Best, Slim 27.5 tires
Old 08-13-18, 08:54 PM
Natenat138
Quoted: 8 Post(s)
I'm in the process of buying/building a second wheelset for my 2018 Specialized Roubaix Sport, this new set being 27.5. Everything is fit pretty tight now, running a 700x28 (the 28 seems more like a 30-32) and I wouldn't go much larger than that.
I'm wondering what the largest I could go on a 27.5 wheel is, if there is any sort of accurate conversion chart from 700 to 27.5, and if anyone here had recommendations.
Natenat138 is offline
Old 08-13-18, 09:21 PM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
Switching from 700c to 650b will give you 19mm of additional tire height clearance, but tire width clearance will depend on the geometry of the frame and fork. You'll have to look at your frameset and see how much room tires will have to the sides on 650b rims.
HTupolev is offline
Old 08-14-18, 07:21 AM
clasher
clasher's Avatar
Quoted: 229 Post(s)
Liked 148 Times in 103 Posts
I dunno about the 2018 roubaix but I couldn’t get the paris-moto 27.5 x 1.5 in my 2013 roubaix.
clasher is offline
Old 08-16-18, 07:10 AM
Facanh
Quoted: 121 Post(s)
Liked 3 Times in 3 Posts
I don't understand, why do you want to switch to 650b if you're not going to run much bigger tyres? You're going to drop the BB a bunch on a bike that already has a low BB.
Facanh is offline
Old 08-16-18, 07:40 AM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
I think you're going to be really disappointed with this project.
2019 Salsa Warbird
shoota is offline
Old 08-16-18, 07:55 AM
Natenat138
Quoted: 8 Post(s)
What I meant there was that I wouldn’t go much larger on my 700c wheelset, not the 650b wheelset. I’m looking for a tire that will give me similar clearance I have now, but on a 650b set.
Old 08-16-18, 08:15 AM
Facanh
Quoted: 121 Post(s)
Oh ok.
You can just google "bicycle tyre circumfence calculator" and these will give you a ballpark. A 650b x 47 is about the same diameter as a 700 x 28-30. But that doesn't mean that the bigger 650b tyre will actually fit.
You can do some measurements (keep in mind that the tyres generally are not the widest at the top) but really it comes down to trial and error because of different frame designs.
For example on my bike the chainstays are straight and not dimpled, I can fit a 700 x 40 but a 650b x 45 barely fits.
I'm not sure if I would go with 650b if you can only fit something smaller than a 47, the BB on your frame is really low.
Facanh is offline
Natenat138
30
06-27-22 07:58 AM
marcomar982
Bicycle Mechanics
4
03-19-19 08:36 PM
bikebreak
Bicycle Mechanics
7
11-08-18 03:06 PM
Saburo
3
02-08-16 07:17 PM
nazcalines
Classic & Vintage
15
10-14-13 01:55 AM
