Can 26" and 700c tires be used interchangably?
Can 26" and 700c wheels be used interchangably?
I'm buying an old frame to make a fix-er-up project. It comes with 26" wheels, but I'm wondering, would I be able to use 700c wheels with this bike instead? Or am I stuck with 26"? Does the frame and/or fork have any effect on what wheels I can use?
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
If the bike has clearance for fat tyres, you might be able to squeeze skinny-tyred 700c wheels in there, but cantilever brake mounts will be in the wrong position. For all the hassle, it's worth just using the appropriate sized wheel. 26" wheels with fat slicks work quite well in my experience, and can be run at a lower pressure.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Probably not. I am assuming 26" mountain bike sized wheels. Sometimes you might luck up and get a frame they will fit on, however they you have to deal with getting a bunch of different parts to make them work. In most cases it is better to just use the correct size to begin with.
Here is a good article on the different sizes of tires and what fits where.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Every day a winding road
Your brakes most likely will not match up to the wheels.
I suppose I should have clarified better: I'm buying *all* new parts for this frame, including wheels, brakes, forks, etc. So I can pick the front fork to be either 26" or 700c, so I'm not actually wondering about the front wheel or brake stuff or whatever. Also, I'm using disc brakes, so rim brake mounts won't matter. However, does the size of the frame's rear triangle/seat-stays/chain-stays/whatever matter? Can the rear wheel be pretty much any size?
I'm just really hoping I can use 700c wheels, because I found a killer deal on a wheelset I really want, and they're 700c If I really have to, if the bike with 26" wheels can't take 700c, I can just buy a frame that uses 700c.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Big question, then, is whether the 700 rear tire that you want would fit in the frame?
You aren't asking if 26" and 700 tires can be used interchangeably on either size wheel, are you?
Best plan would be to start with a frame designed for the size wheels that you would like to use.
Wow, yeah, I just realized that I said "tires" instead of wheels. My bad! What I really mean to ask is if 700c WHEELS can be used for the back wheel on a frame that originally came with 26" wheels?
A totally unrelated question: what are those little metal loops on bikes called that hold the brake and shifter cables on the tubes, so it looks neater and doesn't flop all over?
Quoted: 1572 Post(s)
Liked 644 Times
With disc brakes it will probably work. My fixed gear conversion, which started life as a 26" wheel mountain bike, now has 700c wheels. In my case a standard road caliper brake was perfect to reach from the fork crown to the brakeing surface.
Here's a word of warning: You can almost never change just one part on a bicycle. Everything works together so, when you change one part, you almost always have to change something else to get the whole package to work. If I already own parts, I'll generally trial fit them to see if I can make the combination work. If I'm buying parts, I'll hold out for stuff that matches.
Good luck.
Good luck.
Thank you for reply- a fellow Missourian Yes, I will be buying discs to use on it; it came with calipers but I'm scrapping pretty much everything that came on this bike and *just* using the frame. I wanted to get a fork to fit a 700c front wheel so I was hoping the back part could also fit a 700c wheel. Since you said it worked on your bike, I'll give it a try! Thanks!
-B
-B
world-wide wise..
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
umm.. it's been my understanding that you wouldn't worry so much about the rear clearancewise if there's no fenders involved the real issue would be the front since more then likely you won't have the clearance at the crown... measure it from the center of the fork drop outs to the crown bridge and see if a 700c would fit? and like everyone else said, brakes are gonna be a pain.
Um...did you not read what I said about buying a new fork and brakes? Thats exactly why I'm not worried about the front fork OR brakes. I'm just using the frame, and getting all new parts, so I was wondering if 700c will fit in the rear.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Ahh okay, if you have a 27" wheel throw it on real quick because if that fits why wouldn't a 700?
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
It depends on the rear triangle also. If there is little room between the seat tube and the 26" tire then the 700c tire may hit the seat tube.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6799 Post(s)
Liked 5,509 Times
Thanks; I was actually wondering what they are called if they are originally on the frame; cable loops or holes or something? I dunno.
I don't have the frame yet, I was just considering buying it, but I wanted to ask you guys first to see if it would work, because I'm having a hard time finding local, older and/or affordable fix-er-up frames that already use 700c. I'm from a really small town with few used bikes around, and I can't bring myself to buy a new bike, then scrap all the brand new parts for other ones...
Artificial Member
Liked 5,509 Times
Yeah, they are nicer than zip ties.
But zip ties will work too.
Rider
Liked 5 Times
Simple answer: No.
More complex answer: Maybe, but if someone with the required tinkering skills to pull it off wouldn't have needed to ask.
700C Tire
Found something out the hard way. Had a flat on the front tire out on the road, rode the thing on in with great difficulty. Bought two new tubes at WalMart, both exploded at about 45 lbs mounted in the old tire. Duh, finally discovered that the beat up flat tire would not seat allowing the tube to expand to the point of explosion at the stress non tire seat area. Solution, new 700C tire, and another tube by the way. Also found that a 27" tube fits quite well. Seems WalMart doesn't have the 700C tube with the Schrader valve, only the Presta valve. Sheesh!
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Thanks. The experience was not without some cost, even at WalMart......New tire was 'Kelvar', maybe now I can ride with some peace of mind.....
Quoted: 305 Post(s)
Liked 2,038 Times
that's not quite the same, but if fietsbob wore a medium size tee shirt and it were the most common size world wide, why try to make a small tee shirt fit?
