Go Back  Bike Forums > Bike Forums > Advocacy & Safety
My idea for a U-Lock alarm system
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Old 02-18-13, 08:19 PM
j814wong
My idea for a U-Lock with an Alarm system
It'll be like a standard u-lock. Push in the U metal part into the main part of the lock then turn the key to lock. But here's the difference in my idea. The U-Metal part houses a wire that, where, once the lock is closed, a circuit is completed. Turning the key both locks the lock and turns on the alarm system. This alarm system will activate when the circuit is broken before the lock is unlocked with a key. This means that the U metal part is cut and therefore the wire and circuit is broken. If the alarm sounds, people will notice and if they see a guy running off with a bike, they'll suspect him of being the thief and hopefully give chase.
Variation
There is also an alarm that is attached directly to the bike and not only to the lock. It'll be strong enough to take a banging if the thief tries to break it off without using the key.
How does this part work? When the circuit of the lock is broken, a wireless signal is sent to the alarm attached to the bike so if the thief runs of with the bike, he or she would also be running with teh alarm attached to the bike. The alarm won't stop unless the lock's key is used.
Future high end bikes could even have that alarm module built into the bike's frame to make it harder to stop by a thief.
If there are any engineers here, please make this.
j814wong is offline
Old 02-19-13, 09:42 AM
kmv2
kmv2's Avatar
Bikes: Bianchi circa late 1980s, Surly Cross Check, Kona Blast
https://www.integratedtrackers.com/GPSTrack/Spybike.jsp
kmv2 is offline
Old 02-19-13, 04:09 PM
mulveyr
mulveyr's Avatar
Bikes: Specialized Diverge, Box Dog Pelican, 1991 Cannondale tandem
Quoted: 41 Post(s)
Liked 11 Times in 4 Posts
I think you need to spend some time looking at the dozens of YouTube videos of people openly cutting locks on bikes while surrounded by people... who don't give it a second glance.
And then follow up with some contemplation of how many people pay attention to, much less "give chase", to cars whose alarms have gone off.
Knows the weight of my bike to the nearest 10 pounds.
mulveyr is offline
Old 02-20-13, 05:56 AM
smasha
Vegan on a bicycle
smasha's Avatar
Quoted: 114 Post(s)
Liked 22 Times in 22 Posts
if someone attacks the lock mechanism, rather than the shackle or body of the lock, the alarm is defeated. you lose.
see also - https://www.xenasecurity.com/
smasha is offline
flyback
General Cycling Discussion
2
06-09-19 01:12 PM
ADAP7IVE
18
10-19-18 10:03 PM
Fly2High
14
02-09-15 09:51 AM
RWBlue01
Touring
8
10-21-13 02:16 PM
Leukybear
Road Cycling
2
05-26-11 05:01 PM
