Anyone know anything about Infinity Boss Three Hybrid bikes?
Bikes: Tern Link D8
Was just at my local Costco and saw this for sale for $169.99 and was wondering if anyone has one & would recommend it or not? I'm looking for an inexpensive bike for my husband that will have to be dragged kicking & screaming away from his computer to go cycling with me.
Boss.three Mens 7 Speed ? Infinity
I need more cowbell.
Bikes: 2015 Specialized Sirrus Elite
Quoted: 23 Post(s)
I’d raise the budget a little and shop at an actual LBS. that bike will probably break down quickly and hurt to ride - both disincentives for new riders.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
While I too would suggest an LBS or even other online bikes, I will have to admit after doing a quick look at this bike....It's simple with no crazy pretense of being a mountain bike or fast road bike, inexpensive and seems like an ok bike for simple neighborhood rides to hopefully get the husband away from the computer with.
But, this may be a case you want to have LBS check it out. I see some really strange things on how these bikes are put together at retail stores like WalMart, Dicks and Target. Some cases it simply isn't safe to ride.
I say try it, if you and husband some how get the bug to ride more and more, then save up money for the LBS bikes. Have fun!!!
Bikes: Tern Link D8
Thanks for the replies. If the bike were for me I would definitely go to a LBS & buy something in the upwards of $400 range. Whatever bike we get will probably be taken to an LBS for them to put together anyway since I've never put a bike together myself. The cost for a LBS to put together a bike will be in the $50-100 range. I just know that it will be difficult to get my husband to go riding enough to be worth spending more on a bike for him.
Although, we are around the same height (5'5"). So if I can convince him to go with a bike I'd like to ride too, then I could justify spending more since I'm ready for a full size bike for myself after riding a folder for the past few years. If that's the case I like this one at REI: https://www.rei.com/product/131752/p...ssic-bike-2017 Otherwise, it seems a waste to spend over $200 on a bike he'll very rarely ride.
One good thing about that particular bike is that it has a rigid fork and not a pretend suspension fork that does nothing but cost $ and act as an anchor. So hope they put that fork money towards some better quality.
Do they have assembled bikes in the store for him to test-ride and see the fit? If it doesn't fit it doesn't matter how good or bad it is. If it doesn't fit you already know he won't ride it a lot.....
@Casbah.
I just bought this bike from Costco and it works great. It is what the descriptions says, simple hybrid bike.
This won me over the price, quality and looks. There was quite some thought given to this before I could make my sub $200 purchase. I can say it is definitely worth it. I bought this just for joy rides during the summer along with some travel to simple bike paths, nothing more.
Shifts super smooth and brakes perfect. No adjustments needed.
The assembly is straight forward and simple. Built quality is indeed very good. It is Aluminium frame so needs a little care like you would take care of your car, however it is strong and sturdy.
Quick disconnect wheel is awesome. My front wheel needed a tru so I took it a to a LBS and got it checked out. They were amazed at the bike quality and got other things checked out on my bike. They said the bike was similar to the $250 -300 range entry level bikes.
_____________
2017 Infinity Boss.3 Mens 7 Speed.
_____________
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
The bike looks decent enough to me. Pro set-up/tune would ensure proper performance.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
But, build quality appeared to be just fine...even impressive for the price point. The wheels are probably inexpensive wheels, but they have pinned alloy rims and seemed to be of decent quality. The tires are fine -- about like what you'd find at a Target Schwinn or a Diamondback hybrid at Richard's. The rear derailleur (and maybe even freewheel also; I don't remember) are Shimano branded. Brakes are standard shiny chrome V-brakes, but they use alloy arms as I recall, rather than stamped steel like other budget bikes. I think it compares extremely well for anything you can get for well less than 200 dollars.
Disc brakes
I really like this bike and using it to commute to work during summer months at Olympia wa. I wonder how hard is it to convert this to a disc brake bike. There's a college bike shop I can borrow all the tools and work space I need for free.
Bikes: 2000 Trek 720 Multitrack (plus)
Quoted: 48 Post(s)
Been riding it to work, 6 mi each way for almost two months. The plastic chain guard is cracked and the 7th gear needs adjustments. Been adjusting both breaks few times already, looks like may need new pair for next summer. It's light so can go to the roof no problem. Overall, I like the quality for what I pay for. I got the man bike, my wife's woman bike fender always makes noise no matter how I adjust it. If I can, I rather get two man bikes instead and she will be happier.
What is the size of the inner tube if I need to get replacemwmts? Will this work?
MULTI PACK
BICYCLE TUBES
27" x 1-1/8 -1/4" (700c x 28-32mm)
48mm Schrader Valve
(A little longer valve for ease of airing up or
if you have a deeper rim)
Bikes: Giant Escape 1
Quoted: 136 Post(s)
You probably can't go wrong at that price - but you want to make sure to get a bike your husband will enjoy riding. I don't know how much that bikes weighs, but if it's over 30 pounds, he will get tired of it quickly. Also, I don't know what kind of riding you two are likely to do. If you ride bike paths and rail trails or on pretty level neighborhood streets, then this bike should be fine. But if you want to take rides of more than 20 miles, you may want to upgrade to more gears and lighter weight.
Fenders on the womans bike!
If you have hard time adjusting the fenders, then just simply take them off, and ride it without fenders, if you need them, then make sure you did everything correct, you didn't tight them too hard, or check if it is bent and does not rub against the wheel/frame, if that doesn't work then just buy new fenders off your local bike shop or for cheap prices under 10$, buy online!
breakwater
53
10-11-17 10:01 AM
Mark.from.Texas
21
07-18-12 07:37 AM
