Novice wanting to know about crank arm compatabiliy.
Quoted: 24 Post(s)
This is an older bike. 1985 Trek 520.
I am needing a left crank arm that will work with a Sakae CR. I cannot find a Sakae CR left crank arm and I don't know if I can just pop something else on there in it's place. This is not a permanent fix, I will be getting the group changed out later on.
I really don't know much but since it is on the left side I didn't see why I couldn't just put any old 170mm crank arm on there.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
As long as it fits, and is the same length as the other side, you should be good to go. Especially if it's just temporary. I think I've read before that it's left arms that more commonly fail (which would explain why you're looking for a left). fleaBay has a bunch for $13 delivered, seems the cheapest are square-taper, which I'm guessing is what you're looking at from 1985.
Also, for purists, if you're working with Sakae, that's Japanese, which should have a JIS square-taper BB, which is the shorter kind. If you happen to try a left crank of the other square-taper standard, (ISO I think it's called, taper-angle is the same, but it's longer), then your BB would work, but the square taper would not go as far into the crank. Some purists would complain, but for temporary use you can't go wrong. (If it was the other way around, if you had ISO sq-taper BB, and you tried to put a JIS crank on it, it wouldn't fit; the end of the spindle would bottom out before you started pressing the crank onto the taper, if that makes sense).
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Quoted: 24 Post(s)
Quoted: 1438 Post(s)
Liked 1,092 Times
If you are replacing the arm because the pedal threads are stripped, you should be aware that they can be economically repaired with a Helicoil insert.
Quoted: 24 Post(s)
https://img.cla*****.com/883/722161/1...jpg?1370466087
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
I didn't think about that. Thanks for warning me.
And dsbrantjr is right, stripped pedal eyes can be repaired with helicoil by most well-equipped shops, but if the crank is not special, and soon to be replaced, it might not be worth it. I had it done once to save a crankset which was special to me because I got it from my dad, so it was worth it at $40 (although others at BF seem to say the going rate is closer to $20). Your choice of course.
Quoted: 24 Post(s)
That pic I would call "diamond". I think that is more common.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Quoted: 24 Post(s)
Quoted: 128 Post(s)
Liked 12 Times
Other thing is Q-factor - how far away from the bike's centerline does the crankarm sit - basically how far does it flare out. This isn't as important as the other concerns though. As long as you've matched diamond orientation, JIS taper, and 170mm length, those are the more-important things.
"c" is not a unit that measures tire width
