Compression Knee Sleeve
Quoted: 75 Post(s)
Anyone ever used compression sleeves for their knees either for performance while riding, or for recovery afterward? How about compression calf sleeves or stockings? I've got knee warmers but they don't provide a significant amount of compression. I'm mainly looking for a drug-free way to decrease inflammation and soreness from hard training rides or after long days in the saddle.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Have you had the bicycle set up properly for you? That's the most important drug-free way to decrease inflammation and soreness from hard training rides or after long days in the saddle.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 41 Post(s)
Two things come to mind.
-First is physical conditioning. Exercises that build leg strength and fitness are very useful. As you build calf muscle, for example, the more efficient blood and fluid return. Core exercises are important. In my recent rehab it was amazing how swelling and discomfort went down as my strength and muscle development increased.
-After consulting with your physician you may want to use a prophylactic anti-informatory.
Yes, compression stockings and supports work. But there are some distinct downsides and in an athletic environment they are definitely not a long term answer. These are not the same as orthopedic braces that stabilize joints.
There are people who lay all ills to poor bicycle fit. I suspect that swelling and vascular inflammation won't be influenced very much by moving a seat a couple of mm.
Quoted: 75 Post(s)
As HawkOwl said, improving physical condition and leg strength has and will hopefully continue to help the problem, but to do that, I have to push myself and sometimes that leaves me sore. I can live with a lot of soreness or pain if I have to, but if there is a drug free way to avoid discomfort or speed recovery . . . well . . . cool
I don't expect that I would use the compression sleeves or socks all the time, or even that frequently, but I'm curious if they would be useful for those times I do get sore. There may be a downside to using them but the same can be said for frequent or chronic use of NSAIDS.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
I've found NSAIDs to be contraindicated except for the special case of tendonitis, and even then they should not be used unless necessary.
Knee problems, like back problems, respond best to careful exercise and training. Exercise may need to be targeted to resolve the problem. That said, Friel reviews several studies on compression wear here:
Joe Friel - An Update on Compression Clothing
A feeling of soreness inside the knee may be due to cartilage/meniscus damage. Frequently there's nothing to be done about that other than to train to ride in lower gears, i.e. spin faster, in the 100 rpm range even when climbing. I've ridden with older runners who are missing much of the cartilage in their knees. They spin fast and take ibuprofen. Nothing to be done, it just hurts. That said, I've had less knee pain since I've been taking glucosamine sulfate and MSM, starting about 10 years ago. I've found hiking hills to be the best cross training for cycling.
