Campagnolo experts please??
I just built a new bike with a local retailer and have a super record wireless (the new one) Groupset.
im new to campy and have a few questions.
1. does the installation in the bottom bracket look correct? The Bb cup reads “Pro Tec” on the edge but the SRW crankset is Ultratorque - does this make sense? Also, what is this strange washer on the drive side? Photo attached…
2. I’ve heard about the “Campagnolo clunk” but wow yes it’s real. Is this normal when I’m shifting down at a normal cadence to have a very Solid sounding shift and clunk noise? There’s no rattling or anything but a single loud and very solid/strong sounding “clunk” that is in my opinion very loud. This is normal correct?
3. does anything have experience with “MyCampy 3.0”? The icons in my home page seem to have mixed up the front chainrings and the rear cassette options, icons are swapped relative to the numbers it presents as values. Is this normal in this application? Like is the application not great or have I done something wrong in my syncing? Not sure what to think because I synced properly I believe but it could just be that the application sucks and maybe you can help if you have experience with that? I’ve been a long time Shimano user
Is this washer normal???
Why are these backwards?
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
That little ring or washer-looking thing next to your BB cup is actually a retention clip, just wire bent into the right shape to hold itself in place and protrude through the cup in two places. I believe its only real purpose is to hold things in place during assembly. Once the crank arms are bolted together, the clip is not necessary. (I always use it anyway.)
When you say "shifting down" do you mean going into a smaller cog in back? They tend to give an audible clunk and really let you know you've shifted. It's normal, and I actually find it satisfying.
I can't help you with the app or electronics.
Thread Killer
Quoted: 3151 Post(s)
Liked 1,716 Times
No, the clip is not needed during assembly at all, and would in fact prevent proper assembly were it installed before the crank was assembled; the bearings are pressed onto the spindle halves, then slide into the BB when the left and right crank arms are insterted and bolted together. If the clip were in place, it’d block the bearing going into the cup. The clip is placed there after assembly to ensure preload on the wavy washer on the non-drive side. It’s something to do with variability in BB shell widths, IIRC.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Likes For Broctoon:
Has anyone had experience with my campy 3.0 app?
what sort of things can I customize with the Groupset?
the app doesn’t really give me any options as to things I can change or customize
slow on any terrain
You're the first person I've seen on BF with the new SR wireless groupset. Way to go! I can offer kudos but no help. Ride in good health!
I know from previous threads that you spent upward of $20k on the build. I'd expect top tier customer support. Can the shop not advise?
Quoted: 505 Post(s)
Liked 638 Times
[Ferrari dealer phone ringing]
"Pronto"
"What is this third pedal for? I can't believe there is nothing here that explains it and no one even mentioned it!"
"stronzo testa di cazzo"
[scene]
"Pronto"
[scene]
Quoted: 2338 Post(s)
Liked 2,828 Times
does it ride and shift well? then maybe there is no issue other then bad gui or software, but I would get it checked
I would expect full support from the shop, phone or in person for a high end build....
Liked 2,828 Times
so good reason to keep by A4 quattro with six speed and get another bike rather than a ferrai
Likes For squirtdad:
Quoted: 505 Post(s)
Liked 638 Times
That Audi corners unveliabably. A bud had a supped up one, that was scary fast.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
The clip looks correct - as said, I think it holds the wave washer. This design has been criticized by people like Hambini, but it appears to work well.
The clunk is not only normal, it's awesome and has been a Campy trademark for many years. It's like slamming the door on a G-Wagen. I find it extremely satisfying.
Likes For mattcalifornia:
Quoted: 1821 Post(s)
Liked 1,697 Times
I have installed quite a few Ultra Torque cranksets and can confirm that the clip is needed. What it does is to lock the drive side bearing in place in the cup. Without it, the crank will move from side to side. There was thread here a couple of years ago from someone who installed their crank without the clip and they could see the chainrings moving from side to side as they pedalled. I currently have 2 bikes with Ultra Torque cranks and my son has one. I have also installed these cranks on quite a few other bikes when I was working for a local distributor. I was shown how to install these cranks by a mechanic from Cycles Marinoni who is the biggest importer of Campagnolo components in Canada
logically, lookin at the gui, it would appear that the crank and cassette values are swapped is your crank a 45, 29? (interesting)
Expired Member
Quoted: 3681 Post(s)
Liked 5,445 Times
these ******g bike shops are the worst. I’ve tried emailing him and they won’t reply to this. It’s insane this industry. You spend 24k on a bike and they won’t help you with a clear ******g mishap and he also somehow can’t produce any of the labels or removables from the “boxes” that the new group set came out of. Who knows where it came from and honestly this god damn bike industry is such a ducking sham. I wish you could just get what you pay for it’s sad
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
You are saying you spent $24,000 on a bike and the bike shop you purchased it from won't help you?
