Disc discoloration on brand new bike
#51
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,926 Times
Only my front rotor shows signs of bluing, which is not surprising since I use the front brake more and with much more force, since I generally don't want to lock up the rear wheel and skid.
Likes For genejockey:
#52
Quoted: 682 Post(s)
Liked 453 Times
Not sure what you think is unlikely about the discolouration (from iron oxide forming on the surface at about 300°C) ) being only visible near the braking track and removed from it by the brake pads, given everything that you and others have said.
#53
Quoted: 2700 Post(s)
Liked 486 Times
Im surprised that there is any discoloration (I guess the consensus is that it is an oxide?) Im surprised that any formed, and since it is not uniform on the braking surface and because I haven't done very much with the front brake yet, I dont like to believe that it was everywhere. The bike is less than 20 miles old.
That being said, it does make sense that it is happening all over the braking surface and just being rubbed away. My gut tells me this isn't the case, but I do not know. If others say that its likely that the discoloration is likely happening elsewhere on the rotor and just being rubbed off by the brakes, I would listen.
#54
Quoted: 682 Post(s)
Liked 453 Times
https://steelfabservices.com.au/temp...20temperatures.
You only have to heat it once to create it.
It isn’t on the braking surface at all, because the pads have removed it.
#55
Liked 11,926 Times
You supposedly work at SLAC, with Scientists, and yet without being able to offer an alternative hypothesis, or even a plausible explanation for why this WOULDN'T be the case, you day your GUT tells you it isn't the case?
Don't listen to guts. They're full of ****.
#56
Liked 486 Times
*sigh*
#57
Quoted: 682 Post(s)
Liked 453 Times
Look down the rotor edge as you pull the brakes. You can see where the pads make contact.
Likes For choddo:
#58
Quoted: 4422 Post(s)
Liked 4,875 Times
#59
Quoted: 4260 Post(s)
Liked 1,364 Times
*sigh*
He doesn’t know (since he’s asking the question) but no one else can be right.
Likes For njkayaker:
#60
Quoted: 10238 Post(s)
Liked 5,189 Times
As I read this thread I started to think about my many rotors. I don’t think I have ever looked at them.
Likes For jadmt:
#62
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
I agree. A light application of grease will reduce friction and the resulting noise and heat. As with rational thought, education and social skills, some find braking overrated.
Likes For shelbyfv:
#63
Quoted: 9656 Post(s)
Liked 6,366 Times
Looks like oil slick finish to me. Live with it - it's cool.
Likes For Mojo31:
#64
Quoted: 6975 Post(s)
Liked 10,975 Times
Likes For Koyote:
#65
Liked 5,189 Times
#66
Quoted: 18430 Post(s)
Liked 15,585 Times
The last bike I bought get 13 miles on it just from riding home from the builder's shop. They day after I bought my IF, I rode it 85 miles.
In any event, you did that to your rotors after only 15 miles and, like, two days? I smell something.
#67
Liked 15,585 Times
#68
Liked 6,366 Times
#69
Quoted: 769 Post(s)
Liked 1,748 Times
Yea it was sort of half hearted response as I knew it would be ignored, but I said my bit.
#70
Liked 5,189 Times
Likes For eduskator:
#72
Liked 5,189 Times
Likes For bampilot06:
#73
Quoted: 3958 Post(s)
Liked 7,312 Times
#74
Liked 486 Times
It’s a brand new bike from a bike shop, and it was ridden like 20 miles or something when that pic was taken. How unusual is this? Is it indicative of misalignment, and I shouldn’t be riding it in case it messes things up further?
of course I’m going to bring it back to the shop, it’s a matter of time though, they’ll have to fix my old bike so I have something to commute on. Can’t afford to leave this bike at the shop overnight. This is what it looks like now, maybe 10 miles since the last pic? Also, are fingerprints and grease from hands bad for rotors, like should I wear gloves if touching? I just touched it by mistake
#75
Liked 1,364 Times
How far is the shop from where you live? Most shops will look at it right then. (There probably is nothing to fix.) When did you notice the color change?
