Bearing Service on Ksyrium SSC SL?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Mavic Ksyrium SSC SL wheels from 2006. The bearings have never been serviced. Should I do something to the bearings, adjust the preload or have them replaced or something?
These wheels have been bomb-proof for me. I rode these for 10 years, beat the crap out of them actually, and never did a thing to them. They are in the shop now to be trued for the first time.
The bike is offline, disassembled in preparation for a new groupset and so I'm taking the opportunity to do what I can elsewhere. So what, if anything has to be done to the bearings on these wheels?
-Tim-
-Tim-
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Since the wheels are in the shop, why not get the bearings replaced? Whether they absolutely need it or not depends on lots of things including miles over the ten years, how much dirt you ride in, amount of rain and snow, and things like that. You definately need them greased so new bearings won't ne too much more.
post-ironic
Bikes: CAAD 12, Lemond Maillot Jaune
Quoted: 75 Post(s)
If there is lateral movement after tightening the preload, then replace the bearings. Otherwise you can remove the rubber gasket and spray in degreaser, then repack with grease. But bearings cost like $15 online, so why not replace them?
Quoted: 2952 Post(s)
Liked 3,106 Times
I replaced the bearings on mine after about 15000 miles. It was easy and inexpensive.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
-Tim-
-Tim-
Mine developed a crack in the rear rim after three years, and I'm a fairly gentle rider.
Then I got to experience MAVICs amazing customer service and as a result will NEVER buy anything of theirs again...
Today, I believe my jurisdiction ends here...
Bikes: 2014 CDale EVO, 2007 System Six, 2004 Litespeed Solano, 2002 Burley Duet
Quoted: 92 Post(s)
I bought the bearing removers, press, and bearings from Wheels Manufacturing for around $100. It took me less than an hour to do both wheels.
The other wear point is the bushing in the freehub. I have one set with over 15K miles and it is still tight. You can buy replacement hubs with oversize bushing also.
I do the rear freewheel about once a year.
You only mention bearings, but cleaning the inner rubber seal, the plastic bushing, the 2 ratcheting pawls (yeah, only 2), then relubing with a light weight oil pays off.
I think this slows wear on the bushing too.
Quoted: 92 Post(s)
You need two 608s, two 6901s, one 6903(Freehub body bearing), the press, two 6901 open bore adaptors, two 6903 open bore adapters (they work with the 608 bearings), one 608/688 8mm bearing extractor, one 6901 12mm bearing extractor, and one 6903 17mm bearing extractor.
I went with the ABEC 5 bearings. I can't justify the cost of ceramic bearings since I don't race. I have seven sets of Ksyriums, so for the price of one set of bearings and the tools I spent less than the shop wanted in labor. I now have the tools to do the rest.
There are several good Youtube videos out there on how to do it. The drifts and bearing pullers aren't essential, but make it a lot easier.
- Soli Deo Gloria -
Liked 736 Times
Thank you both. You have been a huge help. This is good information and sounds like something I would like to tackle.
I think I know the part numbers for the bearings, extractors and press. I'm not understanding over axle adapters vs open bore adapters. Is there a place that explains this?
Any pointers on servicing the freehub or recommendation on brand/model would be appreciated.
Actually pretty excited about learning this.
-Tim-
- Soli Deo Gloria -
Liked 736 Times
Bearings
Enduro 6901 SRS, ABEC-5, Sealed Bearing (Qty 2 @ $10ea)
SKU: SB5-6901
Enduro Part # BB 61901 SRS
OD: 24mm/ID: 12mm/Width: 6mm
Enduro 6903 ABEC-5, Sealed Bearing (Qty 1 @ $12ea)
SKU: SB5-6903
Enduro Part # BB 61903 SRS
OD: 30mm/ID: 17mm/Width: 7mm
Enduro 608 SRS ABEC-5, Sealed Bearing (Qty 2 @ $4ea)
SKU: SB5-608
Enduro Part # BB 608 SRS ABEC 5
OD: 22mm/ID: 8mm/Width: 7mm
ToolsSKU: SB5-6901
SKU: SB5-6903
SKU: SB5-608
6001, 6801 & 6901 (12mm) Sealed Bearing Extractor (Qty 1 @ $16)
SKU: 6001-EXT
Wheels Manufacturing 6001 Bearing Extractor
6003, 6803, 6903 & 17287 (17mm) Sealed Bearing Extractor (Qty 1 @ $22 ea)
SKU: 6003-EXT
Wheels Manufacturing 6003 Bearing Extractor
608 & 688 (8mm) Sealed Bearing Extractor (Qty 1 @ $16 ea)
SKU: 608-EXT
Wheels Manufacturing 608 Bearing Extractor
Economy Bearing Press ($35)
SKU: PRESS-4
Economy Bearing Press - Bearing Presses - Tools
6901 Open Bore Adapter (Qty 2 @ $7.50 ea)
6903 Open Bore Adapter (Qty 2 @ $7.50 ea)
Wheels Manufacturing Sealed Bearing Open Bore Adapters
Total is going to be $159SKU: 6001-EXT
SKU: 6003-EXT
SKU: 608-EXT
SKU: PRESS-4
-Tim-
-Tim-
Quoted: 273 Post(s)
Liked 10 Times
You could probably make your own bearing press with a piece of threaded rod and a couple of nuts and washers for much less than $35...
TCR Advanced SL
Replace them. My experience is the seals always leak a bit after removal. The bearings ABEC 3 - ABEC 9 can be purchased at any local auto parts house for less than purchasing on line. You need the part numbers or take the old bearings with you. Lp
Successful alcoholic
Quoted: 21 Post(s)
For decades now, I've just used a plastic faced mallet and a piece of hardwood for installation, and a brass drift for removal. I just did front/rear bearings in a set of Corima carbon wheels in less than 10min. Proper high quality, low seal drag bearings were $15 each from a local bearing supply house (not online).
Quoted: 273 Post(s)
Liked 10 Times
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
Quoted: 25 Post(s)
I'm off Mavic as well after my friend has a Ksyrium Equippe S crack the hub after 4000 gentle club miles, an Aksium spoke pull through the rim and strand me in rural Wisconsin, and when I took my friends rim to rebuild my Aksium I found stress cracks on one of the spoke holes, and finally yes their customer service is pretty much nonexistent.
Quoted: 1814 Post(s)
Liked 923 Times
Also in the Mavik not-fan-club,
but replaced a bearing in an Aksium wheel recently.
No special tools beyond a socket of useful size.
This supplier is good- fast.
61901-2RS1 Radial Ball Bearing Double Sealed Bore Dia. 12mm OD 24mm Width 6mm
