Stupid Truvativ Elita GXP left crank keeps getting loose
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
I assume I need a new Bottom bracket. Correct or no? It is similar to this one. It is ISIS.
It is from 2006.
It is from 2006.
Quoted: 1074 Post(s)
Liked 295 Times
The axle is steel, the crank arms are (usually) considerably softer aluminium. It's just about always the crank arms that gets damaged. Sometimes you can get lucky and find a left crank only to use as a replacement, which usually sorts it out. Otherwise what you need is a crankset. The actual BB will usually be just fine - unless there's something else going on there.
And as I understand it GXP means that the crank axle is permanently attached to the right side crank, while ISIS is basically a development of the good ol' square taper. Crank arms and BB(axle) as separate parts. ISIS just means that the square taper is replaced with a splined interface.
Yes it is a splined interface. The attachment of the crank arm is with a bolt like thingie(see below) that is threaded and attaches to the BB with a simple allen wrench. Because it is splined(similar to Octalink but with 10 splines) and not a square taper(that can get rounded over time) I don't understand why the crank arm itself would be causing it become loose.
I would assume it was the bolt or the threaded part of the BB that is to blame.
Quoted: 2026 Post(s)
Liked 1,096 Times
As dabac noted, the bottom bracket spindle is hardened steel and the crank arm is aluminum so the damage is always to the crank arm if it gets loose.
Those bolts are to blame if you didn't torque them adequately when installing the crank. The recommended torque is very high at 300-400 inch-pounds and MUCH higher than you could possibly apply with a standard 8 mm hex key. If the bolts aren't tight enough, they will back out and the crank arm then loosens and is damaged by the spindle.
I wasn't the one to install the cranks originally. About an hour ago I put on some locktite as a last ditch effort. I attached a small box wrench to the allen wrench to allow me to really crank it down with additional leverage. I will see how it holds for my 3 hour ride later today.
I guess I still don't understand how the crank arm(splined not square taper) could be damaged to the point that the bolt backs out on its own. I can understand how that can happen with a square taper...since the fact that it is tapered is what accounts for the tight hold. But if the splines(I assume) aren't tapered, then how does it loosen itself?
Liked 1,096 Times
The sequence is the opposite of what you describe. The bolt backs out first due to inadequate tension and THEN the arm loosens and is damaged.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
What's stupid about the GXP design is that the arm is not designed to go in too far and is supposed to perch itself onto the axle with about 0.2mm to spare before being tightened down to pick up the slack. Sure, the design doesn't load the bearings up axially, but if it's not tightened down properly, it can loosen and squish the interface enough to cause problems.
Shimano's design is far superior when compared to GXP, as the fastening and preload adjustment are two different parts. With shimano, if you're not careful, you can strip the threading on the left side arm, but that alone won't cause the arm to loosen and rock.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Sequence: Bolt too loose. Arm rocks around and is damaged. Loose bolt is discovered and retightened. Bolt loosens on its own. I just didn't realize that the splined crank arms were also tapered which explains why the issue is with the crank arm. I had assumed that only square tapered cranks are tapered.
Why don't they just design the darn things with multiple bolts like a car wheel or with some sort of lock washer?
Oh well, I will see if the loctite can bide me some time till I get a new crank arm.
actually, for GXP, the interface is splined AND tapered.
There was never anything wrong with the old square taper BB spindle. Everything that followed is just new and improved. If shimano's octalink was that good they wouldn't have replaced it as soon as they did.
Liked 5 Times
The new shimano external BB system is good. I like it, despite some of it's shortcomings.
For one, the expensive drive side doesn't wear out each time you go to remove it, only the cheap left side does. You don't have to worry about stripped extraction threads. On the downside, you can't adjust the chainline too much and it's quite specific about having a properly faced BB shell.
No, nothing wrong, but they could have the same issues with loose crank arms. Plus you need special tools to service them. They are also much heavier. Not that I care, but weight weenies do.
Liked 5 Times
couple thoughts:
The early versions of GXP suck b/c the action of pedaling will loosen the crank bolt over time. This is far less likely to happen if it's torqued down properly, but it can happen regardless. Shimano's pinch bolts counter this effect, and FSA has gone similiar pinch bolts. RaceFace sidesteps the issue by having the bolt on the drive-side arm, with the axle attached to the left arm. New GXP have a reverse-threaded lockring to keep the bolt in place after you've tightened it properly.
Square-taper died b/c this interface was the weak link in high-impact situations, as one might encounter in downhill and dirt-jumping disciplines. New technology is new technology, so when they developed stuff to deal with those styles of riding, the market clamored to offer that same stuff to all riders. Octalink and isis sucked b/c, as someone mentioned, the bearings were too small/weak, but they also sucked in almost every way. The octa/isis era was thankfully short.
These outboard bearings are already essentially dead technology. They're moving to bb30, and 2 different oversize bb shells for shimano alone, depending on if it's for a road or mtb. I don't really like this, b/c it kills the super-adaptable nature of bike frames thayt i've been enjoying for most of my lifetime. I can put hollowtech II on a 70s bike-boom sled if i like, but it'll never take a bb30. Thankfully, the shimano systems will accommodate the regular 68mm "euro" BB shell for as long as hollowtech II BB sets are available.
sorry for the rambling post. it's friday.
-rob
-rob
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
-rob
Loctite plus cranking down the bolt with a box wrench attached to the allen wrench and standing on it with my foot seemed to do the trick...at least for now. 20 miles and still tight. Yesterday just a 30 minute ride had it nearly falling off so this is an improvement. Let's see how long this lasts.
Liked 1,096 Times
I contend the bolt was never adequately tightened. Unless you used a torque wrench and know you torqued it to spec, I'd bet a fair amount the torque you applied was no where near correct.
Liked 5 Times
slowandsteady, now that yor left crankarm has come loose and been ridden loose, there will be enough play that it will never be truly tight again. I went thru this on an early-gxp version of a truvativ stylo SS crank on my old dianchi mtb. Tried all sorts of things but, ultimately, the crank had to go.
Operator, the oversized BB shell standards being favored by shimano (and others) are bb86 (road) and bb92(mtb). The basic idea is to have a very wide bb shell, both laterally and in terms of circumference, so a unit the size of an entire hollowtech II bb set can be fit inside the shell. The ID is something like 37mm; enough to accomodate the bearings shimano currently uses in its outboard bearings, but *inside* of the shell. The width of the bb shell, left to right, is 86 for road (roughly the same as a 68mm bb shell plus the width of the outboard bearings) and 91.5mm for the mtb stuff (roughly equivalent to a 73mm BB shell plus bearings. Remember, the mtb hollowtech II cranksets have a longer axle, to accomodate 73mm shells, and the bbs come with spacers to effectively make a 68mm shell into a 73mm). Currently, there are both threaded and press-fit designs on the table. I like the idea of the press-fit, but this will almost surely drive production costs up. Regardless, i'm terrified about such a radical change, and i'm already thinkling about hoarding a huge pile of hollowtech II BBs so i can continue to run modern cranks in my 68mm english/euro BB bikes for the foreseeable future.
Then again, i'm weird and paranoid.
-rob
-rob
Liked 5 Times
-rob
I'm sure someone will come up with adapters to fit standard 68mm BBs into BB86/92 bottom-bracket shells. Similar to the ones we currently have for American 1-piece bikes.
Liked 5 Times
I just enjoy panic
-rob
Very doubtfull. The new BBs are larger diameter and the cranksets are narrower than the old 68mm standard. You can overcome diameter with smaller bearings but the width issue would be tough to beat.
Liked 5 Times
The chainline never changed between external and 3 piece splined or square taper systems.
Liked 5 Times
AEO, your understanding of the design seems to be accurate, which is why i'm not all too worried.
-rob
