Tool Boxes recommendations for portable workshop
Bikes: 1989 Cannondale SR400(?)
Quoted: 27 Post(s)
Liked 15 Times
Hi all,
I don't have enough space for a permanent bike shop. Mine has to be portable, so I can put it away when I'm not using it. What do you all use for tool boxes? My toolbox has gotten too small.
Quoted: 4512 Post(s)
Liked 6,382 Times
https://images.homedepot-static.com/...13-a0_1000.jpg
Quoted: 27 Post(s)
Liked 15 Times
yeah, I've seen those. I like this one: Husky Tool Box
Liked 6,382 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Sears made some good tool bags a while ago.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
A Craftsman 3 drawer tool box but be careful they can get heavy quick. https://www.lowes.com/pd/craftsman-p...EaAmJFEALw_wcB
i want one of these for the shooting range
Sugar "Kane" Kowalczyk
Quoted: 27 Post(s)
Liked 15 Times
I thought about the 3 drawer metal tool box like that craftsman. But then I saw those stackable totes with wheels, and thought I could put my parts in the bottom. The blue bin in the picture is my parts bin.
Death fork? Naaaah!!
What BG said.
A tool box large enough to hold a useful selection rapidly becomes too heavy to lift easily.
Top
Top
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
I have one of these, from Harbor Freight, and it works pretty well.
But like others have said, you run out of space soon enough .....
Love the GI folding table!
Top
Quoted: 608 Post(s)
Liked 352 Times
I posted this yesterday in another thread. I am a fan of the the Park Tool Chests Currently I use a the BX-2 but with the amount of tools I am accumulating, I might need to move up to the BX-3. Yes, they are very expensive but they are designed for the bicycle enthusiast in mind.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
This style of box was made by many, currently by Kennedy. You can fit most all of your bike tools in it and it's heavy but movable and strong. It's a shame they're hundreds of bucks but your Grandkids will inherit it.
Randomhead
Liked 3,698 Times
Using a Kennedy machinists tool chest is not a bad idea. I have one that is under-utilized. Also a similar craftsman box that is also just collecting junk. I do 99% of my wrenching in the basement nowadays, so a portable is less than fully useful.
If you really want to go down a rabbit hole of portable toolboxes, the toolboxwars hashtag on instagram is good to waste a lot of time. It also got me to waste $14 so far. They usually modify Pelican cases, which is expensive, but not as expensive as the Park or other pre-made boxes. https://www.instagram.com/explore/ta...ars/top/?hl=ur
Pedalin' Erry Day
Random question, but in response to Toolboxwars, can someone explain what the rotating punch pliers in so many of the pros' toolboxes are used for?
Quoted: 1372 Post(s)
Liked 1,751 Times
Believe it or not, at one time, I gave serious consideration to using this Falcon Tricycle as a portable bench and tool holder. Sadly. someone bought the bike and the trike kit, ending my unique bike/tool box idea...
Also, when starting out, one might want to know what are good tools to start with, then what to add when maintenance or restoration projects become more intricate and/or demanding. With that in mind, I put together this tool suggestion page for all levels of bicycle maintenance or full restoration. Have a look, if you wish and I do hope it proves helpful...
Bad example
Quoted: 825 Post(s)
Liked 212 Times
Phyllo-buster
Liked 2,054 Times
Maybe 40-50 lbs with the essentials plus some extra crap. Transistor radio not included. The beauty is you don't need the foam stuff, the drawers organize everything. Build quality exceptional. Looks scattered, I know.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
Kennedy tool boxes are not inexpensive, or very portable. Here's one from Stanley that has wheels and opens up nicely: https://www.homedepot.com/p/Stanley-...800R/202262088
Quoted: 472 Post(s)
Liked 1,028 Times
OP, think about what "portable" means to you. Ex: move it across the room, from one end of the house to the other, inside to outside, up or down stairs, down the driveway to the car, etc. Then look a that route. Smooth floor. Thin carpet, thick carpet, door sills, curbs, step down, etc. This will tell you a lot about what you need. Those small caster things are neat but cannot do stairs. The Stanley or Husky hand truck type things will handle irregular floors and journeys much better. Ex: up the stairs and out onto the back porch. The larger the wheels the better. You could even figure out how to lash that table to the thing. Maybe choose a design that will hold your current tools and many of the others you'll get. And, maybe some consumables ( grease and lubricants and solvents and paper towels, etc) but not all your parts. Or, maybe just the parts for the current build. Seriously manage the weight n potential weight.
Figure out what you want and HOW you're going to use it. Then buy just a bit more than you'll need. You'll grow into it.
I have an old three compartment Craftsman box I bought from our hay guy for $5.00. Cleaned it up and it holds all the bike tools I regularly use. Several others are seldom used (DO alignment tool, heavy duty chain whip, frame alignment tool) so are stashed elsewhere. Not readily to hand.
