Shifting worsens by the end of long rides
I have an Emonda with Dura Ace 11spd on it with 1,700 miles on it. The chain/cassette have about 500 (swapped to diff cassette and changed chain at the same time). I wipe down and lube my chain no less frequently than every other ride or 50 miles (exception for rides longer than 50 miles). The shifter cable was replaced within the last 300 miles too.
I've been noticing that by the end of longer rides (60-75 miles) that the shifting gets louder and less precise and sometimes delays or even mis-shifts. As soon as I get home, wipe down the chain, and re-lube, it's PERFECT again (so I know it's adjusted right). I keep my drivetrain so clean you could eat off it. I am NOT negligent with maintenance, if anything I'm overboard with it.
Is this normal? I'm using Rock N Roll Gold lube. I see people on Strava hitting 200-300 miles in a ride... I don't think I could even tolerate the shift quality if it were to worsen much beyond how mine gets after 60 miles.
Have you tried adjusting derailleurs PRIOR to relubing after long ride. Maybe needs some very minor tweaking that isn't apparent with a well oiled chain? That's where I would start. If that doesn't help maybe double check cables, make sure there isn't an issue caused by steering that might not show at home on stand.
Flyin' under the radar
I would suggest that it isn't adjusted correctly. Lubing a chain facilitates easier shifting, which can mask an ever-so-slightly misadjusted rear derailleur. I'd recommend cleaning your chain, dial in your rear derailleur, and then lube it. I'll betcha you won't run into the same problem again.
FWIW my 11-speed DA needed intermittent cable tension adjustments about once every 3 weeks for the first 1500 miles. Then, magically between 1500-1700 miles it stopped needing minor tweaks. Over 1000 miles later, I haven't needed to do any tweaking.
My issue was the front derailleur would rub the chain after about 400 miles, without fail.
Liked 10 Times
I find my hands get lazy when i'm tired on a long ride and my shifts will suffer. not getting the lever all the way across.
also your drivetrain won't work exactly the same under load as on the work stand.
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
Back when I rode Shimano I had a general technique for adjusting the derailleurs. I typically set the limits and then set the front shift while the back was near center chain line for chainring swaps. The back I would adjust by shifting up one gear un-adjusted and then tightening the barrel until it hopped up to the second cog. I found that testing the quality of shifting had the most resolution if I turned the crank slower than 30 equivalent cadence, which always made shifting worse. If I got good up and down shifts at such a low cadence I had perfect shifts once on the road at 80+ cadence.
Yeah my shifting is perfect in the stand and on the road... until the last 10-15 miles of a 60-75 mile ride. Certain parts of the year (winter & summer) I only ride an hour or so at a time so it gets cleaned/lubed prior to 50 miles and I never even see the decreased performance.
Quoted: 86 Post(s)
i would try more lube after cleaning. or different lube.
had a friend that was OCD WRT the cleanliness of his drivetrain. when i saw the teensy-weensy amount of lube he put on the chain afterward, i commented on it. he said, "i just don't want all that oil collecting dirt". i didn't push it...
Bikes: Fuji, Ridley, Bianchi, Charge
I do a lot of long distance rides and I know first hand that Rock-n-Roll Gold lube does not last more than 50-75 miles. I use Rock-n-Roll Blue and I have no problems. Or you can use Gold lube and apply more, a good deal more than you are now.
Quoted: 18424 Post(s)
Liked 15,573 Times
So it's not just me. My GF bought a bottle of that stuff because a friend of ours swore by it. I gave it a try for a while and found myself asking "Didn't I just lube my chain before my ride the other day?"
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
Rock n Roll lasts less than 60 miles in my experience. On a recommendation from here I'm trying the WD40 chain lube. I like it so far, drivetrain is rather silent, and I have 75 miles on since initial application. We shall see...
Cathedral City, CA
Bikes: 2016 RITCHEY BreakAway (full Chorus 11), 2005 Ritchey BreakAway (full Chorus 11, STOLEN), 2001 Gary Fisher Tassajara mountain bike (sold), 2004 Giant TRC 2 road bike (sold)
Quoted: 8 Post(s)
Bikes: Wizard, Eisentraut, Paramount, Litton, Turner, Surley, Trek, Kona, Landshark, Hujsak, Masi, Tesch, Holland, Retrotec, Spectrum
Quoted: 37 Post(s)
WD-40 is not a lubricant. Google it. It's a lousy chain lube in any event.
Tri-Flow.
Tri-Flow.
Cathedral City, CA
Quoted: 8 Post(s)
Note the bike details in my signature...
Over the years, I have thrown the chain off in both directions, but probably 15-20 : 1 inside to outside. The thing is, I can go for months with a problem and have 2 episodes in the same ride. To me, that also reinforces the human error part...
I'm not sure I understand? Are Campy shifters hard to deal with on upshifts (going to a smaller cog)? With Shimano you can push as hard or as light as you want, the same thing will happen. Downshifts are another story and sometimes I'll do .5 or 1.5 shifts when I meant to do 1 or 2 when fatigued.
Cathedral City, CA
Quoted: 8 Post(s)
No, the point was one of fatigue and how that can change how you manipulate the levers. How hard you push on ANY brand determines how fast the actuation goes. When you get tired, fine motor skills can be effected. You also have to remember that you are using different fingers with Campagnolo. Perhaps when fatigue sets in, it hits index and middle fingers differently than thumbs. Don't know...
My old boss asked me if there was any WD-40 around to fix a squeaky hinge. I just said no and brought some real oil from home to fix it myself without telling him.
Bikes: Steel 1x's
Quoted: 632 Post(s)
Did not notice it on my AWOL/Steel/Sora bike, but it only has 565 miles on it.
I'm doing my first long ride on my Jamis/Steel/SRAM Rival/Force bike tomorrow and will see if it pops up.
Alias530, did you ever find a solution for this?
I also noticed this on my Roubaix/CarbonFiber/105 bike and it has 2,650 miles on it. I used ProLink chain lube on it and I'm not as religious as cleaning it.
