). Not much flotation.
For hard, dry (non muddy) conditions without hard climbing it could be ideal. I probably run 40-60psi in that size range (higher psi than a 40mm tire).
Likes For chas58:
