Make a specialized Allez fit like a Domane?
Quoted: 119 Post(s)
Liked 23 Times
Have a Domane 56cm and I need another bike for the trainer so I can put my Domane back on the road. There is a Specialized Allez at 56cm nearby on CL. Can I make an Allez pretty similar to a Domany on short money, so I can have a nearly similar experience on road as off? I asked my LBS and they said it would take a lot of work, but I know he wants to sell me a new bike, so I thought I'd ask for a different opinion
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
https://geometrygeeks.bike/compare/t...allez-2021-56/
This link compares a 56cm in each bike. The Allez is indeed a bit different. It shows what might need to be changed to make them match.
Likes For Polaris OBark:
Quoted: 426 Post(s)
Liked 274 Times
Since you are not going to care about head angle if one bike is going on the trainer looks like all it would take to make them similar in feel is get the correct length stem with the correct angle adjust spacers accordingly.
Likes For sean.hwy:
I agree all it takes is a new stem, but you need one more thing: a new bike shop.
Quoted: 768 Post(s)
Liked 1,745 Times
You should be able to make it fit and work, or , you could look for a used AL Domane rim brake frame to make it a trainer bike. Then you could find some used parts to put it together. Would not have to worry about anything fancy, would just need a front wheel and the drive train, you could even pick up some Microshift to reduce cost and you dont even need brakes.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
It can be a hard thing to get across. I needed my trainer bike built up without, for example, brakes, and it took a few minutes to communicate the goal.
Quoted: 1461 Post(s)
Liked 1,486 Times
Does the head tube angle affect the fit? I get that it changes the handling, but the question seems to be getting a "similar" fit between the two bikes. Even with different HTA's this doesn't seem that difficult.
I'm not a bike fitting arguer/expert, genuinely curious about this. I have two bikes with different frame geometry (including different head tube angles) and have been able to get them pretty close in terms of contact points, but they're not exact. Close enough for what I need though.
Likes For msu2001la:
Quoted: 426 Post(s)
Liked 274 Times
I would not trust one of these on gravel bike while bombing some crazy single track. On stationary bike trainer yes.
