Fuji Absolute 1.7 NDS Chain stay bracket
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hi folks,
This week's assignment from the Co-op is a Fuji Absolute 1.7. It's equipped with a linear brake on the front & a U brake on the rear under the chain stays. There is a little bracket on the NDS chain stay with two threaded holes in it. They are ~18mm apart. Pix attached. Any idea what they are for? Possibly for a disc brake with an unusual mount? Or, maybe a kickstand? Any info would be appreciated.
Thanks & regards,
Van
Inside
Outside
The bike
Thanks & regards,
Van
Inside
Outside
The bike
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
that's gotta be a disk brake caliper mount
/markp
/markp
SE Wis
Quoted: 2751 Post(s)
Liked 3,408 Times
Likes For dedhed:
Quoted: 5855 Post(s)
Liked 2,695 Times
Given that the flat mounting face is to the outside, we can rule out any kind of brake.
That points to a kickstand as the most likely.
FB
Chain-L site
FB
Chain-L site
Quoted: 851 Post(s)
Liked 1,082 Times
+2 for kickstand but you could also contact FUJI and maybe get an answer. Fuji Bikes | 2014 Absolute 1.7 | Bike Archives
Quoted: 141 Post(s)
Liked 163 Times
Those are "absolutely" (pun intended) mounting holes for a kickstand. There have been some Fuji Absolutes with kickstands mounted as a stock item on the bike, using the mounting holes.
Likes For well biked:
Quoted: 251 Post(s)
Liked 167 Times
Dang, I was hoping it was a new fangled disc caliper mount. I’ve been wanting to use this style & size frame to build up a bike for our daughter-in-law, but prefer discs. Thanks for setting me straight.
Cheers,
Van
Cheers,
Van
SE Wis
Liked 3,408 Times
Likes For dedhed:
