Tripple vs Double chainring.
#51
Cycleway town
The Megarange freewheels are good for road bikes, as only first gear is huge. The rest of the set is fairly close ratio. Kinda like adding a granny ring to the rear.
Not so good for mountain, and terrible for e-bikes which need wide ratios - sadly manufacturers seem to be slow to offer the latter (ironically my 4-speed 13-34t cassette is ancient).
#52
I agree, probably not the best for competitive mountain biking, But for the recreational rider who occasionally likes to rough it, It does seem to work.
#53
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
With the wide range cassettes available today, you would need a really long cage derailleur to make it work with a triple. I've never experienced a triple that came close to a mediocre double shift quality wise. I made a little video a month or so ago on a bike that had a common triple 3x9 speed setup to a modern 2x11 combination. The result was lighter weight, narrower Q factor, and much, much better shift quality overall. Not trying to make folks stop riding triples, but if you've got worn out components, the technology is there to retrofit your existing bike.
#54
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 224 Post(s)
Liked 162 Times
I am crossing to a crossroads with a bike I intend to ship to Okinawa. I need a bike there to allow to ride when I visit the in-laws.
Here in SE Michigan, I can easily get by with a 50/34 and a 11-28T. Our biggest and steepest hill in the area, Kensington Rd, is really nothing compared to what I remember from Okinawa. I'm thinking a 50/38/30 and 11-32 might even not be enough. I do remember hills in the car climbing up Otoba Dake and Ikie Island, and the car straining to make it up these hills. Let alone a bike.
#55
Cycleway town
There are a few arguments against tripled that I'm just not buying.
I'm absolutely on board with making bikes simpler. It might not seem like it, when my daily is a 2,000w electric full suspension tandem, and it's not even my strangest or most complicated bike.. but seriously I'd ride a bike weighing 2kgs and consisting of 14 components of I could.
But please. Weight? The Merlin's granny ring is cross-drilled aluminium with hollow titanium bolts. An empty bottle cage is heavier.
Cross-chain? Who ever used the whole cassette in the granny ring? Apart from the sort of people who use cable locks..?
#56
Cycleway town
Stairs have been my target hurdle for decades. I did a flight of about 10 steps, circa three bike lengths, on the Merlin when it was an 81-speed. That consisted of a triple crank, 9-speed cassette, and 3-speed hub.
I recon I could've done double the stairs since I had the rythum, but it was slow and tricky work.
#57
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The only argument I buy against triples is the shifting. Much easier to keep a 2x shifting perfectly, and many 3x setups take a tad of finesse to deal with the middle ring when not perfect.
This is often reason enough for 2x to be a better choice for many.
However, being someone who CAN shift a reasonably well adjusted 3x crank, there are absolutely no downsides for me, and I have seen ZERO benefits in my switch to 2x a few years ago.
#58
Friction shifting .. FTW..
Its keeping the parts on opposite ends of the cable working together with indexed shifting
that seems to be an issue, on these pages..
but indexed shifting sells bikes now, its expected.. the bike factories all ship it..
#59
When index shifting my triple, I've found that if I overshoot the middle position from the small ring just a tad before backing it into the proper position, I quite confident it will make a clean, crisp shift. Overall I can honestly say I'm impressed with how well this entry level Shimano Altus derailleur works.
My original plan was to use the middle chainring 90% of the time because my initial perception was switching chainrings was a pain. One day I decided to use all 3 chainrings with every cassette sprocket for my ride just to see if my suspicions were justified. What a surprise. It worked so close to perfect I wonder why they even bother to make expensive ones. I am being patient with the shifts and not trying to push it, But it really surprised me how well an entry level bike can shift.
Now whenever I need a big change on my middle chainring, I don't hesitate to switch it rather then 2 or 3 cogs on the cassette.
#60
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I watched your video. Very nice, you have a pleasant voice. I also got to see how that new-fangled bottom bracket works. Thanks. Other thoughts:
But you don't have to use a wide-range cassette with a triple. This is the point, I think, of a triple: closely-spaced gears in three different ranges.
I have two triples, they shift flawlessly, so I can't relate. And I spend 90% of my time on the middle ring, where my favorite gears are, so I am not shifting the front that often. The double crank in your video has a bigger jump between rings (50x34=16 teeth) than I have between my granny and my middle (37-24=13 teeth).
I am not sure what a "common" triple might be, but the reason I have one is for wicked low gears, so I have a 24T as my small ring. I don't know why your customer's bike would have a 30T granny. What's the point of that? He could have switched his 30T for a 24T and had a gear lower than the one on his new setup, 25.4 inches vs. 26.4 (though no real difference in practice). Would have been less expensive.
Of course, I have no idea how your customer rides and what he likes for gears. I run a 13-28 9-speed cassette that gives me 8 gears in which I do most of my riding, with a couple of downhill gears and 3 very low uphill gears. His new setup would give me 7 gears in my favorite range, and more widely spaced. And who needs a 120 gear who is not a pro? So on that double setup, I would lose gears I like and gain gears I wouldn't use, with larger steps between cogs.
Triples rock if you like/need them, and they don't if you don't. That's all there is to it. And now I must go polish my Birkenstocks.
I made a little video a month or so ago on a bike that had a common triple 3x9 speed setup to a modern 2x11 combination. The result was lighter weight, narrower Q factor, and much, much better shift quality overall. Not trying to make folks stop riding triples, but if you've got worn out components, the technology is there to retrofit your existing bike.https://www.youtube.com/watch?v=q07DQ24rPl0
#61
Quoted: 1364 Post(s)
Liked 1,677 Times
Likes For BobbyG:
#63
Liked 1,677 Times
Mea Culpa.
I have begun my penance...
#64
Double or Tripple
I'm more touring than speed. All my bikes are now triples. My two 1970 era ten speeds were converted last year. The stock crank gears were 52-40. The problem was that neither bike could handle hills without standing on the pedals and swaying side to side. That's In low range first gear. High gear was useless except going downhill. My 26"mountain bike has combination tires and a 48-42-36 gearset. My 27" road bike has 48-40-36 gearset. both are now 15 speeds and have no trouble staying with the group. There is enough adjustment in the stock derailers but the length of the chain has to be set to low gear high range so that it isn't too loose in high gear low range. I have two 1990's 18 speed bikes, Two 2000's 21 speed bikes and one three year old 24 speed bike. I ride the older bikes more than the new one probably because there are more of them. I love all of them equally but I try to match the bike to the terrain we are riding that day.
#65
Quoted: 1109 Post(s)
Liked 1,200 Times
Likes For Camilo:
#66
Advanced Slacker
Liked 2,537 Times
Having used and maintained both doubles and triples for over 40 years, I just have never understood this idea that triples are harder to adjust and/or use. It's never been the case for me. In fact, triple shifting is easier than compact doubles - very few double shifts needed, and much less front shifting since you can access all or most of the cassette from the middle ring, and that gives me probably 80% of the total range I ever need. Very few shifts to either the largest or smallest rings needed.
However, do mean since you can do it, you can't understand how it is not trickier? I mean, I can drive a manual tranny no problem, but I totally get why others find it harder than an automatic. I can play guitar but it does not surprise me that others can't. I can build a window casing, and solder copper piping but am not the least bit surprised that someone else would screw either of these up. Likewise, I can adjust and use a triple, but I totally get why others struggle.
#67
Liked 1,200 Times
About the only personal knowledge I have is my wife who is certainly not a bike nerd and just gets on the bike and rides. Now, I'm her mechanic so that's something (I know how to set them up... but really is that more difficult than a double? Maybe I'm blind to the complexity, but but I don't think it is more difficult. Plus, once set up (double or triple), I virtually never have to touch anything on the front shifting, and I suspect this holds true for almost all casual riders.
I considered getting her a compact double for the recent bike I built up for her, but she's used to the triple and likes it for the reasons I mentioned (little or no double shifting and not very much front shifting required) so I went with that.
Another advantage of the triple: She likes very low gearing and no matter what anyone says about the great range that modern 2X gearing has, 3X can get lower. Her road bike lowest gear is 30 front and 34 rear. Her gravel bike is 28 front and 34 rear. I set up another friend with 30 front and 36 rear. All of these are significantly lower than the same cassettes with a 34 tooth front ring.
Frankly, I believe the whole concept of double shifts, and how often you have to do them with a compact double (a LOT... and often two shifts in back when you change rings) , I think this is more difficult for a casual rider to think about and do well than using a triple. A casual rider finds it easy to just camp out on the middle ring, no need for double shifting when changing rings, and just occasional changing to the large or small rings for very specific terrain (i.e. up a big hill = granny gear... or down a big hill = big ring. Everything else can be middle ring.
I have three four "road bikes". Three are compact doubles, and I'm 90% happy with them. The constant double shifting and multiple rear shifts when changing rings annoys me. It's a kludge, IMHO. My other bike is a gravel (cross, actually) with an old 52-42-30 Ultegra triple crank on it and I just love the shifting, gear spacing and range.
Likes For Camilo:
#68
I wonder if one reason some people have more problems shifting the triple chainring then a double is because with the triple we may be inclined to leave it there 90 % of the time or more and the derailleur sticks from under use. Which would explain why the triple on my new bike seems to work fine overall. Its clean and lubed.
It's not perfect and occasionally I do have trouble shifting on the extreme gear ranges. And shifting the rear derailleur while climbing a steep hill to be much better then fiddling with the front thanks to a Megagear cassette with a 2 - 3 cog jump from 1'st to 2'nd. But for general riding, I love the way a single shift up front can achieve what takes 2 or 3 cogs on the cassette.
#69
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
I have 8 bikes for me and 3 bikes for my wife. All of them have triples that are indexed...either mountain bike shifter or Shimano STI road shifters. All of them shift as soon as the lever is moved. It’s crisp and positive. Back in the bad old days, you could move the lever to downshift the front to the smallest ring and it would shift eventually but that might be a week later.
One thing that kind of bugs me about front derailers is that they are improperly designed. Shimano wanted to standardize the shifting on bikes a number of years ago and they went the wrong way about doing it. They developed “RapidRise”...which most people dubbed RapidFail...which depended on the return spring to move the derailer to lower gears. Lower gears are almost always under higher torque and lower speed than higher gears. When you depend on the spring to move the derailer to lower gears, the spring has to be really, really strong. If it is too weak, it will just skate the chain against the cog and not move.
The front derailer suffers from just that problem. It depends on the spring to move the chain to a low speed/high torque gear. Often...especially on old systems...the chain just wouldn’t derail. Sun Tour made a derailer back in the early 90s that was actually reversed from the “normal” derailer. The cable was used to drag the derailer to the lower gear. It worked far better than any other derailer I’ve ever used. If Shimano had done the “RapidRise” (shouldn’t it be RapidFall since it is going to lower gears) treatment to their front derailers, we’d all be shifting differently.
Stuart Black
Stuart Black
Likes For cyccommute:
#70
Quoted: 76 Post(s)
Liked 19 Times
@cyccommute Suntour also had a friction front derailleur like you describe in the 70's. My 72 Fuji Finest came with a FD like you describe. I swapped it out since I hated having it backwards from my other downtube shifter bikes. It did shift nice though.
#71
Quoted: 257 Post(s)
Liked 252 Times
I’d prefer to ride them. But it is hard to argue with your impeccable logic, Richard.
Likes For BCDrums:
#72
I like a single chainring for it's simplicity and appearance and with the right cassette might be fine for many of us. But since the chainring derailleur is already there, Why don't more bikes use a triple chainring. Is it because of the room?
I like the triple because if we have the right combination of cassette and chainring we can leave the bike on the middle chainring most of the time like a single, and still have some very low and high gears for steep hills and fast rides down them. Also sometimes I want to drop 2 or 3 gears fast, and with one step up front I can do that.
i've been on 1x for 10-11 years. no need for more really. i had 11-32 aka 300% what more do you need?? then i simply selected chainrings for this. i now run 42s and everything from 12-30 to 11-28 and 11-30 and 11-32, 8 and 9sp. and 6sp. with 8 and 9sp spacing. my best cassettes are the 6sp ones since these are expanding exponentially as opposed to shimanos 2t or 3t or 4t spacings per cog. it should be 1, then 2 then 3 then 4 then 5 then 6 and so on between the cogs, in theory. then it feels natural. exponential curve..
#73
Most problems i have seen with triples is that the FD rubs, I have never ever seen a rub free triple talking all over the cassette and chainrings. the gripshifts are good for this up front. if youre on a mtb handlebar. i have actually never seen a double run rub free either. in the FD department. I understood this 10 years ago and said F it and went 1x.
Haven't looked back since. stone age tech imo.
#74
Liked 4,217 Times
Well basically the double can replicate the triple with a wider cassette. and some people found out the single can replicate the double with a very wide cassette.
Stuart Black
Stuart Black
