What RPM are you riding at?
Bike rider
I usually ride around 60-65 rpm doing about 12-13mph cruising. Sometimes if i am in a hurry to get somewhere i usually redline each gear (120rpm) before shifting, how do you ride, do you down shift when coming to a stop?.
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
I try to hold 80+ in the flats. I will let it drop down to the 60s when I am out of the saddle climbing to give the twig and berries a rest. I usually drop 4 gears at a light if I am descending a false flat, else I can typically stay in my current gear because I don't really feel the need to spool up the wheels with much vigor from a red light... I will try to lag long enough that I never stop at the red lights though...
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
95 to 100 seated in the saddle.
Are you asking for real life numbers or BF numbers?
If your asking for BF numbers I spin my 53/12 at 100rpm when I'm climbing
Real life, well those numbers are boring.
Bikes: Cannondale CAAD12, Specialized Rockhopper, Norco Fluid FS1
Quoted: 127 Post(s)
~90-100 rpm at around 17-20 mph on flats, and that drops to like 70-80 when climbing.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
When I started, way back when, my cadence was around 80.
Then I took some spinning classes which helped me increase my cadence.
It is now 85 ... maybe as high as 90 sometimes.
And I shift into an easier gear when I'm coming to a stop, but I'm usually coasting then, just pedaling enough to make the shift.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
90 most of the time. 100 if I am doing intervals. 80 when I feel like "mashing" a big gear.
Generally, the harder the effort, the higher the cadence.
Puttering along the beach or such, a low cadence is ok, because you're not trying to put out efficient power.
Yes, I down shift when coming to a stop. Makes getting started again a lot easier.
Bikes: 15 Fuji Altamira 2.0
Quoted: 26 Post(s)
Average of my last 5 rides is 87, usually max is mid 120's when bombing down a hill. I ride in whatever gear will keep me around 90 as that's where I seem to have the most endurance without burning my leg muscles out too soon.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 410 Times
Couldn't tell for sure, but probably 90-100 most of the time, perhaps 80-90 climbing. Those are just guestimates. I don't have a computer.
95-105, and it's been creeping up to 110-115 at times. Once I got a computer I really started doing higher rpms, though it was probably in the 90 range before.
In Real Life
Bikes: Lots
Liked 596 Times
All you need is a watch and the ability to count.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Giant Defy, Trek FX
Just under 90 for me on the flats, and on the hills it varies. When I want to go fast it seems a bigger gear and slightly slower cadence works best.
Quoted: 2514 Post(s)
Liked 2,995 Times
To answer the question the OP was really asking, for the maximum aerobic benefit from cycling, your cadence should be about the same as your distance running or jogging pace, which is between 90 and 95 strides per minute for pretty much everyone on the planet.
You can deviate from that pace or cadence all you like, but that's the pace evolution has dictated to be the most efficient.
Perceptual Dullard
Quoted: 938 Post(s)
Liked 1,196 Times
Don't worry about what others are riding at. Are you comfortable and able to achieve your goals with how you're riding? If so, keep doing what you're doing. If not, do something different. In isolation from power or crank torque or the terrain you're riding on, cadence is a red herring. Ignore it.
Quoted: 5 Post(s)
Somewhere above 90. I try to maintain it on uphills (shifting as I see the cadence drop to 90). I rarely achieve it during the first 15 minutes of warm-up, though, and there are days where it is noticeably lower.
I ride 90+ like many here, but I don't drop my RPM at all on climbs. (And there's BIG-LONG ones here in Maine). Just have to pull up on the back of the stroke more.
Perceptual Dullard
Quoted: 938 Post(s)
Liked 1,196 Times
Not only is that not true, it's irrelevant. The most efficient cadence (in terms of gross metabolic efficiency) tends to be lower than what you're saying, and the research shows that when riding we don't appear to moderate cadence to maximize metabolic efficiency.
Old Fart
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
I don't know- I don't keep track of such things- I just ride and do what feels best and works best under the particular conditions at-hand. Although I have sensed that that my RPMs have increased on the flats, over the last few years since i started riding.
Ultimately, it's something that one shouldn't worry about. There are so many variables- i.e. fitness; terrain; gearing; speed; position; leg strength vs. cardio fitness.... Just do what works for you.
As you get fitter and faster, your RPMs will likely increase. No need to change anything to make your RPMs higher artificially- just let it come naturally. Don't let numbers rule your ride; listen to your body.
Quoted: 6556 Post(s)
Liked 58 Times
Have your ever watched people walking down the street? If people can't even learn to walk efficiently without instruction and coaching, what makes you think that any more complex activity can be perfected or even just improved that way. It sounds so right, but it is so wrong.
Quoted: 1186 Post(s)
Liked 289 Times
I've seen riders dropped in racing in large extent because they ride with too low a cadence and are unable to respond to changes in pace quickly enough to avoid losing a wheel. Track riders specifically practice riding at high cadence to improve efficiency.
edit: And for the OP my cadence varies depending on the ride. Below is a 3 hr ride with a 40min crit in the middle. The crit is shown in blue with higher cadence. As others have said at higher power levels it's natural for cadence to go up.
I consider 85 my basement. I'm trying to stay north of that unless climbing so i don't hurt my knees. 85-110. North of that is for sprinting and heavy accelerating. I watch my speed less on solo rides, more on group rides to keep within the desired parameters.
Bikes: 2015 Giant Talon 4, 2015 Fuji Roubaix 1.1, 2010 Fuji Newest 3.0
If I am riding solo or taking a pull on a group ride I am at 90-100 rpm, in a paceline I am around 80.
