Spokes breaking like crazy, eh!
Bikes: Rampar R-One
Broke my second spoke of the month today, and I think third of the year.
All have been on rear; should I just get a new rim?
wwyd?
wwyd?
Single-serving poster
Make sure the wheel is tensioned properly. Heavier gauge spokes? As long as the eyelets on the rim are fine and it's not really bent up..
not a role model
Usually this is a sign that the entire wheel is out of tension. I would personally take the wheel to someone who can re-tension the whole thing.
This will most likely resolve the issue. If not, rebuilt with a better rim.
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
Bicycle Repair Man !!!
Sounds like a tension, or lack of proper tension issue and this leads to fatigue and breakage.
3 broken spokes is usually a sign that the wheel should be rebuilt with new spokes or that a new wheel be purchased.
Commander, UFO Bike
I'm always breaking spokes on 32 spoke wheels... After upgrading to a 36 spoke wheel, I didn't have any problems until a SUV parked on the wheel (I was on the bike too). >=[
Bicikli Huszár
Bikes: '95 Novara Randonee
This. I had the same problem, and was told to just get a new wheel (it was the original wheel, nothing expensive or I might have had it rebuilt). No more problems.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Yes, if you're going to pay someone to work on the wheel (or do it yourself), definitely replace all the spokes; the original spokes are now suspect due to fatigue probably caused by improper tensioning as mentioned above.
Bike addict, dreamer
Stock wheels? I had a bike once that would pop the spokes when not being ridden, just parked, from the heat, I guess. I'd leave it in the shed in the morning, come back after work to find a spoke broken. I broke a spoke during the first week of riding too, then a few more. I don't buy stock bikes and wheels any more and I haven't had any problems with spokes ever since. Well, except for a wheelset I built myself I suck at this, so I won't try again.
Depending on how much it'll cost to rebuild those wheel you might just buy a new wheelset from Bicycle Wheel Warehouse or Universal Cycles. I have an under $150 BWW wheelset on my commuter that gets a lot of abuse and is usually loaded with crap and after a year and a half the wheels haven't even gone out of true a tiny bit. And I hit potholes sometimes so hard my butt hurts.
A well built wheel should stay that way over thousands and thousands of km and need little to no attention... just checked a front wheel I had used for commuting, utility, and off road riding that has well over 5000 km on it and it was still 5 by 5.
Was a Formula hub laced to an Alex 2100 rim with DT spokes... came to me barely used and I tuned it up 4 years ago before running it just to make sure it was 100%.
This wheel sells for about $80.00 (off the peg) and is a really good deal, the rear runs 100.00... pretty nice for factory built methinks.
Um. . .. no. A properly built wheel requires about zero maintenance. I have wheels with thousands of miles on them that haven't been touched with a spoke wrench in years. It's all a matter of quality: both materials and build. When built right, the wheels stays tight and true and the tension is fine.
"Per Ardua ad Surly"
Bikes: Bianchi Specialissima, Mongoose Hilltopper ATB, Surly Cross-Check, Norco City Glide
My new Norco was blowing spokes all over the place till I took it back to my LBS and Norco replaced the rear rim under warranty. And I got a better rim and spokes in the process.
Bikes: Raleigh Record Ace, Windsor The Hour
No need for a new rim ! Go to you LBS and have them relace the wheel =) Should cost about 50 bucks (including labor)
Bikes: Rampar R-One
Nah, bought it used about 2,200 miles ago.
Since it wouldn't be worth having it rebuilt, I'm going to go new. That wheel sounds like a pretty good option.
If they stay true what am I supposed to "maintain" other than keeping them clean?
When you bring your stock wheel in for that first spoke replacement, it's a good time to go for a "major" wheel true, including de- and re-tensioning.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
My bike was breaking spokes like mad on the stock wheel. I bought a whole new set of spokes and a better rim, and rebuilt it myself one evening. It ran 13,000 miles with zero maintenance after that, until I broke an axle. Never went a mm out of true.
A good wheel doesn't really need regular maintenance, only a tweak if it goes out of true.
Sounds like the OP's spokes are under tensioned, especially if they're breaking at the elbow.
Work: the 8 hours that separates bike rides.
You gonna eat that?
I'll jump on that pile. I got a new wheel and no more problems.
Bikes: Jamis Aurora Elite
Seems to me eliminating c) and upgrading b) will help reduce a).
Bikes: Rampar R-One
