Mechanical disc brakes: What's better than BB7s?
Old 10-24-15, 08:51 AM
Thadcorn
Thadcorn's Avatar
Bikes: 2015 Surly Straggler, 2015 Salsa Warbird
I am looking to upgrade my BB7s on my Straggler. I thought about going to hydraulic, but the price of the new levers is pretty high. Does anyone have any recommendations for an upgrade from BB7s? I would love to hear your comments
Thadcorn is offline
Old 10-24-15, 10:26 AM
cale
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 4 Times in 4 Posts
I like the TRP Spyres. They are very similar to caliper brakes for setup and maintenance. The hoop design allows adjustment of both pads with a turn of the cable tension screw just as you find on a caliper brake.
In terms of performance, they are substantially easier to modulate than traditional rim brakes but don't have the feel of a hydraulic. That's probably due to cable stretch.
Regardless of your choice, I have found that compressionless cable housing makes a spongy mechanical brake feel more solid.
cale is offline
Old 10-25-15, 10:39 AM
chriskmurray
chriskmurray's Avatar
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
Quoted: 8 Post(s)
Klamper | Paul Component Engineering
Every Paul brake I have owned has always impressed me! These are like a hoped up version of the BB7 with much better materials, finishing and bearings.
chriskmurray is offline
Old 10-25-15, 03:26 PM
DogBoy
No one carries the DogBoy
Bikes: Roubaix Expert Di2, Jamis Renegade, Surly Disc Trucker, Cervelo P2, CoMotion Tandem
Quoted: 5 Post(s)
I agree with this. I have some Spyres from a bike I sold that I will be putting on my touring bike for this reason.
DogBoy is offline
Old 10-27-15, 06:53 PM
austex
Quoted: 8 Post(s)
TRP HyRd will get you a hydraulic caliper with a cable actuation, so you don't have to change levers...
austex is offline
Old 11-14-15, 11:21 PM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Liked 33 Times in 22 Posts
What are the perceived shortcomings of the BB7 brakes that you are wanting to see improved in upgraded brakes?
BluesDawg is offline
Old 11-15-15, 01:36 AM
allroader55
The Spyre TRPs get reviewed well. I have them, and while not trouble free they have been good enough. I've never ridden BB7 so can't make direct comparison. The Spyre Hy/Rd would be my choice if I could justify upgrading.
allroader55 is offline
Old 11-15-15, 12:21 PM
Henry III
is just a real cool dude
Henry III's Avatar
Quoted: 31 Post(s)
Liked 32 Times in 14 Posts
I vote for the HyRd or Spryes. What shortcomings of BB7's? Please....They're like the cottered cranks of disc brakes. They do what they're intended to do but beyond that.
Henry III is offline
Old 11-15-15, 01:12 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
One thing I found helped (short of replacing functional BB7s.. Avid Speed Dial Levers, (came on the bike))
Turning the little knob, I can reduce the cable pull on the front, but not the back, that way, and soften the modulation a bit..
fietsbob is offline
Old 11-17-15, 07:12 PM
austex
Quoted: 8 Post(s)
Cable-pull/hydraulic caliper hybrids would be an improvement. TRP HyRd or Juin Tech R1 are two options. Compression-less housing will help any cable brake.
austex is offline
Old 11-17-15, 11:21 PM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
I meant that question for the OP. What specifically is he wanting to see improved?
Old 11-18-15, 09:15 AM
Mr IGH
afraid of whales
Mr IGH's Avatar
Quoted: 347 Post(s)
Liked 5 Times in 5 Posts
Nothing is better, some hydro are just as good but why bother? Properly adjusted BB7 work very well. Over on the MTB forum it's amazing how many riders stick with BB7 for low cost, ease of adjustment/maintenance and reliability.
Mr IGH is offline
Old 11-18-15, 11:03 AM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times in 1,439 Posts
Are we talking about with flat bars or drops? Because the MTN version of BB7's are indeed an excellent brake, especially when paired with Speed Dial levers as fietsbob suggests. The road version, on the other hand, are not nearly as good.
TRP Hy/Rds are significantly better than the road BB7s.
My Bikes
Andy_K is offline
Old 11-18-15, 12:31 PM
fietsbob
Bikes: 8
significant internal caliper part is the little crown like ring attached to the actuating arm,
that is the big change between the road, Steeper ramp, and the MTN a more progressive slope.
Like a hill which has a longer run-up to the pass Vs one with a shorter-steeper one..
that steeper ramp is how they shorten the cable pull required..
TRP has a double acting cable brakes .. spyre or spyke .. 1 short, the other long pull .
fietsbob is offline
Old 11-19-15, 01:58 PM
Mr IGH
afraid of whales
Mr IGH's Avatar
Quoted: 347 Post(s)
Originally Posted by Andy_K
Are we talking about with flat bars or drops?...The road version, on the other hand, are not nearly as good....
I'm talking flats and drops, they both work very well. Complaints are due to lack of proper set-up knowledge/execution which lets to lots of internet braying...Hee Haw!
Mr IGH is offline
Old 11-19-15, 02:54 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
That's a ridiculous thing for you to say. Could it not be that complaints are due to other people having a lower tolerance for mediocre braking than you have? I'm not saying the road BB7s are terrible. They are better than most mechanical disc brakes made for short pull levers and many mechanical disc brakes for long pull levers. They are not as good as the MTN version (and I can't see how having used both you could dispute that), and they aren't as good as Hy/Rds.
My Bikes
Andy_K is offline
Old 11-20-15, 09:33 AM
Mr IGH
afraid of whales
Mr IGH's Avatar
Quoted: 347 Post(s)
That's a ridiculous thing for you to say.....
I always chime in on BB7 threads so that others can understand BB7 road or MTB work just fine if one takes the time to learn how to adjust them properly. I ride my road BB7 with an aggressive club, in a pack with the need to have "feel" for the purpose of maintaining one's position around corners. Several other members use road BB7s, no issues whatsoever.
I explain the need for hydros the same as $5,000 bicycles, people like to consume. It's their right to buy and ride whatever they choose.
Mr IGH is offline
Old 11-25-15, 02:29 PM
GeoKrpan
George Krpan
Quoted: 12 Post(s)
Soma has a dirt drop called Gator. It has a 22.2mm diameter which means it's compatible with MTB brake levers and shifters. Road handlebrs are 23.8mm. You could use state of the art MTB dual piston hydraulic brakes which are way cheaper than road hydraulics and can survive a crash. I could not find a pic of the bars with MTB controls installed. Cable dics feel stone age compared to the latest hydraulic discs.
I've seen Tektro Draco II brakes for $50 a wheel, lever, caliper, hose, pre-bled, with bleed kit included. I've used them and they are as good as my Shimano M615s.
Gator Handlebar | SOMA Fabrications
GeoKrpan is offline
Old 11-25-15, 02:44 PM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 632 Post(s)
Liked 3 Times in 3 Posts
I went from BB7's to Hy/RD's and wished I hadn't.
Jarrett2 is offline
Old 11-25-15, 04:11 PM
fietsbob
Bikes: 8
TRP has a fully hydraulic Drop bar lever- disc set, but you have to drop the Brifters and have a different Shifter .
on 2nd or 3rd set of pads on your BB7s.. ? what others have you tried?
I replaced the stock ones with Kool Stop - 'organic compound' and noted the improvement , quieter , but still stops fast.
fietsbob is offline
Old 11-25-15, 04:38 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
What problems have you had?
My Bikes
Andy_K is offline
Old 11-25-15, 05:57 PM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 632 Post(s)
Just hard to get them adjusted well compared to the BB7's.
Jarrett2 is offline
dobozban
Bicycle Mechanics
23
09-02-16 08:00 PM
Epicus07
Bicycle Mechanics
5
05-17-16 11:29 AM
Short Cut
29
06-19-15 07:02 AM
flipdip
General Cycling Discussion
21
05-25-15 09:52 AM
zimba2
Bicycle Mechanics
6
05-24-15 06:52 PM
