Rear tire rubbing on front derailleur clamp
Quoted: 17 Post(s)
Good evening,
I have a 3 chainrings front derailleur (shimano sis pull down). Just changed my tires from 700*28 to 700*32.
Now the tire rubs on the front clamp holding my derailleur for about 1/4 of the wheel circumference.
Is there anything I can do?
drousseau33, If the bike has vertical rear drop outs, you've exceeded your maximum tire size. If it has horizontal drop outs you maybe able to slide the hub rearward enough.
Bicycle wheels and tires are rarely perfectly round as there's often a 1 or 2 mm deviation. For vertical drop outs you can try finding where the most clearance is and rotating the tire on the rim to where the least clearance is...iffy at best.
Brad
Brad
maybe look at a different model derailleur that might have a
higher or lower band position, or one of them bolt-on types
that uses a separate band clamp.......
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
can you ever so slightly adjust the position of the wheel in the dropout to avoid the rub?
Mid Tour!
Bikes: Marin Muirwoods Racked out for this years Tour, Norco Indi 4 racked out from last years tour, Giant Defi II for week-end ripps.
Quoted: 152 Post(s)
Hope this might help.
-Snuts-
Quoted: 17 Post(s)
I've try playing with the wheel and with the FD/clamp position with no success. My clamp can't go lower since I won't be able to shift top gear, and Higher is even tighter...
Sounds like I have to look for a FD which has enough of 1" clearance and with pull down (my cable runs from the bottom).
Any suggestion not too expensive? 8spd (11-32), 3 gearchain (22-38-48)
Mid Tour!
Quoted: 152 Post(s)
If you are willing to buy a new FD, try filling this one. What have you to loose?
Only my thoughts (out loud).
-Snuts-
-Snuts-
Quoted: 598 Post(s)
Liked 283 Times
Since we seem to be considering excessive solutions other than just buying a slightly smaller tire, btw all 32 mm are not equal in height and diameter and Conti's tend to run smaller than advertised. How about trying a different wider rear rim which will allow your tire to take on a wider but shorter profile.
Quoted: 17 Post(s)
Thanks Robow. Just bought my new tires and put the tags to the trash, so can't bring them back. Plus, it's for a touring bike, so going down to 28mm tires would be kinda small.
Changing the rim means mounting it, and I'm not that good at it
So option A, changing the FD, option B changing the RIM... hummm...
Quoted: 17 Post(s)
Quoted: 598 Post(s)
Liked 283 Times
What rim do you have now? Was that 17mm an inside or outside diameter? Mavic 719 and 319 have an inside 19mm diameter and I know that 2mm doesn't sound like much but it can make a difference.
But heck yea, try the file first, if that doesn't get it done, a lot of people might want to buy your tires around here and you can try some others. Best of luck in whatever you decide.
I can't, off the top of my head, think of a FD or a clamp that can guarantee you the clearance you need with just a single purchase. The clamps I have are all thick enough to have a little material removed without compromising strength. It doesn't read like you need to remove much.(?)
Good luck,
Brad
Good luck,
Brad
Quoted: 1422 Post(s)
Liked 7 Times
Go back to the smaller tire.
The photo helps. Those low mount derailleurs are bulky. Try something like FD-M531, where the clamp is above the derailleur body.
Mid Tour!
Quoted: 152 Post(s)
Damn, those tires are to clean. Get out and ride the high spot off of it this eve!
Quoted: 2604 Post(s)
Liked 1,933 Times
That's why I like long chain stays.
I think the best idea is to go back to a 28 on the rear, and save the 32 for the front. After you wear out the rear tire, you'll probably have worn the front down enough that it'll fit on the rear.
Is your rear wheel true? If it's 1-2 mm too tall at that spot, fixing the wheel might fix the tire rub.
Quoted: 4806 Post(s)
Liked 3,928 Times
I'd go looking for a new front derailleur. Are you locked into a certain brand/model because if indexing issues? I am a little out of touch with the new stuff, I have never seen a derailleur that takes more than half the space yours takes. Usually the cable attachment and arm (I see you have a wheel for the cable; again a new one to me) is far enough to the right that the tire does not interfere.
A possibility would be to replace the front derailleur with a different brand of old style design and run a down tube or bar-end friction shifter for it (if you cannot find the matching index shifter). The was a famous bike racer who used to set his very high end bikes that way for key Tour de France mountain stages to save weight.
I've run rear tires so close to the seattube that I have had to cut a rectangle in the fender to accommodate the FD clamp. This with a derailleur like I was a talking about. (Edit: the cable ran under the BB on that bike. Cable and derailleur were completely clear of the fender and nowhere near the tire.) There are thousands of those derailleurs lying around.
Ben
Ben
Brad
dude, that's not the clamp your tire is rubbing on,
that's the pivot mechanism between the seat tube
and the tire.
had the same situation when fitting a 700c wheel
into a 26" frame. 9spd w/triple.
solution is a seattube clamp
https://item.taobao.com/item.htm?spm...d=523951417491
https://img.alicdn.com/imgextra/i3/1...1096782098.jpg
and a side pull bolt-on derailler, like this here sora FD-3503-F
https://gd2.alicdn.com/imgextra/i1/0...0-item_pic.jpg
and the tire.
