Would a gravel handlebar become annoyng in a race?
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
As the tittle said, a specific gravel handlebar with flare , can be bothering during a criterium race when the group is very compact?
Any other cons to have a gravel specific one?
The gavel geometry would make it interesting...
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Most gravel bars put your hands out wider (when you're in the drops) than traditional drop bars, so there is that aero penalty.
Likes For tyrion:
Quoted: 3953 Post(s)
Liked 7,301 Times
It seems it would depend on whether the flare makes the gravel bars narrow on the top, or wider in the drops.
Likes For tomato coupe:
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
If I were surrounded by a dozen others all packed tight and jockeying for position, wider would clearly be worse. That seems pretty obvious- wider bars have a higher chance of getting caught on another rider's bike or body.
Likes For mstateglfr:
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
If you size the gravel bars to be the same width in the drops as your road bars, you get an aero advantage when on the hoods. Black Inc is now selling a flared integrated bar/stem intended for road use (Froome-endorsed). This is something I would like to do on my road bike, but I'm not willing to scrap my current carbon integrated bar/stem.
Quoted: 4806 Post(s)
Liked 3,932 Times
I'd worry about the wider drop hooking another's handlebars while I'm on the hoods. Ugly and six riders down. Someone hitting you and then flipping. Very unlikely to be a minor "pretty" crash. We were taught to ride with our elbows out precisely to prevent that from happening but moving your hands in while leaving the widest part of the bar out there nullifies some of that protection.
Now, if you always ride the drops when in close quarters and the hoods only for aero benefit when you are chasing or at the front, go for it. Just stay off those hoods when you are around me.
Quoted: 333 Post(s)
Liked 168 Times
Perfect. I'll pass on gravel handlebar now.
ohh right the aero penalty too
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
I’ve got flared bars on our gravel tandem, which sees road and off road use( switching out wheels as the terrain dictates) The flare in the drops is nice off road, particularly when we ride tougher terrain, including some moderate single track.
When we ride on the road, I would prefer more traditional bars. So imho it depends on your intended use.
You could get lost and die.
You could hit a tree and die.
Quoted: 10238 Post(s)
Liked 5,185 Times
Nope. I use the cervelo carbon gravel bar on my crit bike. flare is handy in the sprints.
Edit: What kind of flare are we talking? The cervelo gravel bars is a slight flare. The new madone has a flare as well. I wouldn’t want to race a crit with woodchippers or something extreme.
Liked 3,932 Times
A great place to have two "cockpits". Two fully made up bars, brake levers/shifters, tape etc. Perhaps with Ritchie style disconnects on the brake and derailleur cables. I do this on my good fix gear but it's a little simpler. Quill stems. I leave the brakes set up with their calipers as part of the cockpit so swapping means just pulling the stem and unbolting the calipers. 5 minutes.
Liked 5,185 Times
Quoted: 878 Post(s)
Liked 726 Times
Doesn't seem to have bothered Pogacar on the narrow Belgian roads.
The Enve aero bar design incorporates a flared drop, with Pogačar’s particular size offering a 37 cm width at the hoods and 42 cm on the drops.
Likes For surak:
pan y agua
Liked 727 Times
don’t really think those are the kind of gravel bars that the OP was talking about.
Sunshine
Liked 7,492 Times
Quoted: 878 Post(s)
Liked 726 Times
Mostly commenting on the flared part. But a bar like the Zipp XPLR has a 6mm difference in width between hoods and drops, a whopping 1mm more than the Enves. So one is obviously gravel flare and the other road...
Quoted: 333 Post(s)
Liked 168 Times
Liked 5,185 Times
