Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
anyone use compact crankset for racing?
Old 10-17-18, 10:03 AM
arai_speed
arai_speed's Avatar
Bikes: Yes
Quoted: 41 Post(s)
At first I thought this topic was in jest...but then I saw the replies (which I also thought were in jest)...
arai_speed is offline
Old 10-17-18, 10:34 AM
gsteinb
out walking the earth
gsteinb's Avatar
Quoted: 912 Post(s)
Liked 752 Times in 342 Posts
ok.
gsteinb is offline
Old 10-17-18, 11:03 AM
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
Liked 10 Times in 6 Posts
It's worth noting that track cyclists manage higher peak speeds over the same distances on a smaller gear than a 50/11.
The biggest advantage to running a 53 or 54 big ring, if you can spin, is the mechanical efficiency that comes from the better chain line.
Racer Ex is offline
Old 10-17-18, 09:22 PM
hack
hack's Avatar
Quoted: 417 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by TheKillerPenguin
The queen stage of GMSR is 100+ miles long and ends with a 3 mile climb where the last 500m is like 20%. 36/28 is NEVER enough for that, compacts have their place for sure.
I recently did the Death Ride, a fondo-esque ride in NorCal with a ton of climbing, on a 53/39. I snuck an 11-32 on the rear with a standard etap derailleur. Worked fine, but had to remind myself not to go into big/big. Lots of long descents, so the 53/11 was nice to have with the added climbing range. Not something I'd run often, but it worked for that event.
hack is offline
Old 10-18-18, 11:17 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Originally Posted by gsteinb
While I take your point, your numbers are bit off. Mount Washington averages 12%. I reckon no one races that on a standard. I ride whiteface on a standard crank 10-15 times a year, but the gradient hardly varies a degree or two from 8%. though most folks I see riding it have compacts. Again, a lot of it has to do with the type of races one does, and the style in which one races. If you have a short punchy 15% section, yeah you can muscle over it with momentum. If it's extended and you're suited to higher cadence one might prefer lighter gears. If you're doing mainly flat races, or RRs without serious climbing it's mostly a non issue. I know lots of guys with 53x11s, and not a lot of guys who can effectively use them at the end of a crit for a solid placing. I used my 11 the sprint, but generally it was when I lacked popped at the end of the race to get on top of an easier gear.
This is a big reason why I'd like a 54 or 55, specifically so I DON'T have to get in to an 11. Never-minding the actual friction and science that would make more logical sense from a reasoning standpoint, but just putting my bike on a stand and putting it in a 53x11 and turning the cranks backwards...UGH. There's some restriction there.
I don't want to be in my 11. I don't even like the 12 that much for a similar reason.
rubiksoval is offline
Old 10-18-18, 11:19 AM
rubiksoval
Bikes: bikes
Which part did you think was in jest?
Old 10-18-18, 11:25 AM
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Liked 4 Times in 4 Posts
the topic and the replies. seems clear.
Ygduf is offline
Old 10-18-18, 11:50 AM
rubiksoval
Bikes: bikes
The jest being:
I can't believe someone uses a compact in a race...
or
I can't believe that someone doesn't realize that people might use a compact in a race and actually asks about it...
Clear as mud. Especially the bit about the replies.
Old 10-18-18, 01:49 PM
arai_speed
arai_speed's Avatar
Bikes: Yes
Quoted: 41 Post(s)
Originally Posted by rubiksoval
The jest being:
or
LOL - both.
Another example I took to be in jest (maybe I'm wrong?)
Originally Posted by rubiksoval;
Do they? I don't think so. 52/36, sure, but not a 50/34.
Old 10-18-18, 03:00 PM
rubiksoval
Bikes: bikes
LOL - both.
Yeah. A bit.
There seems to be some communication issues on your end.
Old 10-18-18, 04:00 PM
arai_speed
arai_speed's Avatar
Bikes: Yes
Quoted: 41 Post(s)
Yeah. A bit.
chado445510
Road Cycling
6
01-21-12 07:23 PM
JAX_11
39
01-12-12 11:30 AM
JAMES_AMTRAK
19
10-05-11 10:55 PM
mossi
Road Cycling
36
12-27-10 03:49 PM
